#1 2019-03-29 18:14:44
UnclePa
Problem with Steam
A friend asked me to try something in Steam.  I have no experience with it but installed it.  When I try to run it, I get the following.  Any ideas on what the problem is?
/home/_/.steam/steam.sh: line 106: VERSION_ID: unbound variable
rm: cannot remove '/home/_/.steam/steam': Is a directory
rm: cannot remove '/home/_/.steam/bin': Is a directory
Installing breakpad exception handler for appid(steam)/version(1550534751)
Steam: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
Major opcode of failed request:  20 (X_GetProperty)
Value in failed request:  0x20
Serial number of failed request:  87
xerror_handler: X failed, continuing
[0329/124941.920716:INFO:crash_reporting.cc(242)] Crash reporting enabled for process: browser
CAppInfoCacheReadFromDiskThread took 0 milliseconds to initialize
CApplicationManagerPopulateThread took 0 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
[0329/124941.954516:WARNING:crash_reporting.cc(281)] Failed to set crash key: UserID with value: 0
[0329/124941.954611:WARNING:crash_reporting.cc(281)] Failed to set crash key: BuildID with value: 1550527787
[0329/124941.954621:WARNING:crash_reporting.cc(281)] Failed to set crash key: SteamUniverse with value: Public
[0329/124941.954630:WARNING:crash_reporting.cc(281)] Failed to set crash key: Vendor with value: Valve
[0329/124941.961388:ERROR:gpu_process_transport_factory.cc(1026)] Lost UI shared context.
** (steam:8745): WARNING **: Could not initialize NMClient /org/freedesktop/NetworkManager: The name org.freedesktop.NetworkManager was not provided by any .service files
Serial number of failed request:  143
Serial number of failed request:  177
Opted-in Controller Mask for AppId 0: 0
Serial number of failed request:  205
Serial number of failed request:  318
(steam:8745): Gtk-WARNING **: gtk_disable_setlocale() must be called before gtk_init()
roaming config store loaded successfully - 0 bytes.
Serial number of failed request:  466
Serial number of failed request:  497
Serial number of failed request:  526
Serial number of failed request:  556
Serial number of failed request:  561
[0329/124956.597151:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
Serial number of failed request:  591
Serial number of failed request:  622
Serial number of failed request:  674
[0329/124956.629656:WARNING:crash_reporting.cc(281)] Failed to set crash key: UserID with value: 0
[0329/124956.629754:WARNING:crash_reporting.cc(281)] Failed to set crash key: BuildID with value: 1550527787
[0329/124956.629764:WARNING:crash_reporting.cc(281)] Failed to set crash key: SteamUniverse with value: Public
[0329/124956.629773:WARNING:crash_reporting.cc(281)] Failed to set crash key: Vendor with value: Valve
[0329/124956.630827:INFO:crash_reporting.cc(242)] Crash reporting enabled for process: gpu-process
Serial number of failed request:  719
Serial number of failed request:  725
Serial number of failed request:  732
Serial number of failed request:  737
Serial number of failed request:  768
Serial number of failed request:  799
Serial number of failed request:  828
Serial number of failed request:  858
Serial number of failed request:  892
Serial number of failed request:  946
Serial number of failed request:  1151
Serial number of failed request:  1185
Serial number of failed request:  1213
Serial number of failed request:  1241
Serial number of failed request:  1269
Serial number of failed request:  1297
Serial number of failed request:  1325
Serial number of failed request:  1353
Serial number of failed request:  1381
Serial number of failed request:  1409
Serial number of failed request:  1437
Serial number of failed request:  1445
Serial number of failed request:  1450
Serial number of failed request:  1455
Serial number of failed request:  1460
Failed to init SteamVR because it isn't installed
Serial number of failed request:  1467
assert_20190329124940_1.dmp[8847]: Uploading dump (out-of-process)
/tmp/dumps/assert_20190329124940_1.dmp
/home/_/.steam/steam.sh: line 889:  8745 Segmentation fault      $STEAM_DEBUGGER "$STEAMROOT/$STEAMEXEPATH" "$@"
[0329/124957.416539:INFO:crash_reporting.cc(265)] Crash reporting enabled for process: renderer
assert_20190329124940_1.dmp[8847]: Finished uploading minidump (out-of-process): success = yes
assert_20190329124940_1.dmp[8847]: response: CrashID=bp-49709141-6880-4cab-9cbf-9b5722190329
assert_20190329124940_1.dmp[8847]: file ''/tmp/dumps/assert_20190329124940_1.dmp'', upload yes: ''CrashID=bp-49709141-6880-4cab-9cbf-9b5722190329''
#2 2019-03-29 19:10:10
Re: Problem with Steam
Please list the commands you used to install Steam.
Have you installed the 32-bit version of the mesa-utils package?
Can you run
glxinfo
or
glxgears
https://github.com/ValveSoftware/steam- … ssues/4909
Fabricando fit faber
#3 2019-03-29 19:38:07
UnclePa
Thanks for the reply.  I installed it using synaptic.  I don't remember what dependencies it brought in.  glxinfo and glxgears run fine.  I have a few 3D wine games that I run.  I don't want to install 32-bit mesa-utils because it wants to uninstall my normal mesa-utils.  I don't want to break anything I have.
Thanks for the link.  Rebooting is a non-trivial task for me.  Maybe I should try it on my laptop but it's AMD and pretty pathetic on some games.
#4 2019-03-29 19:54:01
Have you installed the 32-bit OpenGL libraries for your video card?
See the note on the Debian wiki page:
Debian wiki wrote:
Installing the 32-bit OpenGL libraries may uninstall the 64-bit drivers you may have previously installed. Installing the AMD graphics or NVIDIA graphics drivers for your system is recommended. The appropriate OpenGL library will be installed along with those drivers.
https://wiki.debian.org/Steam#A64-bit_s … 28amd64.29
Probably better to follow the instructions on that page rather than rely on synaptic.
#5 2019-03-29 21:57:06
UnclePa
Thanks again.  I think I'll try this on my laptop first later tonight.
