#1 2019-03-29 18:43:58
[Solved] Beowulf update holds back packages
Beowulf amd64 with i386 for wine
The following 3 packages are hold back. What might be the reason for this? I don't use pinning.
# apt list --upgradable
elogind/testing 241.1-1 amd64 [aktualisierbar von: 239.3+20190131-1]
libelogind0/testing 241.1-1 amd64 [aktualisierbar von: 239.3+20190131-1]
libpam-elogind/testing 241.1-1 amd64 [aktualisierbar von: 239.3+20190131-1]
Thanks, Rolf
#2 2019-03-29 19:02:40
Re: [Solved] Beowulf update holds back packages
Because updating them means removing libsystemd0, I presume you want this so use
# aptitude full-upgrade
and say "yes" when it asks.
#3 2019-03-29 19:17:17
I am a friend of apt. Neither apt full-upgrade nor apt dist-upgrade work.
Other recommendations?
Thanks, Rolf
#4 2019-03-29 19:20:21
Use aptitude.
#5 2019-03-29 19:27:28
Installed and tried it, it just confirms the conflict with libsystemd0. The solution is to keep the currently installed version 239.3.
Thanks, Rolf
#6 2019-03-29 19:35:36
Did you use full-upgrade?
If you refuse the first option it will suggest other solutions, keep going until it offers to remove libsystemd0 and upgrade the held packages.
When I tried it the first solution was to remove libsystemd0 but perhaps I have misremembered.
How did you upgrade from ascii to beowulf?
I think the recommended approach is to change the sources then use
# apt update
# apt-get upgrade
# apt-get dist-upgrade
#7 2019-03-29 19:40:30
My Beowulf is a clean install from netinstall, no upgrade from ASCII.
Yes, I used full-upgrade. Dependency missing from the repository?
Rolf
#8 2019-03-29 19:43:56
Well, if I answer n,  apitude wants to remove my wine4, inacceptable.
Looks like libsystemd0 is at 241 already.
#9 2019-03-29 19:44:01
So does aptitude offer any other options if you refuse to keep the currently installed version?
What are your sources and have you updated the package database?
Here are mine:
empty@thanatos:~ $ cat /etc/apt/sources.list
deb http://deb.devuan.org/merged beowulf main contrib non-free
deb http://deb.devuan.org/merged beowulf-updates main contrib non-free
deb http://deb.devuan.org/merged beowulf-security main contrib non-free
empty@thanatos:~ $
#10 2019-03-29 19:53:47
Same sources.list, database updated for sure (installed 12 packages today). The hold is a few updates old already.
~# aptitude full-upgrade
Die folgenden Pakete werden aktualisiert:
  elogind libelogind0{b} libpam-elogind
3 Pakete aktualisiert, 0 zusätzlich installiert, 0 werden entfernt und 0 nicht aktualisiert.
1.042 kB an Archiven müssen heruntergeladen werden. Nach dem Entpacken werden 501 kB zusätzlich belegt sein.
Die folgenden Pakete haben verletzte Abhängigkeiten:
 libelogind0 : Kollidiert mit: libsystemd0 but 241-1 is installed
               Kollidiert mit: libsystemd0:i386 but 241-1 is installed
Die folgenden Aktionen werden diese Abhängigkeiten auflösen:
     Beibehalten der folgenden Pakete in ihrer aktuellen Version:
1)     elogind [239.3+20190131-1 (now)]
2)     libelogind0 [239.3+20190131-1 (now)]
3)     libpam-elogind [239.3+20190131-1 (now)]
Diese Lösung akzeptieren? [Y/n/q/?] n
      Entfernen der folgenden Pakete:
1)      libasound2-plugins:i386 [1.1.8-1 (now, testing)]
2)      libpulse0:i386 [12.2-4 (now, testing)]
3)      libsdl2-2.0-0:i386 [2.0.9+dfsg1-1 (now, testing)]
4)      libsystemd0 [241-1 (now, testing)]
5)      libsystemd0:i386 [241-1 (now, testing)]
6)      libwine:i386 [4.0-1 (now, testing)]
7)      wine32:i386 [4.0-1 (now, testing)]
      Leave the following dependencies unresolved:
8)      wine64 empfiehlt wine32 (= 4.0-1)
9)      libopenal1:i386 empfiehlt libpulse0:i386 (>= 0.99.1)
10)     libwine:i386 empfiehlt libsdl2-2.0-0:i386 (>= 2.0.8)
11)     libwine:i386 empfiehlt libasound2-plugins:i386
1)      accountsservice [0.6.45-2 (now, testing)]
2)      brasero [3.12.2-5 (now, testing)]
3)      caja [1.20.3-1+b1 (now, testing)]
4)      caja-rename [18.7.28~bzr25-1 (now, testing)]
5)      caja-seahorse [1.18.4-2 (now, testing)]
6)      colord [1.4.3-3+devuan1 (now, testing)]
7)      cups-pk-helper [0.2.6-1+b1 (now, testing)]
8)      gir1.2-polkit-1.0 [0.105-25+devuan1 (now, testing)]
9)      gnome-disk-utility [3.30.2-3 (now, testing)]
10)     gnome-system-tools [3.0.0-8 (now, testing)]
11)     gvfs [1.38.1-3 (now, testing)]
12)     gvfs-backends [1.38.1-3 (now, testing)]
13)     gvfs-daemons [1.38.1-3 (now, testing)]
14)     liboobs-1-5 [3.0.0-4 (now, testing)]
15)     libpam-elogind [239.3+20190131-1 (now)]
16)     libpolkit-agent-1-0 [0.105-25+devuan1 (now, testing)]
17)     libpolkit-backend-1-0 [0.105-25+devuan1 (now, testing)]
18)     libpolkit-backend-elogind-1-0 [0.105-25+devuan1 (now, testing)]
19)     libpolkit-gobject-1-0 [0.105-25+devuan1 (now, testing)]
20)     libpolkit-gobject-elogind-1-0 [0.105-25+devuan1 (now, testing)]
21)     mate-control-center [1.20.4-2 (now, testing)]
22)     mate-desktop-environment [1.20.0+5 (now, testing)]
23)     mate-desktop-environment-core [1.20.0+5 (now, testing)]
24)     mate-desktop-environment-extra [1.20.0+5 (now, testing)]
25)     mate-desktop-environment-extras [1.20.0+5 (now, testing)]
26)     mate-indicator-applet [1.20.1-1 (now, testing)]
27)     mate-panel [1.20.5-1 (now, testing)]
28)     mate-polkit [1.20.2-1 (now, testing)]
29)     mate-settings-daemon [1.20.4-1 (now, testing)]
30)     mate-tweak [18.10.2-1 (now, testing)]
31)     nautilus-extension-brasero [3.12.2-5 (now, testing)]
32)     packagekit [1.1.12-5 (now, testing)]
33)     packagekit-tools [1.1.12-5 (now, testing)]
34)     policykit-1 [0.105-25+devuan1 (now, testing)]
35)     synaptic [0.84.5 (now, testing)]
36)     system-config-printer [1.5.11-4 (now, testing)]
37)     system-tools-backends [2.10.2-3+b1 (now, testing)]
38)     udisks2 [2.8.1-4 (now, testing)]
39)     elogind [239.3+20190131-1 (now)]
40)     libelogind0 [239.3+20190131-1 (now)]
41)     atril empfiehlt gvfs
42)     blueman empfiehlt policykit-1
43)     caja-eiciel empfiehlt caja
44)     cups empfiehlt colord
45)     cups-daemon empfiehlt colord
46)     cups-filters empfiehlt colord
47)     engrampa empfiehlt gvfs
48)     gvfs-common empfiehlt gvfs
49)     libpackagekit-glib2-18 empfiehlt packagekit (= 1.1.12-5)
50)     lightdm-gtk-greeter empfiehlt policykit-1
51)     mate-session-manager empfiehlt caja
52)     mate-session-manager empfiehlt mate-panel
53)     mate-session-manager empfiehlt mate-polkit
54)     mate-session-manager empfiehlt mate-settings-daemon
55)     mate-system-monitor empfiehlt gvfs
56)     mate-tweak empfiehlt mate-indicator-applet (>= 1.18.0)
57)     mozo empfiehlt mate-panel
58)     pulseaudio empfiehlt libpam-systemd
59)     system-config-printer-common empfiehlt cups-pk-helper
60)     udisks2 empfiehlt policykit-1
61)     upower empfiehlt policykit-1
62)     xserver-xorg-core empfiehlt libpam-systemd
63)     winetricks empfiehlt policykit-1 | kde-cli-tools
64)     elogind empfiehlt policykit-1
Diese Lösung akzeptieren? [Y/n/q/?] q
Alle Anstrengungen, diese Abhängigkeiten aufzulösen, aufgegeben.
Abbruch.
None of the proposed solutions looks acceptable to me.
Rolf
#11 2019-03-29 19:56:20
Erm, I don't speak German, sorry.
Try
LC_ALL=C aptitude full-upgrade
And keep saying "no" until it tells you there are no more solutions, thanks!
I don't have WINE installed so perhaps that's making a difference.
#12 2019-04-30 21:00:52
Here is a late follow up on this topic. I have seen the same behaviour now on a Beowulf installation in Virtual Box. Problem is unresolved so far.
I have used your recommendation so the output is in English now.
# LC_ALL=C aptitude full-upgrade
  efibootmgr{u}
3 packages upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
Need to get 1042 kB of archives. After unpacking 416 kB will be used.
 libelogind0 : Conflicts: libsystemd0 but 241-3 is installed
The following actions will resolve these dependencies:
     Keep the following packages at their current version:
Accept this solution? [Y/n/q/?] n
     Remove the following packages:
1)     libsystemd0 [241-3 (now, testing)]
2)      caja [1.20.3-1+b1 (now, testing)]
3)      caja-rename [18.7.28~bzr25-1 (now, testing)]
4)      caja-seahorse [1.18.4-2 (now, testing)]
5)      colord [1.4.3-3+devuan1 (now, testing)]
6)      cups-pk-helper [0.2.6-1+b1 (now, testing)]
7)      gir1.2-polkit-1.0 [0.105-25+devuan1 (now, testing)]
8)      gnome-system-tools [3.0.0-8 (now, testing)]
9)      gvfs [1.38.1-3 (now, testing)]
10)     gvfs-backends [1.38.1-3 (now, testing)]
11)     gvfs-daemons [1.38.1-3 (now, testing)]
12)     liboobs-1-5 [3.0.0-4 (now, testing)]
13)     libpam-elogind [239.3+20190131-1 (now)]
14)     libpolkit-agent-1-0 [0.105-25+devuan1 (now, testing)]
15)     libpolkit-backend-1-0 [0.105-25+devuan1 (now, testing)]
16)     libpolkit-backend-elogind-1-0 [0.105-25+devuan1 (now, testing)]
17)     libpolkit-gobject-1-0 [0.105-25+devuan1 (now, testing)]
18)     libpolkit-gobject-elogind-1-0 [0.105-25+devuan1 (now, testing)]
19)     mate-control-center [1.20.4-2 (now, testing)]
20)     mate-desktop-environment [1.20.0+5 (now, testing)]
21)     mate-desktop-environment-core [1.20.0+5 (now, testing)]
22)     mate-desktop-environment-extra [1.20.0+5 (now, testing)]
23)     mate-desktop-environment-extras [1.20.0+5 (now, testing)]
24)     mate-panel [1.20.5-1 (now, testing)]
25)     mate-polkit [1.20.2-1 (now, testing)]
26)     mate-settings-daemon [1.20.4-1 (now, testing)]
27)     packagekit [1.1.12-5 (now, testing)]
28)     packagekit-tools [1.1.12-5 (now, testing)]
29)     policykit-1 [0.105-25+devuan1 (now, testing)]
30)     system-config-printer [1.5.11-4 (now, testing)]
31)     system-tools-backends [2.10.2-3+b1 (now, testing)]
32)     udisks2 [2.8.1-4 (now, testing)]
33)     elogind [239.3+20190131-1 (now)]
34)     libelogind0 [239.3+20190131-1 (now)]
35)     atril recommends gvfs
36)     blueman recommends policykit-1
37)     caja-eiciel recommends caja
38)     cups recommends colord
39)     cups-daemon recommends colord
40)     cups-filters recommends colord
41)     engrampa recommends gvfs
42)     gvfs-common recommends gvfs
43)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
44)     lightdm-gtk-greeter recommends policykit-1
45)     mate-session-manager recommends caja
46)     mate-session-manager recommends mate-panel
47)     mate-session-manager recommends mate-polkit
48)     mate-session-manager recommends mate-settings-daemon
49)     mate-system-monitor recommends gvfs
50)     mozo recommends mate-panel
51)     pulseaudio recommends libpam-systemd
52)     system-config-printer-common recommends cups-pk-helper
53)     udisks2 recommends policykit-1
54)     upower recommends policykit-1
55)     xserver-xorg-core recommends libpam-systemd
56)     elogind recommends policykit-1
7)      elogind [239.3+20190131-1 (now)]
9)      gnome-system-tools [3.0.0-8 (now, testing)]
10)     gvfs [1.38.1-3 (now, testing)]
11)     gvfs-backends [1.38.1-3 (now, testing)]
12)     gvfs-daemons [1.38.1-3 (now, testing)]
13)     liboobs-1-5 [3.0.0-4 (now, testing)]
14)     libpam-elogind [239.3+20190131-1 (now)]
15)     libpolkit-agent-1-0 [0.105-25+devuan1 (now, testing)]
16)     libpolkit-backend-1-0 [0.105-25+devuan1 (now, testing)]
17)     libpolkit-backend-elogind-1-0 [0.105-25+devuan1 (now, testing)]
18)     libpolkit-gobject-1-0 [0.105-25+devuan1 (now, testing)]
19)     libpolkit-gobject-elogind-1-0 [0.105-25+devuan1 (now, testing)]
20)     lightdm [1.26.0-4 (now, testing)]
26)     mate-panel [1.20.5-1 (now, testing)]
27)     mate-polkit [1.20.2-1 (now, testing)]
28)     mate-settings-daemon [1.20.4-1 (now, testing)]
29)     packagekit [1.1.12-5 (now, testing)]
30)     packagekit-tools [1.1.12-5 (now, testing)]
31)     policykit-1 [0.105-25+devuan1 (now, testing)]
32)     system-config-printer [1.5.11-4 (now, testing)]
33)     system-tools-backends [2.10.2-3+b1 (now, testing)]
34)     udisks2 [2.8.1-4 (now, testing)]
35)     libelogind0 [239.3+20190131-1 (now)]
36)     atril recommends gvfs
37)     blueman recommends policykit-1
38)     caja-eiciel recommends caja
39)     cups recommends colord
40)     cups-daemon recommends colord
41)     cups-filters recommends colord
42)     engrampa recommends gvfs
43)     gvfs-common recommends gvfs
44)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
45)     lightdm-gtk-greeter recommends policykit-1
46)     mate-desktop-environment-extras recommends gnome-system-tools
47)     mate-session-manager recommends caja
48)     mate-session-manager recommends mate-panel
49)     mate-session-manager recommends mate-polkit
50)     mate-session-manager recommends mate-settings-daemon
51)     mate-system-monitor recommends gvfs
52)     mozo recommends mate-panel
53)     pulseaudio recommends libpam-systemd
54)     system-config-printer-common recommends cups-pk-helper
55)     udisks2 recommends policykit-1
56)     upower recommends policykit-1
57)     xserver-xorg-core recommends libpam-systemd
13)     libelogind0 [239.3+20190131-1 (now)]
21)     lightdm [1.26.0-4 (now, testing)]
22)     mate-control-center [1.20.4-2 (now, testing)]
23)     mate-desktop-environment [1.20.0+5 (now, testing)]
24)     mate-desktop-environment-core [1.20.0+5 (now, testing)]
25)     mate-desktop-environment-extra [1.20.0+5 (now, testing)]
26)     mate-desktop-environment-extras [1.20.0+5 (now, testing)]
30)     packagekit [1.1.12-5 (now, testing)]
31)     packagekit-tools [1.1.12-5 (now, testing)]
32)     policykit-1 [0.105-25+devuan1 (now, testing)]
33)     system-config-printer [1.5.11-4 (now, testing)]
34)     system-tools-backends [2.10.2-3+b1 (now, testing)]
35)     udisks2 [2.8.1-4 (now, testing)]
46)     mate-desktop-environment-extras recommends caja-rename
47)     mate-desktop-environment-extras recommends caja-seahorse
48)     mate-session-manager recommends caja
49)     mate-session-manager recommends mate-panel
50)     mate-session-manager recommends mate-polkit
51)     mate-session-manager recommends mate-settings-daemon
52)     mate-system-monitor recommends gvfs
53)     mozo recommends mate-panel
54)     pulseaudio recommends libpam-systemd
55)     system-config-printer-common recommends cups-pk-helper
*** No more solutions available ***
Accept this solution? [Y/n/q/?] q
Abandoning all efforts to resolve these dependencies.
Abort.
Suggestions?
Thanks, Rolf
#13 2019-04-30 22:41:17
What does apt-cache policy elogind show? I don't see your version in any repos.
When I installed libelogind0, it removed libsystemd0. Maybe if you try installing libelogind0 it will upgrade elogind and remove lsd0. Or specify the version as libelogind0=241.1-1
#14 2019-05-01 07:43:17
LC_ALL=C apt-cache policy elogind
elogind:
  Installed: 239.3+20190131-1
  Candidate: 241.1-1
  Version table:
     241.1-1 500
        500 http://de.deb.devuan.org/merged beowulf/main amd64 Packages
 *** 239.3+20190131-1 100
        100 /var/lib/dpkg/status
My secondary PC and the VBox installation show the same. Both were installed to CLI from the net iso image dated Feb 16th. Then installed Mate/Lightdm manually.
Rolf
#15 2019-05-01 13:08:18
239.1+20181115-1 is from http://deb.devuan.org/devuan experimental/main.
not sure where 239.3+20190131-1 is from though.
#16 2019-05-01 13:49:32
sgage
For what it's worth, I am having the same elogind packages held back as well. And aptitude full-upgrade does not propose an acceptable solution.
#17 2019-05-01 15:07:34
Glad that I am not alone...
#18 2019-05-01 15:32:42
sgage
Yes, sometimes in nice to know you're not the only one!
Just out of curiosity, what DE are you using?
I'm using MATE, and I am finding that the volume control in the panel works erratically with the mouse wheel. It works perfectly well in Debian buster. So I imagine there's some "plumbing" issue with regard to removing systemd dependencies from some of the infrastructure. I wonder if this elogind business has something to do with it...
Other than that, beowulf/MATE is working great for me.
#19 2019-05-01 15:44:41
Well, just tried the second choice aptitude gives (removing libsystemd0) on my VBox Beowulf, and that really fixes the issue. Can't say from where this library came from. Looks like it was installed when I was setting up the VM end of February.
I was reluctant to remove libsystemd0 before because I thought I had read something about this lib being some placeholder required to fool some packages that insist on a dependency to libsystemd0.
@sgage: I am using Mate/Lightdm, manually installed from cli. Have not yet worked with audio on the Beowulf installations, none of them got loudspeakers connected.
Rolf
#20 2019-05-01 15:55:35
sgage
I was relecutant to remove libsystemd0 before because I thought I had read something about this lib being some placeholder required to fool some packages that insist on a dependency to libsystemd0.
Rolf
In addition to the elogind packages, I am now having shim-signed held back.
Using aptitude, the second option proposes to remove libsystemd0, and several other packages. If I accept the choice, it calculates the transaction, and wants to remove over 250 packages!
So I'll just have to wait until some dependencies get resolved down the line.
#21 2019-05-01 16:16:25
shim-signed is something for secure boot. Do you need this kind of package?
After a reboot, 4 more packages to update, then the VM is happy.
Just tried the same on my secondary PC which has a lot more stuff installed. There removing just libsystemd0 fails. aptitude wants to remove something like 108 packages including Mate. So the fix is not that easy.
Rolf
#22 2019-05-01 17:09:58
Moved from the VM to my secondary PC running a native Beowulf with Mate/Lighdm, encrypted with a lot of stuff installed already including some i386 stuff like wine. There simply removing libsystemd0 does not work.
Output from aptitude full-upgrade and 20 no's to the suggested solutions. This overuns the terminal default buffer.
  shim-helpers-amd64-signed{a} shim-unsigned{a}
  shim{u}
  elogind libelogind0{b} libpam-elogind shim-signed
4 packages upgraded, 2 newly installed, 1 to remove and 0 not upgraded.
Need to get 2397 kB of archives. After unpacking 4518 kB will be used.
               Conflicts: libsystemd0:i386 but 241-3 is installed
4)      libsystemd0 [241-3 (now, testing)]
5)      libsystemd0:i386 [241-3 (now, testing)]
8)      wine64 recommends wine32 (= 4.0-1)
9)      libopenal1:i386 recommends libpulse0:i386 (>= 0.99.1)
10)     libwine:i386 recommends libsdl2-2.0-0:i386 (>= 2.0.8)
11)     libwine:i386 recommends libasound2-plugins:i386
35)     synaptic [0.84.6 (now, testing)]
41)     atril recommends gvfs
42)     blueman recommends policykit-1
43)     caja-eiciel recommends caja
44)     cups recommends colord
45)     cups-daemon recommends colord
46)     cups-filters recommends colord
47)     engrampa recommends gvfs
48)     gvfs-common recommends gvfs
49)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
50)     lightdm-gtk-greeter recommends policykit-1
51)     mate-session-manager recommends caja
52)     mate-session-manager recommends mate-panel
53)     mate-session-manager recommends mate-polkit
54)     mate-session-manager recommends mate-settings-daemon
55)     mate-system-monitor recommends gvfs
56)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
57)     mozo recommends mate-panel
58)     pulseaudio recommends libpam-systemd
59)     system-config-printer-common recommends cups-pk-helper
60)     udisks2 recommends policykit-1
61)     upower recommends policykit-1
62)     xserver-xorg-core recommends libpam-systemd
63)     winetricks recommends policykit-1 | kde-cli-tools
64)     elogind recommends policykit-1
8)      elogind [239.3+20190131-1 (now)]
9)      gir1.2-polkit-1.0 [0.105-25+devuan1 (now, testing)]
10)     gnome-disk-utility [3.30.2-3 (now, testing)]
11)     gnome-system-tools [3.0.0-8 (now, testing)]
12)     gvfs [1.38.1-3 (now, testing)]
13)     gvfs-backends [1.38.1-3 (now, testing)]
14)     gvfs-daemons [1.38.1-3 (now, testing)]
15)     liboobs-1-5 [3.0.0-4 (now, testing)]
16)     libpam-elogind [239.3+20190131-1 (now)]
17)     libpolkit-agent-1-0 [0.105-25+devuan1 (now, testing)]
18)     libpolkit-backend-1-0 [0.105-25+devuan1 (now, testing)]
19)     libpolkit-backend-elogind-1-0 [0.105-25+devuan1 (now, testing)]
20)     libpolkit-gobject-1-0 [0.105-25+devuan1 (now, testing)]
21)     libpolkit-gobject-elogind-1-0 [0.105-25+devuan1 (now, testing)]
22)     lightdm [1.26.0-4 (now, testing)]
23)     mate-control-center [1.20.4-2 (now, testing)]
24)     mate-desktop-environment [1.20.0+5 (now, testing)]
25)     mate-desktop-environment-core [1.20.0+5 (now, testing)]
26)     mate-desktop-environment-extra [1.20.0+5 (now, testing)]
27)     mate-desktop-environment-extras [1.20.0+5 (now, testing)]
28)     mate-indicator-applet [1.20.1-1 (now, testing)]
29)     mate-panel [1.20.5-1 (now, testing)]
30)     mate-polkit [1.20.2-1 (now, testing)]
31)     mate-settings-daemon [1.20.4-1 (now, testing)]
32)     mate-tweak [18.10.2-1 (now, testing)]
33)     nautilus-extension-brasero [3.12.2-5 (now, testing)]
34)     packagekit [1.1.12-5 (now, testing)]
35)     packagekit-tools [1.1.12-5 (now, testing)]
36)     policykit-1 [0.105-25+devuan1 (now, testing)]
37)     synaptic [0.84.6 (now, testing)]
38)     system-config-printer [1.5.11-4 (now, testing)]
39)     system-tools-backends [2.10.2-3+b1 (now, testing)]
40)     udisks2 [2.8.1-4 (now, testing)]
41)     libelogind0 [239.3+20190131-1 (now)]
42)     atril recommends gvfs
43)     blueman recommends policykit-1
44)     caja-eiciel recommends caja
45)     cups recommends colord
46)     cups-daemon recommends colord
47)     cups-filters recommends colord
48)     engrampa recommends gvfs
49)     gvfs-common recommends gvfs
50)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
51)     lightdm-gtk-greeter recommends policykit-1
52)     mate-session-manager recommends caja
53)     mate-session-manager recommends mate-panel
54)     mate-session-manager recommends mate-polkit
55)     mate-session-manager recommends mate-settings-daemon
56)     mate-system-monitor recommends gvfs
57)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
58)     mozo recommends mate-panel
59)     pulseaudio recommends libpam-systemd
60)     system-config-printer-common recommends cups-pk-helper
61)     udisks2 recommends policykit-1
62)     upower recommends policykit-1
63)     xserver-xorg-core recommends libpam-systemd
64)     winetricks recommends policykit-1 | kde-cli-tools
15)     libelogind0 [239.3+20190131-1 (now)]
16)     liboobs-1-5 [3.0.0-4 (now, testing)]
17)     libpam-elogind [239.3+20190131-1 (now)]
18)     libpolkit-agent-1-0 [0.105-25+devuan1 (now, testing)]
19)     libpolkit-backend-1-0 [0.105-25+devuan1 (now, testing)]
20)     libpolkit-backend-elogind-1-0 [0.105-25+devuan1 (now, testing)]
21)     libpolkit-gobject-1-0 [0.105-25+devuan1 (now, testing)]
22)     libpolkit-gobject-elogind-1-0 [0.105-25+devuan1 (now, testing)]
23)     lightdm [1.26.0-4 (now, testing)]
24)     mate-control-center [1.20.4-2 (now, testing)]
25)     mate-desktop-environment [1.20.0+5 (now, testing)]
26)     mate-desktop-environment-core [1.20.0+5 (now, testing)]
27)     mate-desktop-environment-extra [1.20.0+5 (now, testing)]
28)     mate-desktop-environment-extras [1.20.0+5 (now, testing)]
29)     mate-indicator-applet [1.20.1-1 (now, testing)]
30)     mate-panel [1.20.5-1 (now, testing)]
31)     mate-polkit [1.20.2-1 (now, testing)]
32)     mate-settings-daemon [1.20.4-1 (now, testing)]
33)     mate-tweak [18.10.2-1 (now, testing)]
34)     nautilus-extension-brasero [3.12.2-5 (now, testing)]
35)     packagekit [1.1.12-5 (now, testing)]
36)     packagekit-tools [1.1.12-5 (now, testing)]
37)     policykit-1 [0.105-25+devuan1 (now, testing)]
38)     synaptic [0.84.6 (now, testing)]
39)     system-config-printer [1.5.11-4 (now, testing)]
40)     system-tools-backends [2.10.2-3+b1 (now, testing)]
41)     udisks2 [2.8.1-4 (now, testing)]
2)       audacious [3.10.1-1 (now, testing)]
3)       audacious-plugins [3.10.1-1 (now, testing)]
4)       blueman [2.0.8-1 (now, testing)]
5)       brasero [3.12.2-5 (now, testing)]
6)       caja [1.20.3-1+b1 (now, testing)]
7)       caja-rename [18.7.28~bzr25-1 (now, testing)]
8)       caja-seahorse [1.18.4-2 (now, testing)]
9)       colord [1.4.3-3+devuan1 (now, testing)]
10)      cups [2.2.10-6 (now, testing)]
11)      cups-browsed [1.21.6-5 (now, testing)]
12)      cups-core-drivers [2.2.10-6 (now, testing)]
13)      cups-daemon [2.2.10-6 (now, testing)]
14)      cups-pk-helper [0.2.6-1+b1 (now, testing)]
15)      dmeventd [2:1.02.155-2 (now, testing)]
16)      elogind [239.3+20190131-1 (now)]
17)      gimp [2.10.8-2 (now, testing)]
18)      gir1.2-polkit-1.0 [0.105-25+devuan1 (now, testing)]
19)      gnome-disk-utility [3.30.2-3 (now, testing)]
20)      gnome-system-tools [3.0.0-8 (now, testing)]
21)      gstreamer1.0-plugins-bad [1.14.4-1+b1 (now, testing)]
22)      gstreamer1.0-pulseaudio [1.14.4-1 (now, testing)]
23)      gvfs [1.38.1-3 (now, testing)]
24)      gvfs-backends [1.38.1-3 (now, testing)]
25)      gvfs-daemons [1.38.1-3 (now, testing)]
26)      irqbalance [1.5.0-3 (now, testing)]
27)      libaccountsservice0 [0.6.45-2 (now, testing)]
28)      libasound2-plugins [1.1.8-1 (now, testing)]
29)      libelogind0 [239.3+20190131-1 (now)]
30)      libfluidsynth1 [1.1.11-1 (now, testing)]
31)      libgegl-0.4-0 [0.4.12-2 (now, testing)]
32)      libgimp2.0 [2.10.8-2 (now, testing)]
33)      liblvm2cmd2.03 [2.03.02-2 (now, testing)]
34)      libmatemixer0 [1.20.1-1 (now, testing)]
35)      liboobs-1-5 [3.0.0-4 (now, testing)]
36)      libpam-elogind [239.3+20190131-1 (now)]
37)      libpolkit-agent-1-0 [0.105-25+devuan1 (now, testing)]
38)      libpolkit-backend-1-0 [0.105-25+devuan1 (now, testing)]
39)      libpolkit-backend-elogind-1-0 [0.105-25+devuan1 (now, testing)]
40)      libpolkit-gobject-1-0 [0.105-25+devuan1 (now, testing)]
41)      libpolkit-gobject-elogind-1-0 [0.105-25+devuan1 (now, testing)]
42)      libprocps7 [2:3.3.15-2 (now, testing)]
43)      libpulse-mainloop-glib0 [12.2-4 (now, testing)]
44)      libpulse0 [12.2-4 (now, testing)]
45)      libpulsedsp [12.2-4 (now, testing)]
46)      libsdl-image1.2 [1.2.12-10 (now, testing)]
47)      libsdl1.2debian [1.2.15+dfsg2-4 (now, testing)]
48)      libsdl2-2.0-0 [2.0.9+dfsg1-1 (now, testing)]
49)      libsmbclient [2:4.9.5+dfsg-3 (now, testing)]
50)      libsystemd0 [241-3 (now, testing)]
51)      libsystemd0:i386 [241-3 (now, testing)]
52)      libwine [4.0-1 (now, testing)]
53)      lvm2 [2.03.02-2 (now, testing)]
54)      mate-control-center [1.20.4-2 (now, testing)]
55)      mate-desktop-environment [1.20.0+5 (now, testing)]
56)      mate-desktop-environment-core [1.20.0+5 (now, testing)]
57)      mate-desktop-environment-extra [1.20.0+5 (now, testing)]
58)      mate-desktop-environment-extras [1.20.0+5 (now, testing)]
59)      mate-indicator-applet [1.20.1-1 (now, testing)]
60)      mate-media [1.20.2-1 (now, testing)]
61)      mate-panel [1.20.5-1 (now, testing)]
62)      mate-polkit [1.20.2-1 (now, testing)]
63)      mate-screensaver [1.20.3-3 (now, testing)]
64)      mate-session-manager [1.20.2-1 (now, testing)]
65)      mate-settings-daemon [1.20.4-1 (now, testing)]
66)      mate-system-monitor [1.20.2-1 (now, testing)]
67)      mate-tweak [18.10.2-1 (now, testing)]
68)      nautilus-extension-brasero [3.12.2-5 (now, testing)]
69)      nfs-common [1:1.3.4-2.5 (now, testing)]
70)      packagekit [1.1.12-5 (now, testing)]
71)      packagekit-tools [1.1.12-5 (now, testing)]
72)      policykit-1 [0.105-25+devuan1 (now, testing)]
73)      printer-driver-gutenprint [5.3.1-7 (now, testing)]
74)      procps [2:3.3.15-2 (now, testing)]
75)      pulseaudio [12.2-4 (now, testing)]
76)      pulseaudio-module-bluetooth [12.2-4 (now, testing)]
77)      pulseaudio-utils [12.2-4 (now, testing)]
78)      python-samba [2:4.9.5+dfsg-3 (now, testing)]
79)      python3-smbc [1.0.15.6-1+b2 (now, testing)]
80)      rpcbind [1.2.5-0.3 (now, testing)]
81)      rsyslog [8.1901.0-1 (now, testing)]
82)      samba-common-bin [2:4.9.5+dfsg-3 (now, testing)]
83)      samba-dsdb-modules [2:4.9.5+dfsg-3 (now, testing)]
84)      samba-libs [2:4.9.5+dfsg-3 (now, testing)]
85)      sane-utils [1.0.27-3.2 (now, testing)]
86)      smbclient [2:4.9.5+dfsg-3 (now, testing)]
87)      system-config-printer [1.5.11-4 (now, testing)]
88)      system-tools-backends [2.10.2-3+b1 (now, testing)]
89)      udisks2 [2.8.1-4 (now, testing)]
90)      virtualbox-6.0 [6.0.4-128413~Ubuntu~bionic (now)]
91)      vlc [3.0.6-1 (now, testing)]
92)      vlc-plugin-base [3.0.6-1 (now, testing)]
93)      vlc-plugin-samba [3.0.6-1 (now, testing)]
94)      winbind [2:4.9.5+dfsg-3 (now, testing)]
95)      wine64 [4.0-1 (now, testing)]
96)      xorg [1:7.7+19 (now, testing)]
97)      xserver-xorg [1:7.7+19 (now, testing)]
98)      xserver-xorg-core [2:1.20.3-1 (now, testing)]
99)      xserver-xorg-input-all [1:7.7+19 (now, testing)]
100)     xserver-xorg-input-libinput [0.28.2-2 (now, testing)]
101)     xserver-xorg-input-wacom [0.34.99.1-1 (now, testing)]
102)     xserver-xorg-video-all [1:7.7+19 (now, testing)]
103)     xserver-xorg-video-amdgpu [18.1.99+git20190207-1 (now, testing)]
104)     xserver-xorg-video-ati [1:18.1.99+git20190207-1 (now, testing)]
105)     xserver-xorg-video-fbdev [1:0.5.0-1 (now, testing)]
106)     xserver-xorg-video-intel [2:2.99.917+git20180925-2 (now, testing)]
107)     xserver-xorg-video-nouveau [1:1.0.16-1 (now, testing)]
108)     xserver-xorg-video-qxl [0.1.5-2+b1 (now, testing)]
109)     xserver-xorg-video-radeon [1:18.1.99+git20190207-1 (now, testing)]
110)     xserver-xorg-video-vesa [1:2.4.0-1 (now, testing)]
111)     xserver-xorg-video-vmware [1:13.3.0-2 (now, testing)]
       Install the following packages:
112)     elogind:i386 [241.1-1 (testing)]
113)     gstreamer1.0-alsa [1.14.4-1 (testing)]
114)     libacl1:i386 [2.2.53-4 (testing)]
115)     libattr1:i386 [1:2.4.48-4 (testing)]
116)     libaudit1:i386 [1:2.8.4-3 (testing)]
117)     libcap-ng0:i386 [0.7.9-2 (testing)]
118)     libelogind0:i386 [241.1-1 (testing)]
119)     libncursesw6:i386 [6.1+20181013-2 (testing)]
120)     libpam-elogind:i386 [241.1-1 (testing)]
121)     libpam0g:i386 [1.3.1-5 (testing)]
122)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
123)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
124)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
125)     libprocps7:i386 [2:3.3.15-2 (testing)]
126)     policykit-1:i386 [0.105-25+devuan1 (testing)]
127)     procps:i386 [2:3.3.15-2 (testing)]
128)     tightvncserver [1:1.3.9-9 (testing)]
129)     atril recommends gvfs
130)     caja recommends gvfs-backends
131)     caja-eiciel recommends caja
132)     cups recommends colord
133)     cups-filters recommends colord
134)     engrampa recommends gvfs
135)     gvfs-common recommends gvfs
136)     libopenal1 recommends libpulse0 (>= 0.99.1)
137)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
138)     libsane recommends sane-utils (>= 1.0.27-3.2)
139)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
140)     libwine recommends libasound2-plugins
141)     lightdm recommends xserver-xorg
142)     linux-image-4.19.0-4-amd64 recommends irqbalance
143)     mate-desktop-environment recommends mate-media (>= 1.20)
144)     mate-desktop-environment-extras recommends blueman
145)     mate-session-manager recommends mate-panel
146)     mate-session-manager recommends mate-polkit
147)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
148)     mozo recommends mate-panel
149)     samba-common recommends samba-common-bin
150)     system-config-printer-common recommends cups-pk-helper
151)     system-config-printer-common recommends python3-smbc
152)     totem recommends gstreamer1.0-plugins-bad
153)     totem recommends gstreamer1.0-pulseaudio
154)     virtualbox-6.0 recommends libpulse0
10)      cups-browsed [1.21.6-5 (now, testing)]
11)      cups-daemon [2.2.10-6 (now, testing)]
12)      cups-pk-helper [0.2.6-1+b1 (now, testing)]
13)      dmeventd [2:1.02.155-2 (now, testing)]
14)      elogind [239.3+20190131-1 (now)]
15)      gimp [2.10.8-2 (now, testing)]
16)      gir1.2-polkit-1.0 [0.105-25+devuan1 (now, testing)]
17)      gnome-disk-utility [3.30.2-3 (now, testing)]
18)      gnome-system-tools [3.0.0-8 (now, testing)]
19)      gstreamer1.0-plugins-bad [1.14.4-1+b1 (now, testing)]
20)      gstreamer1.0-pulseaudio [1.14.4-1 (now, testing)]
21)      gvfs [1.38.1-3 (now, testing)]
22)      gvfs-backends [1.38.1-3 (now, testing)]
23)      gvfs-daemons [1.38.1-3 (now, testing)]
24)      irqbalance [1.5.0-3 (now, testing)]
25)      libaccountsservice0 [0.6.45-2 (now, testing)]
26)      libasound2-plugins [1.1.8-1 (now, testing)]
27)      libelogind0 [239.3+20190131-1 (now)]
28)      libfluidsynth1 [1.1.11-1 (now, testing)]
29)      libgegl-0.4-0 [0.4.12-2 (now, testing)]
30)      libgimp2.0 [2.10.8-2 (now, testing)]
31)      liblvm2cmd2.03 [2.03.02-2 (now, testing)]
32)      libmatemixer0 [1.20.1-1 (now, testing)]
33)      liboobs-1-5 [3.0.0-4 (now, testing)]
34)      libpam-elogind [239.3+20190131-1 (now)]
35)      libpolkit-agent-1-0 [0.105-25+devuan1 (now, testing)]
36)      libpolkit-backend-1-0 [0.105-25+devuan1 (now, testing)]
37)      libpolkit-backend-elogind-1-0 [0.105-25+devuan1 (now, testing)]
38)      libpolkit-gobject-1-0 [0.105-25+devuan1 (now, testing)]
39)      libpolkit-gobject-elogind-1-0 [0.105-25+devuan1 (now, testing)]
40)      libprocps7 [2:3.3.15-2 (now, testing)]
41)      libpulse-mainloop-glib0 [12.2-4 (now, testing)]
42)      libpulse0 [12.2-4 (now, testing)]
43)      libpulsedsp [12.2-4 (now, testing)]
44)      libsdl-image1.2 [1.2.12-10 (now, testing)]
45)      libsdl1.2debian [1.2.15+dfsg2-4 (now, testing)]
46)      libsdl2-2.0-0 [2.0.9+dfsg1-1 (now, testing)]
47)      libsmbclient [2:4.9.5+dfsg-3 (now, testing)]
48)      libsystemd0 [241-3 (now, testing)]
49)      libsystemd0:i386 [241-3 (now, testing)]
50)      libwine [4.0-1 (now, testing)]
51)      lvm2 [2.03.02-2 (now, testing)]
52)      mate-control-center [1.20.4-2 (now, testing)]
53)      mate-desktop-environment [1.20.0+5 (now, testing)]
54)      mate-desktop-environment-core [1.20.0+5 (now, testing)]
55)      mate-desktop-environment-extra [1.20.0+5 (now, testing)]
56)      mate-desktop-environment-extras [1.20.0+5 (now, testing)]
57)      mate-indicator-applet [1.20.1-1 (now, testing)]
58)      mate-media [1.20.2-1 (now, testing)]
59)      mate-panel [1.20.5-1 (now, testing)]
60)      mate-polkit [1.20.2-1 (now, testing)]
61)      mate-screensaver [1.20.3-3 (now, testing)]
62)      mate-session-manager [1.20.2-1 (now, testing)]
63)      mate-settings-daemon [1.20.4-1 (now, testing)]
64)      mate-system-monitor [1.20.2-1 (now, testing)]
65)      mate-tweak [18.10.2-1 (now, testing)]
66)      nautilus-extension-brasero [3.12.2-5 (now, testing)]
67)      nfs-common [1:1.3.4-2.5 (now, testing)]
68)      packagekit [1.1.12-5 (now, testing)]
69)      packagekit-tools [1.1.12-5 (now, testing)]
70)      policykit-1 [0.105-25+devuan1 (now, testing)]
71)      procps [2:3.3.15-2 (now, testing)]
72)      pulseaudio [12.2-4 (now, testing)]
73)      pulseaudio-module-bluetooth [12.2-4 (now, testing)]
74)      pulseaudio-utils [12.2-4 (now, testing)]
75)      python-samba [2:4.9.5+dfsg-3 (now, testing)]
76)      python3-smbc [1.0.15.6-1+b2 (now, testing)]
77)      rpcbind [1.2.5-0.3 (now, testing)]
78)      rsyslog [8.1901.0-1 (now, testing)]
79)      samba-common-bin [2:4.9.5+dfsg-3 (now, testing)]
80)      samba-dsdb-modules [2:4.9.5+dfsg-3 (now, testing)]
81)      samba-libs [2:4.9.5+dfsg-3 (now, testing)]
82)      sane-utils [1.0.27-3.2 (now, testing)]
83)      smbclient [2:4.9.5+dfsg-3 (now, testing)]
84)      system-config-printer [1.5.11-4 (now, testing)]
85)      system-tools-backends [2.10.2-3+b1 (now, testing)]
86)      udisks2 [2.8.1-4 (now, testing)]
87)      virtualbox-6.0 [6.0.4-128413~Ubuntu~bionic (now)]
88)      vlc [3.0.6-1 (now, testing)]
89)      vlc-plugin-base [3.0.6-1 (now, testing)]
90)      vlc-plugin-samba [3.0.6-1 (now, testing)]
91)      winbind [2:4.9.5+dfsg-3 (now, testing)]
92)      wine64 [4.0-1 (now, testing)]
93)      xorg [1:7.7+19 (now, testing)]
94)      xserver-xorg [1:7.7+19 (now, testing)]
95)      xserver-xorg-core [2:1.20.3-1 (now, testing)]
96)      xserver-xorg-input-all [1:7.7+19 (now, testing)]
97)      xserver-xorg-input-libinput [0.28.2-2 (now, testing)]
98)      xserver-xorg-input-wacom [0.34.99.1-1 (now, testing)]
99)      xserver-xorg-video-all [1:7.7+19 (now, testing)]
100)     xserver-xorg-video-amdgpu [18.1.99+git20190207-1 (now, testing)]
101)     xserver-xorg-video-ati [1:18.1.99+git20190207-1 (now, testing)]
102)     xserver-xorg-video-fbdev [1:0.5.0-1 (now, testing)]
103)     xserver-xorg-video-intel [2:2.99.917+git20180925-2 (now, testing)]
104)     xserver-xorg-video-nouveau [1:1.0.16-1 (now, testing)]
105)     xserver-xorg-video-qxl [0.1.5-2+b1 (now, testing)]
106)     xserver-xorg-video-radeon [1:18.1.99+git20190207-1 (now, testing)]
107)     xserver-xorg-video-vesa [1:2.4.0-1 (now, testing)]
108)     xserver-xorg-video-vmware [1:13.3.0-2 (now, testing)]
109)     cups-browsed:i386 [1.21.6-5 (testing)]
110)     cups-daemon:i386 [2.2.10-6 (testing)]
111)     elogind:i386 [241.1-1 (testing)]
112)     gstreamer1.0-alsa [1.14.4-1 (testing)]
113)     libacl1:i386 [2.2.53-4 (testing)]
114)     libattr1:i386 [1:2.4.48-4 (testing)]
115)     libaudit1:i386 [1:2.8.4-3 (testing)]
116)     libavahi-glib1:i386 [0.7-4+b1 (testing)]
118)     libcupsfilters1:i386 [1.21.6-5 (testing)]
119)     libcupsimage2:i386 [2.2.10-6 (testing)]
120)     libelogind0:i386 [241.1-1 (testing)]
121)     libncursesw6:i386 [6.1+20181013-2 (testing)]
122)     libpam-elogind:i386 [241.1-1 (testing)]
123)     libpam0g:i386 [1.3.1-5 (testing)]
124)     libpaper1:i386 [1.1.26 (testing)]
125)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
126)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
127)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
128)     libprocps7:i386 [2:3.3.15-2 (testing)]
129)     policykit-1:i386 [0.105-25+devuan1 (testing)]
130)     procps:i386 [2:3.3.15-2 (testing)]
131)     tightvncserver [1:1.3.9-9 (testing)]
132)     atril recommends gvfs
133)     caja recommends gvfs-backends
134)     caja-eiciel recommends caja
135)     cups recommends colord
136)     cups-filters recommends colord
137)     engrampa recommends gvfs
138)     gvfs-common recommends gvfs
139)     libopenal1 recommends libpulse0 (>= 0.99.1)
140)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
141)     libsane recommends sane-utils (>= 1.0.27-3.2)
142)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
143)     libwine recommends libasound2-plugins
144)     lightdm recommends xserver-xorg
145)     linux-image-4.19.0-4-amd64 recommends irqbalance
146)     mate-desktop-environment recommends mate-media (>= 1.20)
147)     mate-desktop-environment-extras recommends blueman
148)     mate-session-manager recommends mate-panel
149)     mate-session-manager recommends mate-polkit
150)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
151)     mozo recommends mate-panel
152)     samba-common recommends samba-common-bin
153)     system-config-printer-common recommends cups-pk-helper
154)     system-config-printer-common recommends python3-smbc
155)     totem recommends gstreamer1.0-plugins-bad
156)     totem recommends gstreamer1.0-pulseaudio
157)     cups-daemon:i386 recommends colord:i386
158)     virtualbox-6.0 recommends libpulse0
10)      cups-daemon [2.2.10-6 (now, testing)]
11)      cups-pk-helper [0.2.6-1+b1 (now, testing)]
12)      dmeventd [2:1.02.155-2 (now, testing)]
13)      elogind [239.3+20190131-1 (now)]
14)      gimp [2.10.8-2 (now, testing)]
15)      gir1.2-polkit-1.0 [0.105-25+devuan1 (now, testing)]
16)      gnome-disk-utility [3.30.2-3 (now, testing)]
17)      gnome-system-tools [3.0.0-8 (now, testing)]
18)      gstreamer1.0-plugins-bad [1.14.4-1+b1 (now, testing)]
19)      gstreamer1.0-pulseaudio [1.14.4-1 (now, testing)]
20)      gvfs [1.38.1-3 (now, testing)]
21)      gvfs-backends [1.38.1-3 (now, testing)]
22)      gvfs-daemons [1.38.1-3 (now, testing)]
23)      irqbalance [1.5.0-3 (now, testing)]
24)      libaccountsservice0 [0.6.45-2 (now, testing)]
25)      libasound2-plugins [1.1.8-1 (now, testing)]
26)      libelogind0 [239.3+20190131-1 (now)]
27)      libfluidsynth1 [1.1.11-1 (now, testing)]
28)      libgegl-0.4-0 [0.4.12-2 (now, testing)]
29)      libgimp2.0 [2.10.8-2 (now, testing)]
30)      liblvm2cmd2.03 [2.03.02-2 (now, testing)]
31)      libmatemixer0 [1.20.1-1 (now, testing)]
32)      liboobs-1-5 [3.0.0-4 (now, testing)]
33)      libpam-elogind [239.3+20190131-1 (now)]
34)      libpolkit-agent-1-0 [0.105-25+devuan1 (now, testing)]
35)      libpolkit-backend-1-0 [0.105-25+devuan1 (now, testing)]
36)      libpolkit-backend-elogind-1-0 [0.105-25+devuan1 (now, testing)]
37)      libpolkit-gobject-1-0 [0.105-25+devuan1 (now, testing)]
38)      libpolkit-gobject-elogind-1-0 [0.105-25+devuan1 (now, testing)]
39)      libprocps7 [2:3.3.15-2 (now, testing)]
40)      libpulse-mainloop-glib0 [12.2-4 (now, testing)]
41)      libpulse0 [12.2-4 (now, testing)]
42)      libpulsedsp [12.2-4 (now, testing)]
43)      libsdl-image1.2 [1.2.12-10 (now, testing)]
44)      libsdl1.2debian [1.2.15+dfsg2-4 (now, testing)]
45)      libsdl2-2.0-0 [2.0.9+dfsg1-1 (now, testing)]
46)      libsmbclient [2:4.9.5+dfsg-3 (now, testing)]
47)      libsystemd0 [241-3 (now, testing)]
48)      libsystemd0:i386 [241-3 (now, testing)]
49)      libwine [4.0-1 (now, testing)]
50)      lvm2 [2.03.02-2 (now, testing)]
51)      mate-control-center [1.20.4-2 (now, testing)]
52)      mate-desktop-environment [1.20.0+5 (now, testing)]
53)      mate-desktop-environment-core [1.20.0+5 (now, testing)]
54)      mate-desktop-environment-extra [1.20.0+5 (now, testing)]
55)      mate-desktop-environment-extras [1.20.0+5 (now, testing)]
56)      mate-indicator-applet [1.20.1-1 (now, testing)]
57)      mate-media [1.20.2-1 (now, testing)]
58)      mate-panel [1.20.5-1 (now, testing)]
59)      mate-polkit [1.20.2-1 (now, testing)]
60)      mate-screensaver [1.20.3-3 (now, testing)]
61)      mate-session-manager [1.20.2-1 (now, testing)]
62)      mate-settings-daemon [1.20.4-1 (now, testing)]
63)      mate-system-monitor [1.20.2-1 (now, testing)]
64)      mate-tweak [18.10.2-1 (now, testing)]
65)      nautilus-extension-brasero [3.12.2-5 (now, testing)]
66)      nfs-common [1:1.3.4-2.5 (now, testing)]
67)      packagekit [1.1.12-5 (now, testing)]
68)      packagekit-tools [1.1.12-5 (now, testing)]
69)      policykit-1 [0.105-25+devuan1 (now, testing)]
70)      procps [2:3.3.15-2 (now, testing)]
71)      pulseaudio [12.2-4 (now, testing)]
72)      pulseaudio-module-bluetooth [12.2-4 (now, testing)]
73)      pulseaudio-utils [12.2-4 (now, testing)]
74)      python-samba [2:4.9.5+dfsg-3 (now, testing)]
75)      python3-smbc [1.0.15.6-1+b2 (now, testing)]
76)      rpcbind [1.2.5-0.3 (now, testing)]
77)      rsyslog [8.1901.0-1 (now, testing)]
78)      samba-common-bin [2:4.9.5+dfsg-3 (now, testing)]
79)      samba-dsdb-modules [2:4.9.5+dfsg-3 (now, testing)]
80)      samba-libs [2:4.9.5+dfsg-3 (now, testing)]
81)      sane-utils [1.0.27-3.2 (now, testing)]
82)      smbclient [2:4.9.5+dfsg-3 (now, testing)]
83)      system-config-printer [1.5.11-4 (now, testing)]
84)      system-tools-backends [2.10.2-3+b1 (now, testing)]
85)      udisks2 [2.8.1-4 (now, testing)]
86)      virtualbox-6.0 [6.0.4-128413~Ubuntu~bionic (now)]
87)      vlc [3.0.6-1 (now, testing)]
88)      vlc-plugin-base [3.0.6-1 (now, testing)]
89)      vlc-plugin-samba [3.0.6-1 (now, testing)]
90)      winbind [2:4.9.5+dfsg-3 (now, testing)]
91)      wine64 [4.0-1 (now, testing)]
92)      xorg [1:7.7+19 (now, testing)]
93)      xserver-xorg [1:7.7+19 (now, testing)]
94)      xserver-xorg-core [2:1.20.3-1 (now, testing)]
95)      xserver-xorg-input-all [1:7.7+19 (now, testing)]
96)      xserver-xorg-input-libinput [0.28.2-2 (now, testing)]
97)      xserver-xorg-input-wacom [0.34.99.1-1 (now, testing)]
98)      xserver-xorg-video-all [1:7.7+19 (now, testing)]
99)      xserver-xorg-video-amdgpu [18.1.99+git20190207-1 (now, testing)]
100)     xserver-xorg-video-ati [1:18.1.99+git20190207-1 (now, testing)]
101)     xserver-xorg-video-fbdev [1:0.5.0-1 (now, testing)]
102)     xserver-xorg-video-intel [2:2.99.917+git20180925-2 (now, testing)]
103)     xserver-xorg-video-nouveau [1:1.0.16-1 (now, testing)]
104)     xserver-xorg-video-qxl [0.1.5-2+b1 (now, testing)]
105)     xserver-xorg-video-radeon [1:18.1.99+git20190207-1 (now, testing)]
106)     xserver-xorg-video-vesa [1:2.4.0-1 (now, testing)]
107)     xserver-xorg-video-vmware [1:13.3.0-2 (now, testing)]
108)     cups-daemon:i386 [2.2.10-6 (testing)]
109)     elogind:i386 [241.1-1 (testing)]
110)     gstreamer1.0-alsa [1.14.4-1 (testing)]
111)     libacl1:i386 [2.2.53-4 (testing)]
112)     libattr1:i386 [1:2.4.48-4 (testing)]
113)     libaudit1:i386 [1:2.8.4-3 (testing)]
114)     libcap-ng0:i386 [0.7.9-2 (testing)]
115)     libelogind0:i386 [241.1-1 (testing)]
116)     libncursesw6:i386 [6.1+20181013-2 (testing)]
117)     libpam-elogind:i386 [241.1-1 (testing)]
118)     libpam0g:i386 [1.3.1-5 (testing)]
119)     libpaper1:i386 [1.1.26 (testing)]
120)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
121)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
122)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
123)     libprocps7:i386 [2:3.3.15-2 (testing)]
124)     policykit-1:i386 [0.105-25+devuan1 (testing)]
125)     procps:i386 [2:3.3.15-2 (testing)]
126)     tightvncserver [1:1.3.9-9 (testing)]
127)     atril recommends gvfs
128)     caja recommends gvfs-backends
129)     caja-eiciel recommends caja
130)     cups recommends colord
131)     cups-filters recommends colord
132)     engrampa recommends gvfs
133)     gvfs-common recommends gvfs
134)     libopenal1 recommends libpulse0 (>= 0.99.1)
135)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
136)     libsane recommends sane-utils (>= 1.0.27-3.2)
137)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
138)     libwine recommends libasound2-plugins
139)     lightdm recommends xserver-xorg
140)     linux-image-4.19.0-4-amd64 recommends irqbalance
141)     mate-desktop-environment recommends mate-media (>= 1.20)
142)     mate-desktop-environment-extras recommends blueman
143)     mate-session-manager recommends mate-panel
144)     mate-session-manager recommends mate-polkit
145)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
146)     mozo recommends mate-panel
147)     samba-common recommends samba-common-bin
148)     system-config-printer-common recommends cups-pk-helper
149)     system-config-printer-common recommends python3-smbc
150)     totem recommends gstreamer1.0-plugins-bad
151)     totem recommends gstreamer1.0-pulseaudio
152)     cups-daemon:i386 recommends colord:i386
153)     cups-daemon:i386 recommends cups-browsed:i386
open: 187; closed: 2620; defer: 68; conflict: 81        .The following actions will resolve these dependencies:
117)     libbz2-1.0:i386 [1.0.6-9 (testing)]
118)     libcap-ng0:i386 [0.7.9-2 (testing)]
119)     libelogind0:i386 [241.1-1 (testing)]
120)     libfontenc1:i386 [1:1.1.3-1+b2 (testing)]
124)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
125)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
126)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
127)     libprocps7:i386 [2:3.3.15-2 (testing)]
128)     libunwind8:i386 [1.2.1-9 (testing)]
129)     libxfont2:i386 [1:2.0.3-1 (testing)]
130)     policykit-1:i386 [0.105-25+devuan1 (testing)]
131)     procps:i386 [2:3.3.15-2 (testing)]
132)     xvfb:i386 [2:1.20.3-1 (testing)]
133)     atril recommends gvfs
134)     caja recommends gvfs-backends
135)     caja-eiciel recommends caja
136)     cups recommends colord
137)     cups-filters recommends colord
138)     engrampa recommends gvfs
139)     gvfs-common recommends gvfs
140)     libopenal1 recommends libpulse0 (>= 0.99.1)
141)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
142)     libsane recommends sane-utils (>= 1.0.27-3.2)
143)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
144)     libwine recommends libasound2-plugins
145)     lightdm recommends xserver-xorg
146)     linux-image-4.19.0-4-amd64 recommends irqbalance
147)     mate-desktop-environment recommends mate-media (>= 1.20)
148)     mate-desktop-environment-extras recommends blueman
149)     mate-session-manager recommends mate-panel
150)     mate-session-manager recommends mate-polkit
151)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
152)     mozo recommends mate-panel
153)     samba-common recommends samba-common-bin
154)     system-config-printer-common recommends cups-pk-helper
155)     system-config-printer-common recommends python3-smbc
156)     totem recommends gstreamer1.0-plugins-bad
157)     totem recommends gstreamer1.0-pulseaudio
open: 210; closed: 2791; defer: 78; conflict: 85        .The following actions will resolve these dependencies:
119)     libcupsfilters1:i386 [1.21.6-5 (testing)]
120)     libcupsimage2:i386 [2.2.10-6 (testing)]
121)     libelogind0:i386 [241.1-1 (testing)]
122)     libfontenc1:i386 [1:1.1.3-1+b2 (testing)]
123)     libncursesw6:i386 [6.1+20181013-2 (testing)]
124)     libpam-elogind:i386 [241.1-1 (testing)]
125)     libpam0g:i386 [1.3.1-5 (testing)]
126)     libpaper1:i386 [1.1.26 (testing)]
127)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
128)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
129)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
130)     libprocps7:i386 [2:3.3.15-2 (testing)]
131)     libunwind8:i386 [1.2.1-9 (testing)]
132)     libxfont2:i386 [1:2.0.3-1 (testing)]
133)     policykit-1:i386 [0.105-25+devuan1 (testing)]
134)     procps:i386 [2:3.3.15-2 (testing)]
135)     xvfb:i386 [2:1.20.3-1 (testing)]
136)     atril recommends gvfs
137)     caja recommends gvfs-backends
138)     caja-eiciel recommends caja
139)     cups recommends colord
140)     cups-filters recommends colord
141)     engrampa recommends gvfs
142)     gvfs-common recommends gvfs
143)     libopenal1 recommends libpulse0 (>= 0.99.1)
144)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
145)     libsane recommends sane-utils (>= 1.0.27-3.2)
146)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
147)     libwine recommends libasound2-plugins
148)     lightdm recommends xserver-xorg
149)     linux-image-4.19.0-4-amd64 recommends irqbalance
150)     mate-desktop-environment recommends mate-media (>= 1.20)
151)     mate-desktop-environment-extras recommends blueman
152)     mate-session-manager recommends mate-panel
153)     mate-session-manager recommends mate-polkit
154)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
155)     mozo recommends mate-panel
156)     samba-common recommends samba-common-bin
157)     system-config-printer-common recommends cups-pk-helper
158)     system-config-printer-common recommends python3-smbc
159)     totem recommends gstreamer1.0-plugins-bad
160)     totem recommends gstreamer1.0-pulseaudio
161)     cups-daemon:i386 recommends colord:i386
162)     virtualbox-6.0 recommends libpulse0
open: 222; closed: 2966; defer: 89; conflict: 88        .The following actions will resolve these dependencies:
116)     libcap-ng0:i386 [0.7.9-2 (testing)]
117)     libelogind0:i386 [241.1-1 (testing)]
118)     libncursesw6:i386 [6.1+20181013-2 (testing)]
119)     libpam-elogind:i386 [241.1-1 (testing)]
120)     libpam0g:i386 [1.3.1-5 (testing)]
121)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
122)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
123)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
124)     libprocps7:i386 [2:3.3.15-2 (testing)]
125)     policykit-1:i386 [0.105-25+devuan1 (testing)]
126)     procps:i386 [2:3.3.15-2 (testing)]
127)     tightvncserver [1:1.3.9-9 (testing)]
128)     atril recommends gvfs
129)     caja recommends gvfs-backends
130)     caja-eiciel recommends caja
131)     cups recommends colord
132)     cups-filters recommends colord
133)     engrampa recommends gvfs
134)     gvfs-common recommends gvfs
135)     libopenal1 recommends libpulse0 (>= 0.99.1)
136)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
137)     libsane recommends sane-utils (>= 1.0.27-3.2)
138)     libwebkit2gtk-4.0-37 recommends gstreamer1.0-pulseaudio | gstreamer1.0-alsa
open: 236; closed: 3162; defer: 94; conflict: 80        .The following actions will resolve these dependencies:
138)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
139)     libwine recommends libasound2-plugins
140)     lightdm recommends xserver-xorg
141)     linux-image-4.19.0-4-amd64 recommends irqbalance
142)     mate-desktop-environment recommends mate-media (>= 1.20)
143)     mate-desktop-environment-extras recommends blueman
144)     mate-session-manager recommends mate-panel
145)     mate-session-manager recommends mate-polkit
146)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
147)     mozo recommends mate-panel
148)     samba-common recommends samba-common-bin
149)     system-config-printer-common recommends cups-pk-helper
150)     system-config-printer-common recommends python3-smbc
151)     totem recommends gstreamer1.0-plugins-bad
152)     totem recommends gstreamer1.0-pulseaudio
153)     xinit recommends xserver-xorg | xserver
open: 240; closed: 3307; defer: 97; conflict: 81        .The following actions will resolve these dependencies:
112)     libacl1:i386 [2.2.53-4 (testing)]
113)     libattr1:i386 [1:2.4.48-4 (testing)]
114)     libaudit1:i386 [1:2.8.4-3 (testing)]
115)     libavahi-glib1:i386 [0.7-4+b1 (testing)]
117)     libcupsfilters1:i386 [1.21.6-5 (testing)]
118)     libcupsimage2:i386 [2.2.10-6 (testing)]
120)     libncursesw6:i386 [6.1+20181013-2 (testing)]
121)     libpam-elogind:i386 [241.1-1 (testing)]
122)     libpam0g:i386 [1.3.1-5 (testing)]
123)     libpaper1:i386 [1.1.26 (testing)]
128)     policykit-1:i386 [0.105-25+devuan1 (testing)]
129)     procps:i386 [2:3.3.15-2 (testing)]
130)     tightvncserver [1:1.3.9-9 (testing)]
131)     atril recommends gvfs
132)     caja recommends gvfs-backends
133)     caja-eiciel recommends caja
134)     cups recommends colord
135)     cups-filters recommends colord
136)     engrampa recommends gvfs
137)     gvfs-common recommends gvfs
138)     libopenal1 recommends libpulse0 (>= 0.99.1)
139)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
140)     libsane recommends sane-utils (>= 1.0.27-3.2)
141)     libwebkit2gtk-4.0-37 recommends gstreamer1.0-pulseaudio | gstreamer1.0-alsa
open: 249; closed: 3428; defer: 100; conflict: 84        .The following actions will resolve these dependencies:
141)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
142)     libwine recommends libasound2-plugins
143)     lightdm recommends xserver-xorg
144)     linux-image-4.19.0-4-amd64 recommends irqbalance
145)     mate-desktop-environment recommends mate-media (>= 1.20)
146)     mate-desktop-environment-extras recommends blueman
147)     mate-session-manager recommends mate-panel
148)     mate-session-manager recommends mate-polkit
149)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
150)     mozo recommends mate-panel
151)     samba-common recommends samba-common-bin
152)     system-config-printer-common recommends cups-pk-helper
153)     system-config-printer-common recommends python3-smbc
154)     totem recommends gstreamer1.0-plugins-bad
155)     totem recommends gstreamer1.0-pulseaudio
156)     xinit recommends xserver-xorg | xserver
open: 255; closed: 3575; defer: 103; conflict: 86        .The following actions will resolve these dependencies:
114)     libbz2-1.0:i386 [1.0.6-9 (testing)]
115)     libcap-ng0:i386 [0.7.9-2 (testing)]
116)     libelogind0:i386 [241.1-1 (testing)]
117)     libfontenc1:i386 [1:1.1.3-1+b2 (testing)]
121)     libpaper1:i386 [1.1.26 (testing)]
126)     libunwind8:i386 [1.2.1-9 (testing)]
127)     libxfont2:i386 [1:2.0.3-1 (testing)]
130)     xvfb:i386 [2:1.20.3-1 (testing)]
156)     cups-daemon:i386 recommends colord:i386
157)     cups-daemon:i386 recommends cups-browsed:i386
open: 259; closed: 3692; defer: 105; conflict: 88        .
71)      policykit-1 [0.105-25+devuan1 (now, testing)]
72)      printer-driver-gutenprint [5.3.1-7 (now, testing)]
73)      procps [2:3.3.15-2 (now, testing)]
74)      pulseaudio [12.2-4 (now, testing)]
75)      pulseaudio-module-bluetooth [12.2-4 (now, testing)]
76)      pulseaudio-utils [12.2-4 (now, testing)]
77)      python-samba [2:4.9.5+dfsg-3 (now, testing)]
78)      python3-smbc [1.0.15.6-1+b2 (now, testing)]
79)      rpcbind [1.2.5-0.3 (now, testing)]
80)      rsyslog [8.1901.0-1 (now, testing)]
81)      samba-common-bin [2:4.9.5+dfsg-3 (now, testing)]
82)      samba-dsdb-modules [2:4.9.5+dfsg-3 (now, testing)]
83)      samba-libs [2:4.9.5+dfsg-3 (now, testing)]
84)      sane-utils [1.0.27-3.2 (now, testing)]
85)      smbclient [2:4.9.5+dfsg-3 (now, testing)]
86)      system-config-printer [1.5.11-4 (now, testing)]
87)      system-tools-backends [2.10.2-3+b1 (now, testing)]
88)      udisks2 [2.8.1-4 (now, testing)]
89)      virtualbox-6.0 [6.0.4-128413~Ubuntu~bionic (now)]
90)      vlc [3.0.6-1 (now, testing)]
91)      vlc-plugin-base [3.0.6-1 (now, testing)]
92)      vlc-plugin-samba [3.0.6-1 (now, testing)]
93)      winbind [2:4.9.5+dfsg-3 (now, testing)]
94)      wine64 [4.0-1 (now, testing)]
95)      xorg [1:7.7+19 (now, testing)]
96)      xserver-xorg [1:7.7+19 (now, testing)]
97)      xserver-xorg-core [2:1.20.3-1 (now, testing)]
98)      xserver-xorg-input-all [1:7.7+19 (now, testing)]
99)      xserver-xorg-input-libinput [0.28.2-2 (now, testing)]
100)     xserver-xorg-input-wacom [0.34.99.1-1 (now, testing)]
101)     xserver-xorg-video-all [1:7.7+19 (now, testing)]
102)     xserver-xorg-video-amdgpu [18.1.99+git20190207-1 (now, testing)]
103)     xserver-xorg-video-ati [1:18.1.99+git20190207-1 (now, testing)]
104)     xserver-xorg-video-fbdev [1:0.5.0-1 (now, testing)]
105)     xserver-xorg-video-intel [2:2.99.917+git20180925-2 (now, testing)]
106)     xserver-xorg-video-nouveau [1:1.0.16-1 (now, testing)]
107)     xserver-xorg-video-qxl [0.1.5-2+b1 (now, testing)]
108)     xserver-xorg-video-radeon [1:18.1.99+git20190207-1 (now, testing)]
109)     xserver-xorg-video-vesa [1:2.4.0-1 (now, testing)]
110)     xserver-xorg-video-vmware [1:13.3.0-2 (now, testing)]
114)     libappstream4:i386 [0.12.5-1 (testing)]
115)     libapt-inst2.0:i386 [1.8.0 (testing)]
116)     libapt-pkg5.0:i386 [1.8.0 (testing)]
117)     libattr1:i386 [1:2.4.48-4 (testing)]
118)     libaudit1:i386 [1:2.8.4-3 (testing)]
119)     libbz2-1.0:i386 [1.0.6-9 (testing)]
120)     libcap-ng0:i386 [0.7.9-2 (testing)]
122)     libncursesw6:i386 [6.1+20181013-2 (testing)]
123)     libpackagekit-glib2-18:i386 [1.1.12-5 (testing)]
126)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
127)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
128)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
129)     libprocps7:i386 [2:3.3.15-2 (testing)]
130)     libsqlite3-0:i386 [3.27.2-2 (testing)]
131)     libstemmer0d:i386 [0+svn585-1+b2 (testing)]
132)     libyaml-0-2:i386 [0.2.1-1 (testing)]
133)     packagekit:i386 [1.1.12-5 (testing)]
134)     policykit-1:i386 [0.105-25+devuan1 (testing)]
135)     procps:i386 [2:3.3.15-2 (testing)]
136)     tightvncserver [1:1.3.9-9 (testing)]
137)     atril recommends gvfs
138)     caja recommends gvfs-backends
139)     caja-eiciel recommends caja
140)     cups recommends colord
141)     cups-filters recommends colord
142)     engrampa recommends gvfs
143)     gvfs-common recommends gvfs
144)     libopenal1 recommends libpulse0 (>= 0.99.1)
161)     libapt-pkg5.0:i386 recommends apt:i386 (>= 1.8.0)
open: 258; closed: 3827; defer: 108; conflict: 91        .
open: 260; closed: 3902; defer: 110; conflict: 93        oThe following actions will resolve these dependencies:
108)     cups-browsed:i386 [1.21.6-5 (testing)]
109)     cups-daemon:i386 [2.2.10-6 (testing)]
110)     elogind:i386 [241.1-1 (testing)]
111)     gstreamer1.0-alsa [1.14.4-1 (testing)]
113)     libappstream4:i386 [0.12.5-1 (testing)]
114)     libapt-inst2.0:i386 [1.8.0 (testing)]
115)     libapt-pkg5.0:i386 [1.8.0 (testing)]
116)     libattr1:i386 [1:2.4.48-4 (testing)]
117)     libaudit1:i386 [1:2.8.4-3 (testing)]
118)     libavahi-glib1:i386 [0.7-4+b1 (testing)]
121)     libcupsfilters1:i386 [1.21.6-5 (testing)]
122)     libcupsimage2:i386 [2.2.10-6 (testing)]
123)     libelogind0:i386 [241.1-1 (testing)]
124)     libncursesw6:i386 [6.1+20181013-2 (testing)]
125)     libpackagekit-glib2-18:i386 [1.1.12-5 (testing)]
126)     libpam-elogind:i386 [241.1-1 (testing)]
127)     libpam0g:i386 [1.3.1-5 (testing)]
128)     libpaper1:i386 [1.1.26 (testing)]
129)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
130)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
131)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
132)     libprocps7:i386 [2:3.3.15-2 (testing)]
133)     libsqlite3-0:i386 [3.27.2-2 (testing)]
134)     libstemmer0d:i386 [0+svn585-1+b2 (testing)]
135)     libyaml-0-2:i386 [0.2.1-1 (testing)]
136)     packagekit:i386 [1.1.12-5 (testing)]
137)     policykit-1:i386 [0.105-25+devuan1 (testing)]
138)     procps:i386 [2:3.3.15-2 (testing)]
139)     tightvncserver [1:1.3.9-9 (testing)]
140)     atril recommends gvfs
141)     caja recommends gvfs-backends
142)     caja-eiciel recommends caja
143)     cups recommends colord
144)     cups-filters recommends colord
145)     engrampa recommends gvfs
146)     gvfs-common recommends gvfs
147)     libopenal1 recommends libpulse0 (>= 0.99.1)
148)     libsane recommends sane-utils (>= 1.0.27-3.2)
149)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
150)     libwine recommends libasound2-plugins
151)     lightdm recommends xserver-xorg
152)     linux-image-4.19.0-4-amd64 recommends irqbalance
153)     mate-desktop-environment recommends mate-media (>= 1.20)
154)     mate-desktop-environment-extras recommends blueman
155)     mate-session-manager recommends mate-panel
156)     mate-session-manager recommends mate-polkit
157)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
158)     mozo recommends mate-panel
159)     samba-common recommends samba-common-bin
160)     system-config-printer-common recommends cups-pk-helper
161)     system-config-printer-common recommends python3-smbc
162)     totem recommends gstreamer1.0-plugins-bad
163)     totem recommends gstreamer1.0-pulseaudio
164)     cups-daemon:i386 recommends colord:i386
165)     libapt-pkg5.0:i386 recommends apt:i386 (>= 1.8.0)
166)     virtualbox-6.0 recommends libpulse0
open: 261; closed: 3979; defer: 112; conflict: 96        .
open: 266; closed: 4040; defer: 115; conflict: 99        oThe following actions will resolve these dependencies:
110)     libacl1:i386 [2.2.53-4 (testing)]
111)     libattr1:i386 [1:2.4.48-4 (testing)]
112)     libaudit1:i386 [1:2.8.4-3 (testing)]
113)     libcap-ng0:i386 [0.7.9-2 (testing)]
114)     libelogind0:i386 [241.1-1 (testing)]
115)     libncursesw6:i386 [6.1+20181013-2 (testing)]
116)     libpam-elogind:i386 [241.1-1 (testing)]
117)     libpam0g:i386 [1.3.1-5 (testing)]
118)     libpaper1:i386 [1.1.26 (testing)]
119)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
120)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
121)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
122)     libprocps7:i386 [2:3.3.15-2 (testing)]
123)     policykit-1:i386 [0.105-25+devuan1 (testing)]
124)     procps:i386 [2:3.3.15-2 (testing)]
125)     tightvncserver [1:1.3.9-9 (testing)]
126)     atril recommends gvfs
127)     caja recommends gvfs-backends
128)     caja-eiciel recommends caja
129)     cups recommends colord
130)     cups-filters recommends colord
131)     engrampa recommends gvfs
132)     gvfs-common recommends gvfs
133)     libopenal1 recommends libpulse0 (>= 0.99.1)
134)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
135)     libsane recommends sane-utils (>= 1.0.27-3.2)
136)     libwebkit2gtk-4.0-37 recommends gstreamer1.0-pulseaudio | gstreamer1.0-alsa
open: 269; closed: 4121; defer: 119; conflict: 103        .
open: 269; closed: 4182; defer: 121; conflict: 104        onThe following actions will resolve these dependencies:
136)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
137)     libwine recommends libasound2-plugins
138)     lightdm recommends xserver-xorg
139)     linux-image-4.19.0-4-amd64 recommends irqbalance
140)     mate-desktop-environment recommends mate-media (>= 1.20)
141)     mate-desktop-environment-extras recommends blueman
142)     mate-session-manager recommends mate-panel
143)     mate-session-manager recommends mate-polkit
144)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
145)     mozo recommends mate-panel
146)     samba-common recommends samba-common-bin
147)     system-config-printer-common recommends cups-pk-helper
148)     system-config-printer-common recommends python3-smbc
149)     totem recommends gstreamer1.0-plugins-bad
150)     totem recommends gstreamer1.0-pulseaudio
151)     xinit recommends xserver-xorg | xserver
open: 306; closed: 4267; defer: 122; conflict: 105        .The following actions will resolve these dependencies:
116)     libbz2-1.0:i386 [1.0.6-9 (testing)]
119)     libfontenc1:i386 [1:1.1.3-1+b2 (testing)]
123)     libpolkit-agent-1-0:i386 [0.105-25+devuan1 (testing)]
124)     libpolkit-backend-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
125)     libpolkit-gobject-elogind-1-0:i386 [0.105-25+devuan1 (testing)]
126)     libprocps7:i386 [2:3.3.15-2 (testing)]
127)     libunwind8:i386 [1.2.1-9 (testing)]
128)     libxfont2:i386 [1:2.0.3-1 (testing)]
131)     xvfb:i386 [2:1.20.3-1 (testing)]
142)     libwebkit2gtk-4.0-37 recommends gstreamer1.0-pulseaudio | gstreamer1.0-alsa
open: 326; closed: 4360; defer: 125; conflict: 108        .n
open: 335; closed: 4427; defer: 125; conflict: 108        oThe following actions will resolve these dependencies:
121)     libfontenc1:i386 [1:1.1.3-1+b2 (testing)]
123)     libpam-elogind:i386 [241.1-1 (testing)]
124)     libpam0g:i386 [1.3.1-5 (testing)]
125)     libpaper1:i386 [1.1.26 (testing)]
130)     libunwind8:i386 [1.2.1-9 (testing)]
131)     libxfont2:i386 [1:2.0.3-1 (testing)]
132)     policykit-1:i386 [0.105-25+devuan1 (testing)]
133)     procps:i386 [2:3.3.15-2 (testing)]
134)     xvfb:i386 [2:1.20.3-1 (testing)]
135)     atril recommends gvfs
136)     caja recommends gvfs-backends
137)     caja-eiciel recommends caja
138)     cups recommends colord
139)     cups-filters recommends colord
140)     engrampa recommends gvfs
141)     gvfs-common recommends gvfs
142)     libopenal1 recommends libpulse0 (>= 0.99.1)
143)     libpackagekit-glib2-18 recommends packagekit (= 1.1.12-5)
144)     libsane recommends sane-utils (>= 1.0.27-3.2)
145)     libwebkit2gtk-4.0-37 recommends gstreamer1.0-pulseaudio | gstreamer1.0-alsa
open: 354; closed: 4493; defer: 125; conflict: 108        .
open: 364; closed: 4545; defer: 125; conflict: 108        oThe following actions will resolve these dependencies:
124)     libpackagekit-glib2-18:i386 [1.1.12-5 (testing)]
125)     libpam-elogind:i386 [241.1-1 (testing)]
126)     libpam0g:i386 [1.3.1-5 (testing)]
131)     libsqlite3-0:i386 [3.27.2-2 (testing)]
132)     libstemmer0d:i386 [0+svn585-1+b2 (testing)]
133)     libunwind8:i386 [1.2.1-9 (testing)]
134)     libxfont2:i386 [1:2.0.3-1 (testing)]
139)     xvfb:i386 [2:1.20.3-1 (testing)]
164)     libapt-pkg5.0:i386 recommends apt:i386 (>= 1.8.0)
165)     virtualbox-6.0 recommends libpulse0
open: 382; closed: 4663; defer: 125; conflict: 108        o
137)     libwebkit2gtk-4.0-37 recommends gstreamer1.0-pulseaudio | gstreamer1.0-alsa
open: 399; closed: 4826; defer: 125; conflict: 108        OThe following actions will resolve these dependencies:
68)      policykit-1 [0.105-25+devuan1 (now, testing)]
69)      procps [2:3.3.15-2 (now, testing)]
70)      pulseaudio [12.2-4 (now, testing)]
71)      pulseaudio-module-bluetooth [12.2-4 (now, testing)]
72)      pulseaudio-utils [12.2-4 (now, testing)]
73)      python-samba [2:4.9.5+dfsg-3 (now, testing)]
74)      python3-smbc [1.0.15.6-1+b2 (now, testing)]
75)      rpcbind [1.2.5-0.3 (now, testing)]
76)      rsyslog [8.1901.0-1 (now, testing)]
77)      samba-common-bin [2:4.9.5+dfsg-3 (now, testing)]
78)      samba-dsdb-modules [2:4.9.5+dfsg-3 (now, testing)]
79)      samba-libs [2:4.9.5+dfsg-3 (now, testing)]
80)      sane-utils [1.0.27-3.2 (now, testing)]
81)      smbclient [2:4.9.5+dfsg-3 (now, testing)]
82)      system-config-printer [1.5.11-4 (now, testing)]
83)      system-tools-backends [2.10.2-3+b1 (now, testing)]
84)      udisks2 [2.8.1-4 (now, testing)]
85)      virtualbox-6.0 [6.0.4-128413~Ubuntu~bionic (now)]
86)      vlc [3.0.6-1 (now, testing)]
87)      vlc-plugin-base [3.0.6-1 (now, testing)]
88)      vlc-plugin-samba [3.0.6-1 (now, testing)]
89)      winbind [2:4.9.5+dfsg-3 (now, testing)]
90)      wine64 [4.0-1 (now, testing)]
91)      xorg [1:7.7+19 (now, testing)]
92)      xserver-xorg [1:7.7+19 (now, testing)]
93)      xserver-xorg-core [2:1.20.3-1 (now, testing)]
94)      xserver-xorg-input-all [1:7.7+19 (now, testing)]
95)      xserver-xorg-input-libinput [0.28.2-2 (now, testing)]
96)      xserver-xorg-input-wacom [0.34.99.1-1 (now, testing)]
97)      xserver-xorg-video-all [1:7.7+19 (now, testing)]
98)      xserver-xorg-video-amdgpu [18.1.99+git20190207-1 (now, testing)]
99)      xserver-xorg-video-ati [1:18.1.99+git20190207-1 (now, testing)]
100)     xserver-xorg-video-fbdev [1:0.5.0-1 (now, testing)]
101)     xserver-xorg-video-intel [2:2.99.917+git20180925-2 (now, testing)]
102)     xserver-xorg-video-nouveau [1:1.0.16-1 (now, testing)]
103)     xserver-xorg-video-qxl [0.1.5-2+b1 (now, testing)]
104)     xserver-xorg-video-radeon [1:18.1.99+git20190207-1 (now, testing)]
105)     xserver-xorg-video-vesa [1:2.4.0-1 (now, testing)]
106)     xserver-xorg-video-vmware [1:13.3.0-2 (now, testing)]
107)     cups-daemon:i386 [2.2.10-6 (testing)]
108)     elogind:i386 [241.1-1 (testing)]
109)     gstreamer1.0-alsa [1.14.4-1 (testing)]
111)     libappstream4:i386 [0.12.5-1 (testing)]
112)     libapt-inst2.0:i386 [1.8.0 (testing)]
113)     libapt-pkg5.0:i386 [1.8.0 (testing)]
120)     libpackagekit-glib2-18:i386 [1.1.12-5 (testing)]
128)     libsqlite3-0:i386 [3.27.2-2 (testing)]
129)     libstemmer0d:i386 [0+svn585-1+b2 (testing)]
130)     libyaml-0-2:i386 [0.2.1-1 (testing)]
131)     packagekit:i386 [1.1.12-5 (testing)]
134)     tightvncserver [1:1.3.9-9 (testing)]
       Leave the following dependencies unresolved:
143)     libsane recommends sane-utils (>= 1.0.27-3.2)
144)     libwine recommends libsdl2-2.0-0 (>= 2.0.8)
145)     libwine recommends libasound2-plugins
146)     lightdm recommends xserver-xorg
147)     linux-image-4.19.0-4-amd64 recommends irqbalance
148)     mate-desktop-environment recommends mate-media (>= 1.20)
149)     mate-desktop-environment-extras recommends blueman
150)     mate-session-manager recommends mate-panel
151)     mate-session-manager recommends mate-polkit
152)     mate-tweak recommends mate-indicator-applet (>= 1.18.0)
153)     mozo recommends mate-panel
154)     samba-common recommends samba-common-bin
155)     system-config-printer-common recommends cups-pk-helper
156)     system-config-printer-common recommends python3-smbc
157)     totem recommends gstreamer1.0-plugins-bad
158)     totem recommends gstreamer1.0-pulseaudio
159)     cups-daemon:i386 recommends colord:i386
160)     cups-daemon:i386 recommends cups-browsed:i386
Abort.
No reasonable solution suggested. Is there a reasonable solution? I tried an apt remove libsystemd0, tha wants to remove mate.
Rolf
#23 2019-05-01 17:17:01
sgage
Re: [Solved] Beowulf update holds back packages
I think the only solution, at least for me, is to wait until all the versioning gets reconciled. Something similar happened several months ago, and one day, it just worked - packages that had been held back for days and days finally had their dependencies fulfilled, and all was well.
# LC_ALL=C aptitude full-upgrade
  shim{u}
 libelogind0 : Conflicts: libsystemd0 but 241-3 is installed
     Keep the following packages at their current version:
1)     elogind [239.3+20190131-1 (now)]
2)     libelogind0 [239.3+20190131-1 (now)]
Accept this solution? [Y/n/q/?] n
      Remove the following packages:
1)      libasound2-plugins:i386 [1.1.8-1 (now, testing)]
2)      libpulse0:i386 [12.2-4 (now, testing)]
3)      libsdl2-2.0-0:i386 [2.0.9+dfsg1-1 (now, testing)]
6)      libwine:i386 [4.0-1 (now, testing)]
7)      wine32:i386 [4.0-1 (now, testing)]
1)      accountsservice [0.6.45-2 (now, testing)]
2)      brasero [3.12.2-5 (now, testing)]
3)      caja [1.20.3-1+b1 (now, testing)]
4)      caja-rename [18.7.28~bzr25-1 (now, testing)]
5)      caja-seahorse [1.18.4-2 (now, testing)]
6)      colord [1.4.3-3+devuan1 (now, testing)]
7)      cups-pk-helper [0.2.6-1+b1 (now, testing)]
10)     gnome-system-tools [3.0.0-8 (now, testing)]
11)     gvfs [1.38.1-3 (now, testing)]
12)     gvfs-backends [1.38.1-3 (now, testing)]
13)     gvfs-daemons [1.38.1-3 (now, testing)]
14)     liboobs-1-5 [3.0.0-4 (now, testing)]
15)     libpam-elogind [239.3+20190131-1 (now)]
16)     libpolkit-agent-1-0 [0.105-25+devuan1 (now, testing)]
17)     libpolkit-backend-1-0 [0.105-25+devuan1 (now, testing)]
18)     libpolkit-backend-elogind-1-0 [0.105-25+devuan1 (now, testing)]
19)     libpolkit-gobject-1-0 [0.105-25+devuan1 (now, testing)]
20)     libpolkit-gobject-elogind-1-0 [0.105-25+devuan1 (now, testing)]
21)     mate-control-center [1.20.4-2 (now, testing)]
22)     mate-desktop-environment [1.20.0+5 (now, testing)]
23)     mate-desktop-environment-core [1.20.0+5 (now, testing)]
24)     mate-desktop-environment-extra [1.20.0+5 (now, testing)]
25)     mate-desktop-environment-extras [1.20.0+5 (now, testing)]
26)     mate-indicator-applet [1.20.1-1 (now, testing)]
27)     mate-panel [1.20.5-1 (now, testing)]
28)     mate-polkit [1.20.2-1 (now, testing)]
29)     mate-settings-daemon [1.20.4-1 (now, testing)]
30)     mate-tweak [18.10.2-1 (now, testing)]
31)     nautilus-extension-brasero [3.12.2-5 (now, testing)]
32)     packagekit [1.1.12-5 (now, testing)]
33)     packagekit-tools [1.1.12-5 (now, testing)]
34)     policykit-1 [0.105-25+devuan1 (now, testing)]
36)     system-config-printer [1.5.11-4 (now, testing)]
37)     system-tools-backends [2.10.2-3+b1 (now, testing)]
38)     udisks2 [2.8.1-4 (now, testing)]
39)     elogind [239.3+20190131-1 (now)]
40)     libelogind0 [239.3+20190131-1 (now)]
Abort.
Rolf
#24 2019-05-01 17:36:25
Try apt-get install libelogind0=241.1-1 (Maybe need to do the same for elogind, too.) I'm guessing that there were some changes in dependencies in the interim versions of libelogind0 and you two are caught in some kind of twilight zone.
Another thing you (sgage) could try if the 250 packages are going to be set to autoremoval (as opposed to actually being removed) is to remove libsystemd0 and then install libelogind0 (even if it's already installed). Since libelogind0 Provides libsystemd0, all those packages that want lsd0 will be happy and will be taken off the autoremove list. Maybe.
#25 2019-05-01 19:45:23
This tries to remove my wine installation.
# LC_ALL=C apt install libelogind0=241.1-1
Building dependency tree
  gstreamer1.0-plugins-base:i386 i965-va-driver:i386 intel-media-va-driver:i386 libaom0:i386 libasound2:i386 libasyncns0:i386
  libatomic1:i386 libavahi-client3:i386 libavahi-common-data:i386 libavahi-common3:i386 libavcodec58:i386 libavresample4:i386
  libavutil56:i386 libblkid1:i386 libbsd0:i386 libcairo2:i386 libcap2:i386 libcapi20-3:i386 libcdparanoia0:i386
  libcodec2-0.8.1:i386 libcroco3:i386 libcrystalhd3:i386 libcups2:i386 libdatrie1:i386 libdb5.3:i386 libdbus-1-3:i386
  libdrm-amdgpu1:i386 libdrm-intel1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386 libelf1:i386
  libeudev1:i386 libexif12:i386 libexpat1:i386 libflac8:i386 libfontconfig1:i386 libfreetype6:i386 libfribidi0:i386 libgd3:i386
  libgdk-pixbuf2.0-0:i386 libgl1:i386 libgl1-mesa-dri:i386 libglapi-mesa:i386 libglib2.0-0:i386 libglu1-mesa:i386 libglvnd0:i386
  libglx-mesa0:i386 libglx0:i386 libgnutls30:i386 libgomp1:i386 libgphoto2-6:i386 libgphoto2-port12:i386 libgpm2:i386
  libgraphite2-3:i386 libgsm1:i386 libgssapi-krb5-2:i386 libgstreamer-plugins-base1.0-0:i386 libgstreamer1.0-0:i386
  libharfbuzz0b:i386 libhogweed4:i386 libice6:i386 libicu63:i386 libigdgmm5:i386 libjack-jackd2-0:i386 libjbig0:i386
  libjpeg62-turbo:i386 libk5crypto3:i386 libkeyutils1:i386 libkrb5-3:i386 libkrb5support0:i386 liblcms2-2:i386 libldap-2.4-2:i386
  libllvm7:i386 libltdl7:i386 libmount1:i386 libmp3lame0:i386 libmpg123-0:i386 libncurses6:i386 libnettle6:i386 libnuma1:i386
  libodbc1:i386 libogg0:i386 libopenal1:i386 libopenjp2-7:i386 libopus0:i386 liborc-0.4-0:i386 libosmesa6:i386 libp11-kit0:i386
  libpango-1.0-0:i386 libpangocairo-1.0-0:i386 libpangoft2-1.0-0:i386 libpcap0.8:i386 libpciaccess0:i386 libpixman-1-0:i386
  libpng16-16:i386 librsvg2-2:i386 librsvg2-common:i386 libsamplerate0:i386 libsasl2-2:i386 libsasl2-modules:i386
  libsasl2-modules-db:i386 libsensors5:i386 libshine3:i386 libsm6:i386 libsnappy1v5:i386 libsndfile1:i386 libsndio7.0:i386
  libsoxr0:i386 libspeex1:i386 libssl1.1:i386 libswresample3:i386 libtasn1-6:i386 libthai0:i386 libtheora0:i386 libtiff5:i386
  libtinfo6:i386 libtwolame0:i386 libudev1:i386 libusb-1.0-0:i386 libuuid1:i386 libv4l-0:i386 libv4lconvert0:i386 libva-drm2:i386
  libva-x11-2:i386 libva2:i386 libvdpau-va-gl1:i386 libvdpau1:i386 libvisual-0.4-0:i386 libvkd3d1:i386 libvorbis0a:i386
  libvorbisenc2:i386 libvpx5:i386 libvulkan1:i386 libwavpack1:i386 libwayland-client0:i386 libwayland-cursor0:i386
  libwayland-egl1:i386 libwebp6:i386 libwebpmux3:i386 libwrap0:i386 libx11-6:i386 libx11-xcb1:i386 libx264-155:i386
  libx265-165:i386 libxau6:i386 libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386 libxcb-render0:i386
  libxcb-shm0:i386 libxcb-sync1:i386 libxcb-xfixes0:i386 libxcb1:i386 libxcomposite1:i386 libxcursor1:i386 libxdamage1:i386
  libxdmcp6:i386 libxext6:i386 libxfixes3:i386 libxi6:i386 libxinerama1:i386 libxkbcommon0:i386 libxml2:i386 libxpm4:i386
  libxrandr2:i386 libxrender1:i386 libxshmfence1:i386 libxslt1.1:i386 libxss1:i386 libxtst6:i386 libxvidcore4:i386
  libxxf86vm1:i386 libzstd1:i386 libzvbi0:i386 mesa-va-drivers:i386 mesa-vdpau-drivers:i386 ocl-icd-libopencl1:i386
  va-driver-all:i386 vdpau-driver-all:i386
Use 'apt autoremove' to remove them.
  elogind libpam-elogind
  libasound2-plugins:i386 libpulse0:i386 libsdl2-2.0-0:i386 libsystemd0 libsystemd0:i386 libwine:i386 wine32:i386
  elogind libelogind0 libpam-elogind
3 upgraded, 0 newly installed, 7 to remove and 1 not upgraded.
Need to get 1042 kB of archives.
After this operation, 217 MB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
Shall I risk this and re-install wine afterwards?
Rolf
