#1 2019-03-12 00:47:17
seeker
Root terminal without password
I have installed (I think) Devuan Ascii with LXQT and sddm. Whenever I start a root terminal, it launches without prompting for a password. a dialog says that my system is configured to do this. Does anyone know how to force it to request a password? Other applications, like Synaptic Package Manager do prompt for the root credentials.
#2 2019-03-12 18:40:33
Re: Root terminal without password
Are you sure you get a root terminal? Or is the prompt more like this one:
username@computername:~$
Rolf
#3 2019-03-13 15:45:08
PedroReina
Good question. Try also the command whoami
