#1 2019-04-13 12:43:25
zero
Grub memtest86+ entry stuck on black screen
I was trying to use memtest86+ for this topic.
Unfortunately, I get a black screen when I try to use it.
The keyboard's leds shutdown, and do not react when I push keys like num lock and caps lock.
Here the related grub.cfg
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
	insmod part_gpt
	insmod ext2
	set root='hd2,gpt1'
	if [ x$feature_platform_search_hint = xy ]; then
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd2,gpt1 --hint-efi=hd2,gpt1 --hint-baremetal=ahci2,gpt1  xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
	else
	  search --no-floppy --fs-uuid --set=root xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
	fi
	linux16	/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
	insmod part_gpt
	insmod ext2
	set root='hd2,gpt1'
	else
	fi
	linux16	/memtest86+.bin console=ttyS0,115200n8
menuentry "Memory test (memtest86+, experimental multiboot)" {
	insmod part_gpt
	insmod ext2
	set root='hd2,gpt1'
	else
	fi
	multiboot	/memtest86+_multiboot.bin
menuentry "Memory test (memtest86+, serial console 115200, experimental multiboot)" {
	insmod part_gpt
	insmod ext2
	set root='hd2,gpt1'
	else
	fi
	multiboot	/memtest86+_multiboot.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
#2 2019-04-13 14:59:22
Re: Grub memtest86+ entry stuck on black screen
The open source version doesn't work in UEFI mode.
It is possible to get a UEFI system booting in non-UEFI ("Legacy") mode, post back if you want help with that.
For a UEFI-compatible version see https://www.memtest86.com/download.htm
Otherwise, try memtester instead, that can be run from the booted system.
#3 2019-04-14 15:31:38
zero
Ok thanks, I did not know that this version doesn't work in UEFI mode :s
I tried the UEFI version with usb sticks, but, strangely, I still get a black screen… Even if, now the keyboard seems to react (led, etc…). But still nothing on screen.
As for memtester, it should be "less accurate" than memtest86+; indeed, I will have to allocate an amount of memory, leaving at least 2GB unchecked—mate takes ~1.2GB.
Can you help me to get my system in Legacy mode?
As an aside, do you have some links about how works EFI with Grub? How can I manage grubx64.efi entries under /boot/efi?
I tried efibootmgr but seems useless—some entries are rewritten at boot?
#4 2019-04-14 15:58:02
First create a BIOS boot partition on your main disk: I like to use gdisk and add a new partition of type "EF02" in sectors 34-2047 (these should be free in a correctly aligned disk), do not format the partition.
Then install the grub-pc-bin package and run
# grub-install --target=i386-pc /dev/sdX
Replace X with the letter assigned to your main drive.
Finally reboot and make sure that CSM or "Legacy" mode is enabled in your firmware ("BIOS") options, this will emulate a non-UEFI system and should allow memtester86+ to work.
If your firmware is crap (most are) then you will probably be using the fallback UEFI loader located on the EFI system partition at /EFI/BOOT/BOOTX64.EFI
See https://www.rodsbooks.com/efi-bootloade … iples.html & https://www.rodsbooks.com/efi-bootloade … ive-naming for more on this.
#5 2019-04-14 15:58:25
To free up the memory that mate is using, drop to console (ctrl-alt-F2) log in as root and stop your display manager.
/etc/init.d/slim stop Or replace slim in that command with lightdm or whatever dm you're using. Replace stop with start in that command when you're ready to go back to the desktop.
To read all about booting uefi:
https://www.rodsbooks.com/efi-bootloaders/index.html
Look around in your bios for a Legacy or CSM boot setting. It's also possible that the boot device menu gives you a choice of legacy or uefi. You can usually get to this menu by pressing some key at boot (at the motherboard/computer logo) maybe F12, F11, F8, ESC, or other. Pressing DEL usually gets you to the bios.
#6 2019-04-21 17:01:32
zero
@Head_on_a_Stick & @fsmithred
Thanks for the links, rodsbooks.com helped me a lot to understand how UEFI works. Previously, in my understanding, UEFI was only a kind of BIOS wrapper.
As for legacy mode, I used to think that I can get it under Grub EFI.
@fsmithred,
You right, how I did not think about this before :s Anyway, even if I stop lightdm, then stop as many services as possible, I will never get the maximum RAM to test.
Finally, I did my tests with memtest86+ and all 4 pass are OK.
Thanks for all.
