#1 2019-03-13 09:54:47
RIA77
Microsoft TTF fonts
Hello to all memebers of the forum!
I want to install microsoft ttf fonts.
I tried to install on the same way that I did on Debian, by running .deb file, but it seems that nothing happened.
I have been using XFCE.
Can anyone help ?
Thank you.
#2 2019-03-13 10:35:55
ToxicExMachina
Re: Microsoft TTF fonts
The way is absolutely same as in Debian.
For example, you can install it using contrib section of repository:
apt-get install ttf-mscorefonts-installer
#3 2019-03-17 21:37:59
RIA77
I installed it manually, apt-get was not working at all. It was information that ttf could not be found. Thank you.
#4 2019-03-18 13:45:51
Ogis1975
Hello.  Microsoft TTF fonts is in contrib section. You must edit your source list file.
