#1 2019-03-25 19:23:39
fabien
Ncurses
Hello!
I am trying to learn a bit C (only for fun), and I wrote a little code with ncurses.
It works on FreeBSD, but I can't run it on DEVUAN.
libncurses5-dev and libncursesw5-dev are installed, the program compile just fine but nothing shows up in the terminal.
Is somebody knows what I am talking about?
Merci.
Fabien
#2 2019-03-30 21:22:54
fabien
Re: Ncurses
Sorry to insist, nobody?
#3 2019-03-30 21:57:32
dxrobertson
Re: Ncurses
I have no experience with ncurses.
You say "the program compile just fine", just to make sure - you did compile it on Devuan?
How are you running it, from a terminal?  Are any error messages displayed in the terminal?
If you are sure its running, and there are no errors anywhere, then I would add printf's in your code to see where your program is at runtime:
printf("HERE 1.\n");
printf("HERE 2.\n");
#4 2019-03-30 21:58:18
Re: Ncurses
You do know how to leave an audience guessing wink
Perhaps you should test the waters at the freenode IRC #devuan as well, to increase the chances of running into someone else doing C with ncurses on both freebsd and devuan. It might be a more select group than this one.
#5 2019-03-30 22:11:17
fabien
Re: Ncurses
Hi, i did compile it on Devuan using Geany.
There is no error message.
I will try your tip, thank you! I should of do it already, i am afraid i am a bit slow  smile
Thank you!
#6 2019-03-30 22:16:24
fabien
Re: Ncurses
I hope I wasn't rude.
Thank you I will try that too smile
#7 2019-03-30 22:42:50
yeti
Re: Ncurses
Where is the code?
#8 2019-03-30 23:03:51
fabien
Re: Ncurses
Thank you for helping.
#include <time.h>
#include <ncurses.h>
WINDOW *create_newwin(int h, int l, int y, int x)
{	WINDOW *local_win;
	local_win = newwin(h, l, y, x);
	box(local_win, 0 , 0);
	wrefresh(local_win);
	return local_win;
int main(int argc, char **argv)
	WINDOW *win;
	int x, y, h, l;                          // window
	int px, py;								 // chicken
	int v1x;								 // car 1
	int ch, top = 0;
	initscr();
	cbreak();
	keypad(stdscr, TRUE);
	nodelay(stdscr, TRUE);
	curs_set(0);
	h = 30;
	l = 60 ;
	y = (LINES - h) / 2;
	x = (COLS - l) / 2;
	py = 1;
	px = 30;
	v1x = 1;
	while ((ch = getch()) != 'q' && (py != 10 || px != v1x)){
		if (clock() > top + 10){
			top = clock();
			win = create_newwin(h, l, y, x);  // car crossing the window
			mvwhline(win, 10, 1, '.', 58);
			mvwaddch(win, 10, v1x, 'V');
			v1x++;
			if (v1x > 58)
				v1x = 1;
		switch(ch){                            // chicken moves
			case KEY_LEFT:
				px--;
				break;
			case KEY_RIGHT:
				px++;
				break;
			case KEY_UP:
				py--;
				break;
			case KEY_DOWN:
				py++;
				break;
		mvwaddch(win, py, px,'P');
		wrefresh(win);
		mvwaddch(win, py, px,' ');
	endwin();
	return 0;
#9 2019-03-30 23:21:27
yeti
Re: Ncurses
~/tmp4c$ cat /etc/devuan_version
ascii
~/tmp4c$ ls -l
total 4
-rw-r--r-- 1 yeti yeti 1293 Mar 30 23:05 main.c
~/tmp4c$ gcc main.c -lncurses -o main
~/tmp4c$ ls -l
total 16
-rwxr-xr-x 1 yeti yeti 9216 Mar 30 23:14 main
It compiles without errors.
Started with
~/tmp4c$ ./main
it runs and I can move the P with the arrow keys.
#10 2019-04-01 06:24:46
fabien
Re: Ncurses
Ah...
Thank you, I will check that.
