#1 2019-04-13 19:04:43
Job
dcaenc
You good people here know how to install "dcaenc"?  It seems avidemux and handbrake can't output AC3 or DTS without dcaenc.
Thank you,
#2 2019-04-13 21:07:22
Re: dcaenc
mkdir -p ~/builds/dcaenc
cd ~/builds/dcaenc
wget http://aepatrakov.narod.ru/olderfiles/1/dcaenc-2.tar.gz
tar xf dcaenc-2.tar.gz && cd dcaenc-2
./configure --prefix=/usr/local
make
sudo make install
It was pretty simple to package it up for Debian/Devuan so here it is:
https://software.opensuse.org//download … age=dcaenc
Disclaimer: untested so let me know if it works smile
Fabricando fit faber
#3 2019-04-14 01:18:31
Job
Re: dcaenc
I will give it a go and report back.
Thank you,
Worked like charm.
Thanks again.
