#1 2019-03-02 03:06:49
bgstack15
[SOLVED] xscreensaver works but prompt has no text
devuan ceres amd64, from a netinst. I did not select the desktop package in the install screen, and I use apt-get to select lightdm, fluxbox, etc.
I am running fluxbox and xscreensaver. Xscreensaver operates, and shows me the username and the asterisks for the password entry. However, the prompt has no text. Even the buttons have no text!
link to image from my phone
I ran the daemon with -log and -verbose.
xscreensaver: 21:38:27: logging to "/home/bgstack15-local/log/xscreen1" at Fri Mar  1 21:38:27 2019
xscreensaver 5.42, copyright (c) 1991-2018 by Jamie Zawinski <jwz@jwz.org>.
xscreensaver: 21:38:27: running as bgstack15-local/bgstack15-local (1000/1000)
xscreensaver: 21:38:27: in process 3904.
xscreensaver: 21:38:27: running on display ":0.0"
xscreensaver: 21:38:27: vendor is The X.Org Foundation, 12003000.
xscreensaver: 21:38:27: useful extensions:
xscreensaver: 21:38:27:   MIT Screen-Saver (disabled at compile time)
xscreensaver: 21:38:27:   Shared Memory (1.2)
xscreensaver: 21:38:27:   Double-Buffering (1.0)
xscreensaver: 21:38:27:   Power Management (1.1)
xscreensaver: 21:38:27:   GLX
xscreensaver: 21:38:27:   XF86 Video-Mode (2.2)
xscreensaver: 21:38:27:   XC Misc (disabled at compile time)
xscreensaver: 21:38:27:   Xinerama (1.1)
xscreensaver: 21:38:27:   Resize-and-Rotate (1.5)
xscreensaver: 21:38:27:   XInput
xscreensaver: 21:38:27: screen 0 non-colormapped depths: 24.
xscreensaver: 21:38:27: WARNING: RANDR and Xinerama report different
xscreensaver: 21:38:27:                 screen layouts!  Believing RANDR.
xscreensaver: 21:38:27: screens in use: 2
xscreensaver: 21:38:27:    1/0: 1920x1080+0+0 (HDMI-0)
xscreensaver: 21:38:27:    2/0: 1920x1080+1920+0 (DVI-0)
xscreensaver: 21:38:27: rejected screens: 1
xscreensaver: 21:38:27:    0/0: 1920x1080+0+0 (DisplayPort-0) -- output disabled
xscreensaver: 21:38:27: selecting RANDR events
xscreensaver: 21:38:27: not using XInputExtension.
xscreensaver: 21:38:27: consulting /proc/interrupts for keyboard activity.
xscreensaver: 21:38:27: 0: visual 0x21 (TrueColor,   depth: 24, cmap: default)
xscreensaver: 21:38:27: 0: saver window is 0x2000001.
xscreensaver: 21:38:27: 1: saver window is 0x2000005.
xscreensaver: 21:38:27: selecting events on extant windows... done.
xscreensaver: 21:38:27: mouse is on screen 0 of 2
xscreensaver: 21:38:27: awaiting idleness.
I cannot get the message on the actual lock screen to show up again with a camera good enough to take a picture of the words. But it said something about not finding libgnome.so. I was having trouble figuring out where libgnome.so should come from, (libgnome-2-0 is descrbed as deprecated?).
$ dpkg -l | grep -iE 'font|xscreen'
ii  console-setup                           1.189                              all          console font and keymap setup program
ii  fontconfig                              2.13.1-2                           amd64        generic font configuration library - support binaries
ii  fontconfig-config                       2.13.1-2                           all          generic font configuration library - configuration
ii  fonts-dejavu-core                       2.37-1                             all          Vera font family derivate with additional characters
ii  fonts-droid-fallback                    1:6.0.1r16-1.1                     all          handheld device font with extensive style and language support (fallback)
ii  fonts-freefont-ttf                      20120503-9                         all          Freefont Serif, Sans and Mono Truetype fonts
ii  fonts-liberation                        1:1.07.4-9                         all          Fonts with the same metrics as Times, Arial and Courier
ii  fonts-noto-mono                         20181227-1                         all          "No Tofu" monospaced font family with large Unicode coverage
ii  fonts-wine                              4.0-1                              all          Windows API implementation - fonts
ii  gsfonts                                 1:8.11+urwcyr1.0.7~pre44-4.4       all          Fonts for the Ghostscript interpreter(s)
ii  kbd                                     2.0.4-4                            amd64        Linux console font and keytable utilities
ii  libfont-afm-perl                        1.20-2                             all          Font::AFM - Interface to Adobe Font Metrics files
ii  libfontconfig1:amd64                    2.13.1-2                           amd64        generic font configuration library - runtime
ii  libfontembed1:amd64                     1.21.6-4                           amd64        OpenPrinting CUPS Filters - Font Embed Shared library
ii  libfontenc1:amd64                       1:1.1.3-1+b2                       amd64        X11 font encoding library
ii  libfreetype6:amd64                      2.9.1-3                            amd64        FreeType 2 font engine, shared library files
ii  libgraphite2-3:amd64                    1.3.13-7                           amd64        Font rendering engine for Complex Scripts -- library
ii  libwoff1:amd64                          1.0.2-1                            amd64        library for converting fonts to WOFF 2.0
ii  libxfont2:amd64                         1:2.0.3-1                          amd64        X11 font rasterisation library
ii  libxft2:amd64                           2.3.2-2                            amd64        FreeType-based font drawing library for X
ii  xfonts-base                             1:1.0.5                            all          standard fonts for X
ii  xfonts-encodings                        1:1.0.4-2                          all          Encodings for X.Org fonts
ii  xfonts-terminus                         4.40-2                             all          Fixed-width fonts for fast reading
ii  xfonts-utils                            1:7.7+6                            amd64        X Window System font utility programs
ii  xscreensaver                            5.42+dfsg1-1                       amd64        Screensaver daemon and frontend for X11
ii  xscreensaver-data                       5.42+dfsg1-1                       amd64        Screen saver modules for screensaver frontends
Is there something basic I'm missing? In fedora/centos, I could list the group name such as '^Xfce desktop' and trying to install that would prompt me with the names of the exact packages to install. I am concerned that tasksel wouldn't ask me for the exact packages and it would just go ahead and run something much larger than I want, but I've boiled it down to a million packages.
$ tasksel --task-packages desktop
task-desktop
$ sudo apt-get install task-desktop
Building dependency tree
...TRUNCATED...
  anacron ant ant-contrib ant-optional atril atril-common ca-certificates-java coinor-libcbc3 coinor-libcgl1 coinor-libclp1
  coinor-libcoinmp1v5 coinor-libcoinutils3v5 coinor-libosi1v5 crda cups-pk-helper default-jre default-jre-headless
  desktop-file-utils espeak-ng-data exfalso exo-utils firebird3.0-common firebird3.0-common-doc firebird3.0-server-core
  firebird3.0-utils firefox fonts-crosextra-caladea fonts-crosextra-carlito fonts-dejavu fonts-dejavu-extra fonts-font-awesome
  fonts-lato fonts-liberation2 fonts-linuxlibertine fonts-mathjax fonts-noto-core fonts-noto-ui-core fonts-opensymbol
  fonts-roboto-slab fonts-sil-gentium fonts-sil-gentium-basic gdisk gimp-data gir1.2-atspi-2.0 gir1.2-gst-plugins-base-1.0
  gir1.2-gstreamer-1.0 gir1.2-gtksource-3.0 gir1.2-javascriptcoregtk-4.0 gir1.2-keybinder-3.0 gir1.2-notify-0.7
  gir1.2-packagekitglib-1.0 gir1.2-polkit-1.0 gir1.2-secret-1 gir1.2-soup-2.4 gir1.2-webkit2-4.0 gir1.2-wnck-3.0 gstreamer1.0-alsa
  gstreamer1.0-plugins-bad gtk2-engines-xfce gvfs gvfs-common gvfs-daemons gvfs-libs hddtemp hyphen-en-us iw java-common
  javascript-common libabw-0.1-1 libactivation-java libamd2 libao-common libao4 libaopalliance-java libapache-poi-java
  libapache-pom-java libappstream4 libargs4j-java libasm-java libatasmart4 libatinject-jsr330-api-java libatk-adaptor
  libatk-wrapper-java libatk-wrapper-java-jni libatkmm-1.6-1v5 libatrildocument3 libatrilview3 libaudio2 libbabl-0.1-0
  libbase-java libbcmail-java libbcpkix-java libbcprov-java libboost-atomic1.67.0 libboost-chrono1.67.0 libboost-date-time1.67.0
  libboost-filesystem1.67.0 libboost-iostreams1.67.0 libboost-locale1.67.0 libboost-system1.67.0 libboost-thread1.67.0 libbsh-java
  libburn4 libcairo-perl libcairomm-1.0-1v5 libcaja-extension1 libcamd2 libcanberra-gtk3-0 libcanberra-gtk3-module libcanberra0
  libccolamd2 libcdi-api-java libcdr-0.1-1 libcglib-java libcholmod3 libclucene-contribs1v5 libclucene-core1v5 libcmis-0.5-5v5
  libcodemodel-java libcolamd2 libcommons-cli-java libcommons-codec-java libcommons-collections3-java libcommons-collections4-java
  libcommons-compress-java libcommons-io-java libcommons-lang3-java libcommons-logging-java libcommons-math3-java
  libcommons-parent-java libcurvesapi-java libdom4j-java libdotconf0 libdtd-parser-java libe-book-0.1-1 libehcache-java
  libel-api-java libeot0 libept1.5.0 libepubgen-0.1-1 libespeak-ng1 libetonyek-0.1-1 libexiv2-14 libexo-1-0 libexo-2-0
  libexo-common libexo-helpers libexttextcat-2.0-0 libexttextcat-data libfastinfoset-java libfbclient2 libflute-java libfonts-java
  libformula-java libfreehand-0.1-1 libgail-3-0 libgarcon-1-0 libgarcon-common libgck-1-0 libgcr-base-3-1 libgegl-0.4-0
  libgegl-common libgeronimo-annotation-1.3-spec-java libgeronimo-interceptor-3.0-spec-java libgexiv2-2 libgimp2.0 libglib-perl
  libglib2.0-bin libglibmm-2.4-1v5 libgpgme11 libgpgmepp6 libgssdp-1.0-3 libgstreamer-plugins-bad1.0-0 libgtk2-perl
  libgtkmm-3.0-1v5 libgtksourceview-3.0-1 libgtksourceview-3.0-common libguava-java libguice-java libgupnp-1.0-4
  libgupnp-igd-1.0-4 libgxps2 libhawtjni-runtime-java libhsqldb1.8.0-java libhttpclient-java libhttpcore-java libib-util libical3
  libicu4j-java libimobiledevice6 libintellij-annotations-java libisofs6 libistack-commons-java libitext-java libjansi-java
  libjansi-native-java libjaxb-api-java libjaxb-java libjaxen-java libjcommon-java libjdom1-java libjetbrains-annotations-java
  libjs-jquery libjs-mathjax libjs-modernizr libjs-sphinxdoc libjs-underscore libjsoncpp1 libjsoup-java libjsp-api-java
  libjsr305-java libjte1 libkeybinder-3.0-0 libkpathsea6 liblangtag-common liblangtag1 liblayout-java libloader-java
  liblog4j1.2-java libmail-java libmaven-file-management-java libmaven-parent-java libmaven-resolver-java libmaven-shared-io-java
  libmaven-shared-utils-java libmaven3-core-java libmetis5 libmhash2 libmjpegutils-2.1-0 libmpeg2encpp-2.1-0 libmplex2-2.1-0
  libmspub-0.1-1 libmwaw-0.3-3 libmythes-1.2-0 libnice10 libnotify-bin libnumbertext-1.0-0 libnumbertext-data libodfgen-0.1-1
  libofa0 liborcus-0.14-0 libpackagekit-glib2-18 libpagemaker-0.0-0 libpango-perl libpangomm-1.4-1v5 libpcaudio0
  libpentaho-reporting-flow-engine-java libpixie-java libplexus-archiver-java libplexus-cipher-java libplexus-classworlds-java
  libplexus-component-annotations-java libplexus-interpolation-java libplexus-io-java libplexus-sec-dispatcher-java
  libplexus-utils2-java libplist3 libpoppler-glib8 libpq5 libpulsedsp libqrencode4 libqxp-0.0-0 libraptor2-0 librasqal3 libraw19
  librdf0 librelaxng-datatype-java libreoffice libreoffice-avmedia-backend-gstreamer libreoffice-base libreoffice-base-core
  libreoffice-base-drivers libreoffice-calc libreoffice-common libreoffice-core libreoffice-draw libreoffice-gtk2
  libreoffice-help-common libreoffice-help-en-us libreoffice-impress libreoffice-java-common libreoffice-librelogo
  libreoffice-math libreoffice-nlpsolver libreoffice-report-builder libreoffice-report-builder-bin libreoffice-script-provider-bsh
  libreoffice-script-provider-js libreoffice-script-provider-python libreoffice-sdbc-firebird libreoffice-sdbc-hsqldb
  libreoffice-sdbc-postgresql libreoffice-style-colibre libreoffice-style-tango libreoffice-wiki-publisher libreoffice-writer
  librepository-java librevenge-0.0-0 librngom-java libsac-java libsaxonhe-java libsbc1 libserializer-java libservlet-api-java
  libservlet3.1-java libsigc++-2.0-0v5 libsisu-guice-java libsisu-inject-java libsisu-ioc-java libsisu-plexus-java libslf4j-java
  libsnappy-java libsnappy-jni libsonic0 libsoundtouch1 libspandsp2 libspectre1 libspeechd2 libsrtp2-1 libstaroffice-0.0-0
  libstartup-notification0 libstax-ex-java libstemmer0d libstreambuffer-java libsuitesparseconfig5 libtagc0 libthunarx-3-0
  libtommath1 libtumbler-1-0 libtxw2-java libu2f-udev libudisks2-0 libumfpack5 libunique-1.0-0 libupower-glib1 libupower-glib3
  libusbmuxd4 libvisio-0.1-1 libvo-aacenc0 libvo-amrwbenc0 libwagon-http-java libwagon-provider-api-java
  libwebrtc-audio-processing1 libwebsocket-api-java libwildmidi2 libwnck-3-0 libwnck-3-common libwnck-common libwnck22
  libwpd-0.10-10 libwpg-0.3-3 libwps-0.4-4 libxerces2-java libxfce4panel-2.0-4 libxfce4ui-1-0 libxfce4ui-2-0 libxfce4ui-common
  libxfce4ui-utils libxfce4util-bin libxfce4util-common libxfce4util7 libxfconf-0-2 libxml-commons-external-java
  libxml-commons-resolver1.1-java libxml-java libxmlbeans-java libxmlsec1 libxmlsec1-nss libxnvctrl0 libxom-java libxres1
  libxsom-java libxz-java libzbar0 libzmf-0.0-0 lm-sensors lp-solve mousepad mythes-en-us node-normalize.css openjdk-11-jre
  openjdk-11-jre-headless orage orage-data orca packagekit packagekit-tools parole pavucontrol policykit-1-gnome pulseaudio
  pulseaudio-utils python3-brlapi python3-cups python3-cupshelpers python3-feedparser python3-gst-1.0 python3-louis
  python3-musicbrainzngs python3-mutagen python3-pyatspi python3-pyinotify python3-smbc python3-speechd python3-uno python3-xdg
  quodlibet ristretto rtkit slim sound-icons sound-theme-freedesktop speech-dispatcher speech-dispatcher-audio-plugins
  speech-dispatcher-espeak-ng sphinx-rtd-theme-common synaptic system-config-printer system-config-printer-common
  system-config-printer-udev tango-icon-theme task-desktop task-xfce-desktop thunar thunar-archive-plugin thunar-data
  thunar-media-tags-plugin thunar-volman tumbler tumbler-common udisks2 uno-libs3 upower ure usbmuxd wicd wireless-regdb
  x11-session-utils xbrlapi xfburn xfce4 xfce4-appfinder xfce4-battery-plugin xfce4-clipman xfce4-clipman-plugin
  xfce4-cpufreq-plugin xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict xfce4-diskperf-plugin xfce4-fsguard-plugin
  xfce4-genmon-plugin xfce4-goodies xfce4-mailwatch-plugin xfce4-netload-plugin xfce4-notes xfce4-notes-plugin xfce4-notifyd
  xfce4-panel xfce4-places-plugin xfce4-power-manager xfce4-power-manager-data xfce4-power-manager-plugins xfce4-pulseaudio-plugin
  xfce4-screenshooter xfce4-sensors-plugin xfce4-session xfce4-settings xfce4-smartbookmark-plugin xfce4-systemload-plugin
  xfce4-taskmanager xfce4-terminal xfce4-timer-plugin xfce4-verve-plugin xfce4-wavelan-plugin xfce4-weather-plugin
  xfce4-whiskermenu-plugin xfce4-xkb-plugin xfconf xfdesktop4 xfdesktop4-data xfonts-100dpi xfonts-75dpi xfonts-scalable xfwm4
  xinit xorg xorg-docs-core xsane xsane-common
0 upgraded, 490 newly installed, 0 to remove and 28 not upgraded.
Need to get 405 MB of archives.
Does anyone have any bright ideas as to which of these 490 packages will get the fonts/stuff needed for my xscreensaver to show the words?
So far in my non-EL, non-systemd journey I've discovered that while yum might be slow, its output is way easier to understand.
#2 2019-03-02 15:35:55
Panopticon
Re: [SOLVED] xscreensaver works but prompt has no text
have you tried xscreensaver-demo ?
https://manpages.debian.org/stretch/xsc … .1.en.html
#3 2019-03-04 13:41:58
bgstack15
Yes, I generated the .xscreensaver file using xscreensaver-demo as expected.
#4 2019-03-04 17:48:48
KatolaZ
It looks more like you need elogind/consolekit installed, rather than fonts, IMHO.
#5 2019-03-05 03:18:15
bgstack15
$ ps -ef | grep -iE 'elogin|consolekit'
root      1932     1  0 Mar03 ?        00:00:00 elogind-daemon
bgstack15  14383 14329  0 22:00 pts/6    00:00:00 grep -iE elogin|consolekit
I read up a very tiny bit on elogind and consolekit, but not enough to understand them in depth. I did discover that my default runlevel is 5, but elogind only creates the extra vtys for runlevels 2 and 3 by default. That would explain why I couldn't raise a terminal with CTRL+ALT+F2. Well, time to change my runlevel and reboot! Thanks for this research effort.
#6 2019-03-05 03:29:20
bgstack15
I rebooted in runlevel 2 (which I remember being the original value in /etc/inittab) and now I've got all the vtys. However, my xscreensaver still shows no text in the prompt.
The reason I have this question on the devuan forum is because when I used a "Desktop install" in the installation prompts, the xscreensaver worked. I've even run an strace on the xscreensaver-command -lock and the xscreensaver daemon, on both my control system and my malfunctioning system, and couldn't come up with any observable differences that provided useful avenues to research.
#7 2019-03-05 14:00:03
Panopticon
maybe post up your .xscreensaver dotfile?
Check see what the font setting is.
I used xscreensaver for a while but no longer use, instead just have i3lock with no screensaver.
also if you want to try other x fonts in place of what is there install xorg-xlsfonts and do something like below to list fonts to place in .xscreensaver
xlsfonts | grep helvetica
Edit: not really sure but maybe these fonts are needed and not installed
https://packages.debian.org/stable/font … transcoded
#8 2019-03-06 03:10:34
bgstack15
# XScreenSaver Preferences File
# Written by xscreensaver-demo 5.42 for bgstack15 on Sun Mar  3 18:11:54 2019.
# https://www.jwz.org/xscreensaver/
timeout:        0:10:00
cycle:          0:10:00
lock:           True
lockTimeout:    0:05:00
passwdTimeout:  0:00:30
visualID:       default
installColormap:    True
verbose:        False
timestamp:      True
splash:         True
splashDuration: 0:00:05
demoCommand:    xscreensaver-demo
prefsCommand:   xscreensaver-demo -prefs
nice:           10
memoryLimit:    0
fade:           False
unfade:         False
fadeSeconds:    0:00:03
fadeTicks:      20
captureStderr:  True
ignoreUninstalledPrograms:False
font:           *-medium-r-*-140-*-m-*
dpmsEnabled:    False
dpmsQuickOff:   False
dpmsStandby:    2:00:00
dpmsSuspend:    2:00:00
dpmsOff:        4:00:00
grabDesktopImages:  False
grabVideoFrames:    False
chooseRandomImages: False
imageDirectory:
mode:           one
selected:       154
textMode:       date
textLiteral:    XScreenSaver
textFile:
textProgram:    fortune
textURL:        https://planet.debian.org/rss20.xml
programs:        \
                                maze -root                                  \n\
- GL:                           superquadrics -root                         \n\
...TRUNCATED...
pointerPollTime:    0:00:05
pointerHysteresis:  10
windowCreationTimeout:0:00:30
initialDelay:   0:00:00
GetViewPortIsFullOfLies:False
procInterrupts: True
xinputExtensionDev: False
overlayStderr:  True
authWarningSlack:   20
I ran xlsfonts (it was already present from x11-utils from when I was troubleshooting other, fluxbox stuff) and didn't see any helvetica, or anything that matches a regex similar to the (shell-glob-resembling) conf entry.
$ xlsfonts | grep -E 'medium-r-.*-140-.*-m-'
$ xlsfonts | grep -i helv
Submitting now so I don't lose my large post, but I'm still investigating.
#9 2019-03-06 04:03:34
bgstack15
No go. It still shows the splash screen and unlock prompt with no words whatsoever.
#10 2019-03-06 12:01:18
Panopticon
Not sure what is going on sorry.
What i mean by using xlsfonts is try a few fonts from a list of xfonts, you should have bitstream installed so put the below line in place of where your fonts is in the xsceensaver, this just to narrow it down as not a font issue perhaps?
-bitstream-terminal-medium-r-normal--18-140-100-100-c-110-iso8859-1
Not saying that helvetica is something to search for but it should bring up the adobe helvetica fonts atleast.
try...
xlsfonts | grep adobe
#11 2019-03-06 23:26:30
bgstack15
After taking some time to briefly understand how fonts are named/identified, I learned about how to use this command.
xlsfonts -fn '*-*-bold-r-*-*-*-140-*'
After installing a lot of fonts, it still wasn't working. After a reboot I think (and a day later), it's working now!
Thank you for your help, everybody.
The last few entries from my /var/log/apt/history.log
Start-Date: 2019-03-05  22:11:47
Commandline: apt-get install xfonts-100dpi xfonts-100dpi-transcoded
Requested-By: bgstack15 (960600001)
Install: xfonts-100dpi-transcoded:amd64 (1:1.0.4+nmu1), xfonts-100dpi:amd64 (1:1.0.4+nmu1)
End-Date: 2019-03-05  22:12:19
Start-Date: 2019-03-05  22:37:30
Commandline: apt-get install i3lock
Install: libxcb-xrm0:amd64 (1.0-3, automatic), libev4:amd64 (1:4.25-1, automatic), i3lock:amd64 (2.11.1-1)
End-Date: 2019-03-05  22:37:38
Start-Date: 2019-03-05  22:39:14
Commandline: apt-get purge i3lock
Purge: i3lock:amd64 (2.11.1-1)
End-Date: 2019-03-05  22:39:18
Start-Date: 2019-03-05  22:41:02
Commandline: apt-get purge i3lock libev4 libxcb-xrm0
Purge: libxcb-xrm0:amd64 (1.0-3), libev4:amd64 (1:4.25-1)
End-Date: 2019-03-05  22:41:05
Start-Date: 2019-03-05  22:49:32
Commandline: apt-get install fonts-crosextra-caladea fonts-crosextra-carlito fonts-dejavu fonts-dejavu-extra fonts-font-awesome
Install: fonts-font-awesome:amd64 (5.0.10+really4.7.0~dfsg-1), fonts-dejavu:amd64 (2.37-1), fonts-crosextra-carlito:amd64 (20130920-1), fonts-dejavu-extra:amd64 (2.37-1), fonts-crosextra-caladea:amd64 (20130214-2)
End-Date: 2019-03-05  22:49:42
Start-Date: 2019-03-05  22:50:11
Commandline: apt-get install fonts-crosextra-caladea fonts-crosextra-carlito fonts-dejavu fonts-dejavu-extra fonts-font-awesome fonts-lato fonts-liberation2 fonts-linuxlibertine fonts-mathjax fonts-noto-core fonts-noto-ui-core fonts-opensymbol fonts-roboto-slab fonts-sil-gentium fonts-sil-gentium-basic
Install: fonts-linuxlibertine:amd64 (5.3.0-4), fonts-mathjax:amd64 (2.7.4+dfsg-1), fonts-noto-ui-core:amd64 (20181227-1), fonts-sil-gentium-basic:amd64 (1.102-1), fonts-roboto-slab:amd64 (1.100263+20170512-1), fonts-lato:amd64 (2.0-2), fonts-opensymbol:amd64 (2:102.10+LibO6.1.5-1), fonts-noto-core:amd64 (20181227-1), fonts-sil-gentium:amd64 (20081126:1.03-2)
End-Date: 2019-03-05  22:50:50
I think it was the large swath of fonts at the end, and a reboot.
#12 2019-06-29 12:35:55
bgstack15
On yet another Devuan netinst instance, I had this problem again.
I ended up installing a lot of font packages, and rebooting. I guess restarting X or else rebooting triggers a cache update for the fonts?
apt-get install xfonts-100dpi xfonts-100dpi-transcoded freetype2-doc gsfonts libfreetype6 libfontembed1 fonts-noto-mono fonts-liberation fonts-droid-fallback
The next time I try this, I will do just this bottom line, and report back here. I don't want to have to install the phone book, if I only need a single one of these packages.
