#1 2019-03-23 04:03:06
Job
ssh with a file manager???
Is it possible to browse files on another box with a file manager using ssh?  If not what are the alternatives.
Thanks
#2 2019-03-23 04:27:19
Re: ssh with a file manager???
You might like to use sshfs, which lets you mount the remote file system as if a local directory tree. Then you can can browse them with your local file manager.
#3 2019-03-23 09:17:58
PedroReina
Midnight Commander can do it.
#4 2019-03-23 12:04:43
kuleszdl
This depends on the file manager and desktop you are using. In KDE's dolphin you can use fish://user@host:/path/to/directory as URL. However, I also find sshfs-connections more reliable and you don't get annoying popups each time you download/upload a file.
#5 2019-03-23 13:27:43
Job
I appreciate the inputs.  Thanks.  I thought I will have to use vnc like the good people of FreeBSD.
