#1 2019-03-04 16:03:33
sudo.log: read only file system
In order to overcome (ie: eventually diagnose and maybe solve) a shutdown problem I have with my Sun Ultra 24 rig, I am currently shutting down with a script instead of the Xfce shutdown button (which calls the shutdown helper executable):
groucho@devuan:~$ cat /usr/bin/magicdown.sh
# Shutdown system without the use of shutdownhelper
for i in s u o; do echo $i | sudo tee /proc/sysrq-trigger; sleep 6; done  # halt
groucho@devuan:~$
In order to make it as easy to use as possible and also see what's going on, I launch it in terminal via a *.desktop file:
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name=shutdown
Comment=Shuts down system bypassing shutdown helper
Exec=xfce4-terminal -x sudo /usr/bin/magicdown.sh
Icon=/usr/share/icons/gnome/32x32/actions/gnome-shutdown.png
Terminal=false
Path=
StartupNotify=false
GenericName=Shutdown
What I get on the terminal screen goes by too fast but with a video taken with a cell phone I could get a glimpse:
s
u
sudo: unable to open log file: /var/log/sudo.log: read only file system
o
I have a properly configured sudoers.d file that allows me to use the executable script:
[root@devuan groucho]# visudo -c
/etc/sudoers: parsed OK
/etc/sudoers.d/README: parsed OK
/etc/sudoers.d/user_dmesg: parsed OK
/etc/sudoers.d/user_linssid: parsed OK
/etc/sudoers.d/user_modprobe: parsed OK
/etc/sudoers.d/user_rescan: parsed OK
/etc/sudoers.d/user_shutdown: parsed OK
/etc/sudoers.d/user_updatedb: parsed OK
[root@devuan groucho]# cat /etc/sudoers.d/user_shutdown
groucho ALL= NOPASSWD: /sbin/halt, /sbin/shutdown, /sbin/reboot, /usr/bin/magicdown.sh
What I don't understand is not being able to open sudo.log as root.
Is there something wrong with the script?
#2 2019-03-04 17:45:01
Re: sudo.log: read only file system
Observation: you haven't set a path in the script.
2nd guess: trying to write a log during shutdown might not work.
Regards, Rolf
#3 2019-03-04 19:07:01
rolfie wrote:
Observation: you haven't set a path ...
No, that's not it.
It seems the path is set in the environment variables.
groucho@devuan:~$ echo $PATH
/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
groucho@devuan:~$
I can run the script directly from the prompt with or without sudo.
With sudo it executes directly (because sudoers) without, it asks me for the PW twice.
rolfie wrote:
... trying to write a log during shutdown might not work.
Seems that's it.  =-)
From https://it.toolbox.com/question/file-sy … ode-061114
The filesystem will usually go into read-only while the system is running if ...
... an emergency read-only remount is requested via Alt+SysRq+U.
So it is normal that sudo cannot write to it's log file after U is called.
Thanks for your input.
#4 2019-03-05 18:51:00
No, that's not it.
groucho@devuan:~$
Unfortunately, that won't work. This is the path valid in your home only. Starting a shell requires setting path in the shell script or to use the full path to any command. Example from one of my scripts:
PATH=/sbin:/bin:/usr/sbin:/usr/bin:
Rolf
#5 2019-03-06 11:24:05
rolfie wrote:
... that won't work. This is the path valid in your home only.
I understand (from my old DOS days) the importance and need for setting the PATH variable in a script.
But my *.bat days are long gone and I have no bash skills worth mentioning.
Undoubtedly, it is best practise to do so.
But this script works and has the same result whether I add the line you suggested to it or not.
I expect it is so because it (the needed PATH) is already set elsewhere:
groucho@devuan:~$ printenv | grep -i path
GLADE_CATALOG_PATH=:
GLADE_MODULE_PATH=:
GLADE_PIXMAP_PATH=:
PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
groucho@devuan:~$
In any case, I will start adding the PATH to every script I attempt to write.
