#1 2019-02-09 23:47:36
toro
ethernet and login manager concerns
(my computer is running Ascii with MATE) One day I woke up to find that my computer had either rebooted or logged me out or something like that, I was at the login screen for devuan's default login manager which I think is slim.  I tried to login, and it took a while before reporting that the login had failed or something like that.  I can login from tty1 etc. but that gives me no graphical user interface.  What's more, ever since this incident, ethernet connections don't work with devuan on this computer anymore.  On the other hand, ethernet connections on this computer work just fine in debian stretch which I happened to end up trying.  I don't know how to do a WLAN connection from the terminal, so effectively on the devuan ascii install that is on the internal drive of this laptop (which is the main subject of this post), I have no internet connection.  now, the login manager thing is not really that much of a concern, since if I can somehow get the packages for lightdm, that will probably work (another devuan ascii install that I'm using with this laptop does let me login via lightdm).  But I have 2 questions:
1.  How can I get the packages for lightdm seeing as I have no internet connection on that install and devuan does not seem to offer the packages via web site like debian does with packages.debian.org?
2.  What's going on with my ethernet connection?  If you need more information to figure out what's going on with this please let me know how I can provide it.
In general if you need more info please let me know how I can provide it.  I am currently using this other install of devuan ascii which is on an external hard drive and uses lightdm.
Thank you very much for reading this.
#2 2019-02-10 00:19:26
PedroReina
Re: ethernet and login manager concerns
Usually we need to know the gore details. Let's start for posting the result of running the order dmesg.
#3 2019-02-10 03:42:12
Given that you can boot up some other partition/system with network connection, it should be easy enough the use chroot to the failing partition/system, and then use apt-get as per normal for it.
E.g., if the failing partition/system happen to be /dev/sda5, you would do the following, starting in the working system:
# mount /dev/sda5 /mnt
# chroot /mnt
# mount -t procfs proc /proc
# mount -t sysfs sys /sys
# mount -t devpts devpts /dev/pts
# apt-get install lightdm
That would install lightdm to the failing partition/system, which I assume is correctly set up as to its sources.list.
Note that the three later mount commands are not always needed; it depends on what you want to install. In fact, in some cases you also need to ensure there are nodes for /dev/sda and /dev/sda5 in the chroot file system, but that certainly shouldn't be needed for a lightdm installation.
To exit gracefully, you would first umount the three points within the chroot, then exit and umount /mnt.
#4 2019-02-10 04:59:09
toro
well here goes something.
[   39.061447] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[   39.061484] ACPI: Sleep Button [SLPB]
[   39.061525] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input5
[   39.061550] ACPI: Lid Switch [LID0]
[   39.061575] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[   39.061599] ACPI: Power Button [PWRF]
[   39.176219] input: PC Speaker as /devices/platform/pcspkr/input/input7
[   39.268218] iTCO_vendor_support: vendor-support=0
[   39.318183] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[   39.338726] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   39.338826] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[   39.339080] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   39.374219] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   39.414752] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[   39.414756] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   39.414758] RAPL PMU: hw unit of domain package 2^-14 Joules
[   39.414759] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   39.414761] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   39.414763] RAPL PMU: hw unit of domain psys 2^-14 Joules
[   39.477437] idma64 idma64.0: Found Intel integrated DMA 64-bit
[   39.484101] i2c_hid i2c-ELAN0501:00: i2c-ELAN0501:00 supply vdd not found, using dummy regulator
[   39.484130] i2c_hid i2c-ELAN0501:00: Linked as a consumer to regulator.0
[   39.484135] i2c_hid i2c-ELAN0501:00: i2c-ELAN0501:00 supply vddl not found, using dummy regulator
[   39.503371] input: ELAN0501:00 04F3:3060 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0501:00/0018:04F3:3060.0002/input/input8
[   39.503630] input: ELAN0501:00 04F3:3060 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0501:00/0018:04F3:3060.0002/input/input10
[   39.503806] hid-generic 0018:04F3:3060.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN0501:00 04F3:3060] on i2c-ELAN0501:00
[   40.251723] [drm] Replacing VGA console driver
[   40.253222] Console: switching to colour dummy device 80x25
[   40.254437] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   40.254437] [drm] Driver supports precise vblank timestamp query.
[   40.254795] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   40.262781] acer_wmi: Acer Laptop ACPI-WMI Extras
[   40.262796] acer_wmi: Function bitmap for Communication Button: 0x801
[   40.319529] input: Acer WMI hotkeys as /devices/virtual/input/input11
[   40.372190] Intel(R) Wireless WiFi driver for Linux
[   40.372190] Copyright(c) 2003- 2015 Intel Corporation
[   40.484595] i915 0000:00:02.0: firmware: failed to load i915/kbl_dmc_ver1_04.bin (-2)
[   40.484603] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[   40.484607] i915 0000:00:02.0: Direct firmware load for i915/kbl_dmc_ver1_04.bin failed with error -2
[   40.484611] i915 0000:00:02.0: Failed to load DMC firmware i915/kbl_dmc_ver1_04.bin. Disabling runtime power management.
[   40.484612] i915 0000:00:02.0: DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
[   40.543863] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20180810/nsarguments-66)
[   40.543898] ACPI Warning: \_SB.PCI0.RP01.PXSX._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20180810/nsarguments-66)
[   40.544394] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[   40.544396] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.RP01.PXSX handle
[   40.544397] nouveau: detected PR support, will not use DSM
[   40.544420] nouveau 0000:01:00.0: enabling device (0406 -> 0407)
[   40.544568] nouveau 0000:01:00.0: NVIDIA GP108 (138000a1)
[   40.577243] nouveau 0000:01:00.0: bios: version 86.08.10.00.07
[   40.577410] nouveau 0000:01:00.0: firmware: failed to load nvidia/gp108/gr/sw_nonctx.bin (-2)
[   40.577417] nouveau 0000:01:00.0: Direct firmware load for nvidia/gp108/gr/sw_nonctx.bin failed with error -2
[   40.577419] nouveau 0000:01:00.0: gr: failed to load gr/sw_nonctx
[   40.642935] iwlwifi 0000:03:00.0: firmware: direct-loading firmware iwlwifi-3168-29.ucode
[   40.643176] iwlwifi 0000:03:00.0: loaded firmware version 29.1044073957.0 op_mode iwlmvm
[   40.667313] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[   40.746491] nouveau 0000:01:00.0: fb: 2048 MiB GDDR5
[   40.747710] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   40.747836] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12
[   40.747940] [Firmware Bug]: ACPI(PXSX) defines _DOD but not _DOS
[   40.747949] ACPI: Video Device [PXSX] (multi-head: yes  rom: yes  post: no)
[   40.747981] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:32/LNXVIDEO:01/input/input13
[   40.748099] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   40.753477] fbcon: inteldrmfb (fb0) is primary device
[   41.005352] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC255: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   41.005354] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   41.005355] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   41.005356] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   41.005356] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   41.005357] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
[   41.005358] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   41.067676] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
[   41.196950] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   41.197368] thermal thermal_zone2: failed to read out thermal zone (-61)
[   41.247943] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[   41.251469] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[   41.252323] dell_smbios: Unable to run on non-Dell system
[   41.314621] Bluetooth: Core ver 2.22
[   41.314634] NET: Registered protocol family 31
[   41.314635] Bluetooth: HCI device and connection manager initialized
[   41.314638] Bluetooth: HCI socket layer initialized
[   41.314639] Bluetooth: L2CAP socket layer initialized
[   41.314644] Bluetooth: SCO socket layer initialized
[   41.473334] usbcore: registered new interface driver btusb
[   41.482789] Bluetooth: hci0: read Intel version: 370810225019140f00
[   41.515599] bluetooth hci0: firmware: direct-loading firmware intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
[   41.515601] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
[   41.889815] Bluetooth: hci0: Intel firmware patch completed and activated
[   41.963720] media: Linux media interface: v0.10
[   41.982826] videodev: Linux video capture interface: v2.00
[   41.993724] Console: switching to colour frame buffer device 240x67
[   42.013081] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[   42.157720] uvcvideo 1-7:1.0: Entity type for entity Extension 4 was not initialized!
[   42.157721] uvcvideo 1-7:1.0: Entity type for entity Processing 2 was not initialized!
[   42.756359] ------------[ cut here ]------------
[   42.756360] nouveau 0000:01:00.0: timeout
[   42.756437] WARNING: CPU: 6 PID: 630 at /build/linux-Ut6wTa/linux-4.19.12/drivers/gpu/drm/nouveau/nvkm/subdev/pmu/base.c:86 nvkm_pmu_reset+0x14c/0x160 [nouveau]
[   42.756437] Modules linked in: uvcvideo(+) videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev media btusb btrtl btbcm btintel bluetooth drbg dell_smbios(-) ansi_cprng dcdbas ecdh_generic dell_wmi_descriptor arc4 snd_soc_skl snd_soc_skl_ipc snd_soc_sst_ipc iwlmvm snd_soc_sst_dsp snd_hda_ext_core snd_hda_codec_realtek(+) snd_soc_acpi_intel_match snd_hda_codec_generic kvm_intel(+) snd_soc_acpi mac80211 hid_multitouch(+) snd_soc_core snd_compress kvm nouveau(+) irqbypass iwlwifi snd_hda_intel acer_wmi i915 wmi_bmof sparse_keymap snd_hda_codec crct10dif_pclmul snd_hda_core crc32_pclmul snd_hwdep mxm_wmi ghash_clmulni_intel snd_pcm ttm snd_timer rtsx_pci_ms drm_kms_helper cfg80211 snd intel_cstate drm soundcore intel_uncore memstick idma64 intel_rapl_perf rfkill mei_me i2c_algo_bit
[   42.756463]  iTCO_wdt intel_lpss_pci mei iTCO_vendor_support intel_lpss serio_raw pcspkr intel_pch_thermal tpm_crb video tpm_tis button tpm_tis_core pcc_cpufreq tpm rng_core wmi evdev battery ac acpi_pad uinput ext4 crc16 mbcache jbd2 fscrypto ecb uas btrfs xor zstd_decompress zstd_compress xxhash usb_storage raid6_pq libcrc32c crc32c_generic hid_generic usbhid sg sr_mod cdrom sd_mod crc32c_intel rtsx_pci_sdmmc ahci xhci_pci mmc_core libahci xhci_hcd libata aesni_intel aes_x86_64 crypto_simd r8169 usbcore i2c_hid cryptd scsi_mod glue_helper libphy rtsx_pci i2c_i801 hid usb_common thermal
[   42.756489] CPU: 6 PID: 630 Comm: udevd Not tainted 4.19.0-0.bpo.1-amd64 #1 Debian 4.19.12-1~bpo9+1
[   42.756490] Hardware name: Acer Aspire E5-576G/Ironman_SK, BIOS V1.29 07/21/2017
[   42.756516] RIP: 0010:nvkm_pmu_reset+0x14c/0x160 [nouveau]
[   42.756518] Code: 5c 41 5d 41 5e c3 48 8b 7d 10 48 8b 5f 50 48 85 db 74 24 e8 b6 01 10 ca 48 89 da 48 89 c6 48 c7 c7 75 8a f7 c0 e8 c4 d7 c5 c9 <0f> 0b e9 42 ff ff ff 48 8b 5f 10 eb ab 48 8b 5f 10 eb d6 90 0f 1f
[   42.756518] RSP: 0000:ffffb99b013077d0 EFLAGS: 00010282
[   42.756519] RAX: 0000000000000000 RBX: ffff8fbea48f76a0 RCX: ffffffff8ba4dca8
[   42.756520] RDX: 0000000000000001 RSI: 0000000000000096 RDI: 0000000000000247
[   42.756521] RBP: ffff8fbe9e50cc00 R08: 0000000000000001 R09: 0000000000000357
[   42.756521] R10: ffff8fbea3cb4300 R11: 0000000000000000 R12: ffff8fbe9d70dc00
[   42.756522] R13: ffff8fbea4cc4540 R14: 000000097d59bba0 R15: 0000000000000002
[   42.756523] FS:  00007f43d130dd00(0000) GS:ffff8fbea6b80000(0000) knlGS:0000000000000000
[   42.756523] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   42.756524] CR2: 00007f2fc9456659 CR3: 0000000262c14006 CR4: 00000000003606e0
[   42.756525] Call Trace:
[   42.756551]  nvkm_pmu_init+0x16/0x40 [nouveau]
[   42.756569]  nvkm_subdev_init+0x95/0x1f0 [nouveau]
[   42.756596]  nvkm_device_init+0x169/0x270 [nouveau]
[   42.756620]  nvkm_udevice_init+0x41/0x60 [nouveau]
[   42.756638]  nvkm_object_init+0x3e/0x190 [nouveau]
[   42.756655]  nvkm_ioctl_new+0x171/0x2b0 [nouveau]
[   42.756672]  ? nvkm_client_notify+0x30/0x30 [nouveau]
[   42.756696]  ? nvkm_udevice_rd08+0x20/0x20 [nouveau]
[   42.756713]  nvkm_ioctl+0x112/0x230 [nouveau]
[   42.756729]  nvif_object_init+0xba/0x110 [nouveau]
[   42.756745]  nvif_device_init+0xe/0x50 [nouveau]
[   42.756772]  nouveau_cli_init+0x1e4/0x560 [nouveau]
[   42.756798]  nouveau_drm_load+0x66/0x7f0 [nouveau]
[   42.756818]  drm_dev_register+0x112/0x1a0 [drm]
[   42.756825]  drm_get_pci_dev+0x8e/0x160 [drm]
[   42.756849]  nouveau_drm_probe+0x1e7/0x260 [nouveau]
[   42.756852]  local_pci_probe+0x44/0xa0
[   42.756855]  ? _cond_resched+0x16/0x40
[   42.756856]  pci_device_probe+0x102/0x1b0
[   42.756858]  really_probe+0x216/0x3e0
[   42.756860]  driver_probe_device+0x10b/0x130
[   42.756862]  __driver_attach+0x109/0x110
[   42.756863]  ? driver_probe_device+0x130/0x130
[   42.756864]  bus_for_each_dev+0x67/0xc0
[   42.756867]  ? klist_add_tail+0x3b/0x70
[   42.756868]  bus_add_driver+0x16a/0x260
[   42.756870]  driver_register+0x5b/0xe0
[   42.756871]  ? 0xffffffffc0fd8000
[   42.756872]  do_one_initcall+0x4d/0x1c5
[   42.756874]  ? _cond_resched+0x16/0x40
[   42.756876]  ? kmem_cache_alloc_trace+0x16a/0x1d0
[   42.756878]  do_init_module+0x5b/0x218
[   42.756879]  load_module+0x1c62/0x2b00
[   42.756881]  ? __do_sys_finit_module+0xd7/0x110
[   42.756882]  __do_sys_finit_module+0xd7/0x110
[   42.756884]  do_syscall_64+0x55/0x110
[   42.756886]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[   42.756887] RIP: 0033:0x7f43d07df229
[   42.756888] Code: 00 f3 c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 40 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 3f 4c 2b 00 f7 d8 64 89 01 48
[   42.756889] RSP: 002b:00007fff12fef218 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[   42.756890] RAX: ffffffffffffffda RBX: 00005558c1e97470 RCX: 00007f43d07df229
[   42.756890] RDX: 0000000000000000 RSI: 00007f43d0aab265 RDI: 000000000000000f
[   42.756891] RBP: 00007f43d0aab265 R08: 0000000000000000 R09: 00007fff12fef790
[   42.756891] R10: 000000000000000f R11: 0000000000000246 R12: 0000000000000000
[   42.756892] R13: 00005558c1e989f0 R14: 0000000000020000 R15: 00005558c038a319
[   42.756893] ---[ end trace 2ff3a28c66f3ae33 ]---
[   42.797096] usbcore: registered new interface driver uvcvideo
[   42.797097] USB Video Class driver (1.1.1)
[   42.797400] snd_hda_codec_realtek hdaudioC0D0: Failed to find dell wmi symbol dell_micmute_led_set
[   42.832966] vga_switcheroo: enabled
[   42.833066] [TTM] Zone  kernel: Available graphics memory: 4022052 kiB
[   42.833066] [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
[   42.833067] [TTM] Initializing pool allocator
[   42.833069] [TTM] Initializing DMA pool allocator
[   42.833081] nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
[   42.833082] nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
[   42.833084] nouveau 0000:01:00.0: DRM: BIT table 'A' not found
[   42.833085] nouveau 0000:01:00.0: DRM: BIT table 'L' not found
[   42.833086] nouveau 0000:01:00.0: DRM: Pointer to TMDS table invalid
[   42.833109] nouveau 0000:01:00.0: DRM: DCB version 4.1
[   42.833638] nouveau 0000:01:00.0: DRM: failed to create kernel channel, -22
[   42.857163] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[   42.860060] input: ELAN0501:00 04F3:3060 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0501:00/0018:04F3:3060.0002/input/input18
[   42.860113] hid-multitouch 0018:04F3:3060.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN0501:00 04F3:3060] on i2c-ELAN0501:00
[   43.074801] intel_rapl: Found RAPL domain package
[   43.074805] intel_rapl: Found RAPL domain core
[   43.074808] intel_rapl: Found RAPL domain uncore
[   43.074810] intel_rapl: Found RAPL domain dram
[   43.744625] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[   43.745618] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[   43.745673] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[   43.745743] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[   43.745813] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[   43.745897] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[   43.746000] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[   46.229400] EXT4-fs (sdd1): re-mounted. Opts: errors=remount-ro
[   47.210312] EXT4-fs (sdd3): mounted filesystem with ordered data mode. Opts: (null)
[   52.828390] elogind[2786]: New seat seat0.
[   52.878657] elogind[2786]: Watching system buttons on /dev/input/event6 (Power Button)
[   52.973161] elogind[2786]: Watching system buttons on /dev/input/event3 (Power Button)
[   52.973220] elogind[2786]: Watching system buttons on /dev/input/event4 (Sleep Button)
[   53.017266] elogind[2786]: Watching system buttons on /dev/input/event0 (AT Translated Set 2 keyboard)
[   53.017420] elogind[2786]: Watching system buttons on /dev/input/event10 (Acer WMI hotkeys)
[   53.017623] elogind[2786]: Watching system buttons on /dev/input/event2 (BRLTTY 5.4 Linux Screen Driver Keyboard)
[   53.237441] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   53.237442] Bluetooth: BNEP filters: protocol multicast
[   53.237445] Bluetooth: BNEP socket layer initialized
[   54.771583] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   54.790551] r8169 0000:04:00.1: firmware: direct-loading firmware rtl_nic/rtl8411-2.fw
[   54.790834] Generic PHY r8169-401:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=r8169-401:00, irq=IGNORE)
[   54.899911] r8169 0000:04:00.1 eth0: Link is Down
[   54.900108] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   54.922295] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   54.990802] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   55.073096] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   55.655122] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   58.433943] r8169 0000:04:00.1 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   58.433960] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   65.017653] elogind[2786]: New session 1 of user sphere.
[   88.100463] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   92.288063] EXT4-fs (sdc2): mounted filesystem with ordered data mode. Opts: (null)
[  147.820707] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  150.578895] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  175.886328] tun: Universal TUN/TAP device driver, 1.6
[  190.433524] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[ 7682.453052] EXT4-fs (sdc3): mounted filesystem with ordered data mode. Opts: (null)
[ 7706.873227] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 7716.366183] BTRFS info (device sdb2): disk space caching is enabled
[ 7716.366188] BTRFS info (device sdb2): has skinny extents
[ 7716.375520] BTRFS info (device sdb2): enabling ssd optimizations
[ 7716.378043] BTRFS info (device sdb2): checking UUID tree
[15434.626564] acer_wmi: Unknown function number - 8 - 1
[61095.212275] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[61442.061455] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[61757.057500] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[61914.958359] usb 1-2.2: USB disconnect, device number 6
[62072.061751] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[62387.062067] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[62702.061804] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[63017.062020] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[63332.061081] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[63647.061131] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[63962.007491] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[64277.022229] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[64592.037258] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[64907.052374] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[65222.061413] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[65537.061928] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[65852.061744] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[66167.013352] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[66482.037617] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[66797.061274] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[67112.019926] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[67427.061351] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[67742.061099] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[68057.061454] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[68372.061677] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[68687.061326] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[69002.061413] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[69317.061424] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[69632.057232] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[69947.061165] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[70262.004971] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[70577.021915] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[70892.036978] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[71207.049242] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[71522.034605] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[71837.060624] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[72152.060795] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[72467.061004] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[72782.061368] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[73097.061566] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[73412.025794] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[73727.043436] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[74042.046118] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[74357.061356] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[74672.061259] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[74987.061357] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[75302.061490] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[75617.061278] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[75932.061215] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[76247.029638] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[76562.004780] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[76877.007116] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[77192.037060] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[77507.012070] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[77822.003483] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[78137.040412] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[78452.061349] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[78767.012533] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[79082.011741] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[79397.060684] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[79712.061035] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[80027.026291] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[80342.048241] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[80657.061738] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[80972.060742] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[81287.060667] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[81602.060587] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[81917.061048] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[82232.061221] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[82547.060972] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[82862.004643] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[83177.020585] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[83492.036633] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[83807.011442] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[84122.061292] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[84437.061284] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[84752.027398] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[85067.011481] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[85382.060753] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[85697.060635] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[86012.060494] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[86327.060837] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[86642.060791] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[86957.060406] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[87272.049747] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[87587.014953] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[87902.002833] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[88217.042725] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[88532.059632] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[88847.060136] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[89162.006799] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[89477.021914] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[89792.036531] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[90107.051387] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[90422.060316] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[90737.060492] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[91052.003766] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[91367.060505] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[91682.059872] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[91997.060706] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[92312.011219] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[92627.059940] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[92942.060242] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[93257.060464] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[93572.058831] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[93887.060471] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[94202.060548] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[94517.060284] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[94832.056351] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[95147.017543] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[95462.001178] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[95777.021117] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[96092.036539] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[96407.051620] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[96722.060128] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[97037.060410] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[97352.060496] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[97667.060407] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[97982.040807] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[98297.060435] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[98612.059632] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[98927.010260] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[99242.060459] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[99557.037326] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[99872.010213] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[100004.625100] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[100004.742802] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[114018.823667] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Thank you both for the responses, and ralph I will get to you after I have tried the procedure!
#5 2019-02-10 05:39:01
toro
The plot thickens.
I tried the chroot, and it seemed to work mostly fine, although I think it was the procfs mount that did not work, and it gave me this during the installation:
invoke-rc.d: could not determine current runlevel
[....] Reloading system message bus config...Failed to open connection to "system" message bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
invoke-rc.d: initscript dbus, action "reload" failed.
After all that, I booted back to the system, and lightdm showed fine, but when I tried to log in, it said it could not update the .ICEauthority file.
EDIT:  Oh, um, oops.  The dmesg output was from the operating system that worked, so, I guess that's useless.
another edit:  But, I don't see how I'm supposed to save dmesg output on the OS install that is not working right.
#6 2019-02-10 05:51:54
At a guess, you have set up your machine to share /home between systems, but "forgotten" to synchronize the UID of the user(s)...
#7 2019-02-10 06:51:45
toro
I looked up why this kind of thing might happen with the .ICEauthority and found it can be related to home permissions and sure enough I did not have write permissions to my own home directory for some reason.  So I fixed that, logged in, and it was pretty expected that consolekit was not liking lightdm after I had read the release notes, so I just switched back to slim and it worked fine and I uninstalled lightdm since I did not need it anymore.
So now half of this whole thing is solved.
But there is still the concern with the networking.  So let's see here.
Maybe this dmesg output will actually help since it is from the right OS install:
[   34.799715] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   34.808045] input: ELAN0501:00 04F3:3060 Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0501:00/0018:04F3:3060.0002/input/input7
[   34.808144] input: ELAN0501:00 04F3:3060 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0501:00/0018:04F3:3060.0002/input/input9
[   34.808196] hid-generic 0018:04F3:3060.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN0501:00 04F3:3060] on i2c-ELAN0501:00
[   34.840694] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[   34.840695] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   34.840695] RAPL PMU: hw unit of domain package 2^-14 Joules
[   34.840696] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   34.840696] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   34.840697] RAPL PMU: hw unit of domain psys 2^-14 Joules
[   34.861432] media: Linux media interface: v0.10
[   34.863942] Intel(R) Wireless WiFi driver for Linux
[   34.863942] Copyright(c) 2003- 2015 Intel Corporation
[   34.864995] [drm] Replacing VGA console driver
[   34.865095] acer_wmi: Acer Laptop ACPI-WMI Extras
[   34.865111] acer_wmi: Function bitmap for Communication Button: 0x801
[   34.866219] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[   34.866686] Console: switching to colour dummy device 80x25
[   34.871983] iwlwifi 0000:03:00.0: firmware: direct-loading firmware iwlwifi-3168-29.ucode
[   34.872170] iwlwifi 0000:03:00.0: loaded firmware version 29.1044073957.0 op_mode iwlmvm
[   34.874512] videodev: Linux video capture interface: v2.00
[   34.910439] hpet1: lost 1 rtc interrupts
[   34.918328] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[   34.918329] [drm] Driver supports precise vblank timestamp query.
[   34.921926] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   34.922825] i915 0000:00:02.0: firmware: failed to load i915/kbl_dmc_ver1_04.bin (-2)
[   34.922831] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[   34.922836] i915 0000:00:02.0: Direct firmware load for i915/kbl_dmc_ver1_04.bin failed with error -2
[   34.922838] i915 0000:00:02.0: Failed to load DMC firmware i915/kbl_dmc_ver1_04.bin. Disabling runtime power management.
[   34.922839] i915 0000:00:02.0: DMC firmware homepage: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
[   34.988472] Bluetooth: Core ver 2.22
[   34.988485] NET: Registered protocol family 31
[   34.988486] Bluetooth: HCI device and connection manager initialized
[   34.988489] Bluetooth: HCI socket layer initialized
[   34.988490] Bluetooth: L2CAP socket layer initialized
[   34.988495] Bluetooth: SCO socket layer initialized
[   34.989386] r8169 0000:04:00.1: firmware: direct-loading firmware rtl_nic/rtl8411-2.fw
[   34.989570] Generic PHY r8169-401:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=r8169-401:00, irq=IGNORE)
[   34.998231] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
[   35.008199] usbcore: registered new interface driver btusb
[   35.009026] uvcvideo 1-7:1.0: Entity type for entity Extension 4 was not initialized!
[   35.009028] uvcvideo 1-7:1.0: Entity type for entity Processing 2 was not initialized!
[   35.009169] usbcore: registered new interface driver uvcvideo
[   35.009170] USB Video Class driver (1.1.1)
[   35.014751] input: Acer WMI hotkeys as /devices/virtual/input/input11
[   35.014753] ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20180810/nsarguments-66)
[   35.014815] ACPI Warning: \_SB.PCI0.RP01.PXSX._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20180810/nsarguments-66)
[   35.015545] pci 0000:01:00.0: optimus capabilities: enabled, status dynamic power, hda bios codec supported
[   35.015551] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.RP01.PXSX handle
[   35.015552] nouveau: detected PR support, will not use DSM
[   35.015575] nouveau 0000:01:00.0: enabling device (0406 -> 0407)
[   35.015812] nouveau 0000:01:00.0: NVIDIA GP108 (138000a1)
[   35.021041] Bluetooth: hci0: read Intel version: 370810225019140f00
[   35.021401] bluetooth hci0: firmware: direct-loading firmware intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
[   35.021403] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
[   35.022592] input: BRLTTY 5.4 Linux Screen Driver Keyboard as /devices/virtual/input/input12
[   35.064978] intel_rapl: Found RAPL domain package
[   35.064980] intel_rapl: Found RAPL domain core
[   35.064981] intel_rapl: Found RAPL domain uncore
[   35.064982] intel_rapl: Found RAPL domain dram
[   35.138125] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   35.164654] nouveau 0000:01:00.0: bios: version 86.08.10.00.07
[   35.164830] nouveau 0000:01:00.0: firmware: failed to load nvidia/gp108/gr/sw_nonctx.bin (-2)
[   35.164837] nouveau 0000:01:00.0: Direct firmware load for nvidia/gp108/gr/sw_nonctx.bin failed with error -2
[   35.164839] nouveau 0000:01:00.0: gr: failed to load gr/sw_nonctx
[   35.177038] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   35.177476] thermal thermal_zone3: failed to read out thermal zone (-61)
[   35.286283] input: ELAN0501:00 04F3:3060 Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-ELAN0501:00/0018:04F3:3060.0002/input/input15
[   35.286344] hid-multitouch 0018:04F3:3060.0002: input,hidraw1: I2C HID v1.00 Mouse [ELAN0501:00 04F3:3060] on i2c-ELAN0501:00
[   35.326027] Bluetooth: hci0: Intel firmware patch completed and activated
[   35.331154] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[   35.410322] nouveau 0000:01:00.0: fb: 2048 MiB GDDR5
[   35.411296] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   35.411418] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input16
[   35.411513] [Firmware Bug]: ACPI(PXSX) defines _DOD but not _DOS
[   35.411519] ACPI: Video Device [PXSX] (multi-head: yes  rom: yes  post: no)
[   35.411538] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:32/LNXVIDEO:01/input/input17
[   35.411640] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   35.416983] fbcon: inteldrmfb (fb0) is primary device
[   36.656953] Console: switching to colour frame buffer device 240x67
[   36.676178] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[   37.419876] ------------[ cut here ]------------
[   37.419877] nouveau 0000:01:00.0: timeout
[   37.419946] WARNING: CPU: 6 PID: 611 at /build/linux-Ut6wTa/linux-4.19.12/drivers/gpu/drm/nouveau/nvkm/subdev/pmu/base.c:86 nvkm_pmu_reset+0x14c/0x160 [nouveau]
[   37.419946] Modules linked in: joydev arc4 hid_multitouch intel_rapl snd_soc_skl x86_pkg_temp_thermal intel_powerclamp snd_soc_skl_ipc snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core snd_compress coretemp btusb kvm_intel btrtl btbcm btintel uvcvideo iwlmvm snd_hda_intel kvm videobuf2_vmalloc irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel bluetooth mac80211 snd_hda_codec videobuf2_memops snd_hda_core videobuf2_v4l2 videobuf2_common nouveau(+) snd_hwdep intel_cstate snd_pcm videodev drbg acer_wmi wmi_bmof iwlwifi sparse_keymap snd_timer intel_uncore ansi_cprng media ecdh_generic snd cfg80211 i915 crc16 intel_rapl_perf mxm_wmi evdev iTCO_wdt rtsx_pci_ms ttm soundcore serio_raw iTCO_vendor_support pcspkr tpm_crb rfkill memstick drm_kms_helper
[   37.419973]  tpm_tis tpm_tis_core idma64 intel_lpss_pci tpm video intel_lpss mei_me drm acpi_pad rng_core battery mei wmi intel_pch_thermal ac button pcc_cpufreq i2c_algo_bit uinput uas btrfs xor zstd_decompress zstd_compress xxhash usb_storage raid6_pq libcrc32c crc32c_generic hid_generic usbhid sg sr_mod cdrom sd_mod crc32c_intel rtsx_pci_sdmmc ahci xhci_pci libahci mmc_core xhci_hcd libata aesni_intel aes_x86_64 r8169 usbcore crypto_simd scsi_mod cryptd glue_helper i2c_hid libphy rtsx_pci i2c_i801 hid usb_common thermal
[   37.419997] CPU: 6 PID: 611 Comm: udevd Not tainted 4.19.0-0.bpo.1-amd64 #1 Debian 4.19.12-1~bpo9+1
[   37.419998] Hardware name: Acer Aspire E5-576G/Ironman_SK, BIOS V1.29 07/21/2017
[   37.420024] RIP: 0010:nvkm_pmu_reset+0x14c/0x160 [nouveau]
[   37.420025] Code: 5c 41 5d 41 5e c3 48 8b 7d 10 48 8b 5f 50 48 85 db 74 24 e8 b6 11 cf d5 48 89 da 48 89 c6 48 c7 c7 75 7a f8 c0 e8 c4 e7 84 d5 <0f> 0b e9 42 ff ff ff 48 8b 5f 10 eb ab 48 8b 5f 10 eb d6 90 0f 1f
[   37.420026] RSP: 0018:ffffa0624146f7d0 EFLAGS: 00010282
[   37.420027] RAX: 0000000000000000 RBX: ffff9106a48f7c60 RCX: ffffffff9764dca8
[   37.420027] RDX: 0000000000000001 RSI: 0000000000000096 RDI: 0000000000000247
[   37.420028] RBP: ffff9106a3e02800 R08: 0000000000000001 R09: 000000000000035e
[   37.420029] R10: ffff9106a06937e0 R11: 0000000000000000 R12: ffff9106a1fe6600
[   37.420029] R13: ffff91069e4fc000 R14: 000000083f457ea0 R15: 0000000000000002
[   37.420030] FS:  00007fea84f1cd00(0000) GS:ffff9106a6b80000(0000) knlGS:0000000000000000
[   37.420031] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[   37.420031] CR2: 0000564cfaab5770 CR3: 000000025f10c004 CR4: 00000000003606e0
[   37.420032] Call Trace:
[   37.420058]  nvkm_pmu_init+0x16/0x40 [nouveau]
[   37.420076]  nvkm_subdev_init+0x95/0x1f0 [nouveau]
[   37.420104]  nvkm_device_init+0x169/0x270 [nouveau]
[   37.420128]  nvkm_udevice_init+0x41/0x60 [nouveau]
[   37.420147]  nvkm_object_init+0x3e/0x190 [nouveau]
[   37.420164]  nvkm_ioctl_new+0x171/0x2b0 [nouveau]
[   37.420181]  ? nvkm_client_notify+0x30/0x30 [nouveau]
[   37.420205]  ? nvkm_udevice_rd08+0x20/0x20 [nouveau]
[   37.420221]  nvkm_ioctl+0x112/0x230 [nouveau]
[   37.420238]  nvif_object_init+0xba/0x110 [nouveau]
[   37.420254]  nvif_device_init+0xe/0x50 [nouveau]
[   37.420281]  nouveau_cli_init+0x1e4/0x560 [nouveau]
[   37.420307]  nouveau_drm_load+0x66/0x7f0 [nouveau]
[   37.420324]  drm_dev_register+0x112/0x1a0 [drm]
[   37.420331]  drm_get_pci_dev+0x8e/0x160 [drm]
[   37.420356]  nouveau_drm_probe+0x1e7/0x260 [nouveau]
[   37.420359]  local_pci_probe+0x44/0xa0
[   37.420362]  ? _cond_resched+0x16/0x40
[   37.420363]  pci_device_probe+0x102/0x1b0
[   37.420365]  really_probe+0x216/0x3e0
[   37.420367]  driver_probe_device+0x10b/0x130
[   37.420369]  __driver_attach+0x109/0x110
[   37.420370]  ? driver_probe_device+0x130/0x130
[   37.420371]  bus_for_each_dev+0x67/0xc0
[   37.420374]  ? klist_add_tail+0x3b/0x70
[   37.420375]  bus_add_driver+0x16a/0x260
[   37.420377]  driver_register+0x5b/0xe0
[   37.420378]  ? 0xffffffffc0fe7000
[   37.420379]  do_one_initcall+0x4d/0x1c5
[   37.420381]  ? _cond_resched+0x16/0x40
[   37.420383]  ? kmem_cache_alloc_trace+0x16a/0x1d0
[   37.420385]  do_init_module+0x5b/0x218
[   37.420386]  load_module+0x1c62/0x2b00
[   37.420389]  ? __do_sys_finit_module+0xd7/0x110
[   37.420390]  __do_sys_finit_module+0xd7/0x110
[   37.420391]  do_syscall_64+0x55/0x110
[   37.420393]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[   37.420394] RIP: 0033:0x7fea843e3229
[   37.420395] Code: 00 f3 c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 40 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 3f 4c 2b 00 f7 d8 64 89 01 48
[   37.420396] RSP: 002b:00007ffdad452698 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[   37.420397] RAX: ffffffffffffffda RBX: 000055801025cf50 RCX: 00007fea843e3229
[   37.420398] RDX: 0000000000000000 RSI: 00007fea846af265 RDI: 000000000000000d
[   37.420398] RBP: 00007fea846af265 R08: 0000000000000000 R09: 00007ffdad452c10
[   37.420399] R10: 000000000000000d R11: 0000000000000246 R12: 0000000000000000
[   37.420400] R13: 0000558010251ae0 R14: 0000000000020000 R15: 000055800f0d5319
[   37.420401] ---[ end trace 78a6cf067b8d2746 ]---
[   37.459252] vga_switcheroo: enabled
[   37.459385] [TTM] Zone  kernel: Available graphics memory: 4022064 kiB
[   37.459385] [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
[   37.459386] [TTM] Initializing pool allocator
[   37.459389] [TTM] Initializing DMA pool allocator
[   37.459400] nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
[   37.459401] nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
[   37.459403] nouveau 0000:01:00.0: DRM: BIT table 'A' not found
[   37.459404] nouveau 0000:01:00.0: DRM: BIT table 'L' not found
[   37.459405] nouveau 0000:01:00.0: DRM: Pointer to TMDS table invalid
[   37.459426] nouveau 0000:01:00.0: DRM: DCB version 4.1
[   37.459973] nouveau 0000:01:00.0: DRM: failed to create kernel channel, -22
[   37.480236] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 1
[   37.536393] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC255: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   37.536395] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   37.536396] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   37.536397] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   37.536397] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   37.536398] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
[   37.536399] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
[   37.541583] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[   37.542821] dell_smbios: Unable to run on non-Dell system
[   37.617284] snd_hda_codec_realtek hdaudioC0D0: Failed to find dell wmi symbol dell_micmute_led_set
[   38.021093] r8169 0000:04:00.1 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   38.021107] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   38.223283] BTRFS info (device sdb2): disk space caching is enabled
[   38.963905] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   39.449679] audit: type=1400 audit(1549778136.064:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="system_tor" pid=1562 comm="apparmor_parser"
[   39.568580] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[   39.569618] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[   39.569792] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[   39.571962] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[   39.572672] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[   39.573017] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[   39.573302] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[  104.581360] elogind[2439]: New seat seat0.
[  104.581736] elogind[2439]: Watching system buttons on /dev/input/event5 (Power Button)
[  104.595623] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  104.595624] Bluetooth: BNEP filters: protocol multicast
[  104.595628] Bluetooth: BNEP socket layer initialized
[  104.729841] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  104.776254] elogind[2439]: Watching system buttons on /dev/input/event2 (Power Button)
[  104.776293] elogind[2439]: Watching system buttons on /dev/input/event3 (Sleep Button)
[  104.795385] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  104.816245] elogind[2439]: Watching system buttons on /dev/input/event0 (AT Translated Set 2 keyboard)
[  104.816287] elogind[2439]: Watching system buttons on /dev/input/event10 (Acer WMI hotkeys)
[  104.816321] elogind[2439]: Watching system buttons on /dev/input/event11 (BRLTTY 5.4 Linux Screen Driver Keyboard)
[  104.891559] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  106.955857] ------------[ cut here ]------------
[  106.955858] nouveau 0000:01:00.0: timeout
[  106.955917] WARNING: CPU: 2 PID: 2636 at /build/linux-Ut6wTa/linux-4.19.12/drivers/gpu/drm/nouveau/nvkm/subdev/pmu/base.c:86 nvkm_pmu_reset+0x14c/0x160 [nouveau]
[  106.955918] Modules linked in: cmac bnep cpufreq_userspace cpufreq_powersave cpufreq_conservative snd_hda_codec_hdmi ext4 mbcache jbd2 fscrypto ecb dcdbas dell_wmi_descriptor snd_hda_codec_realtek snd_hda_codec_generic joydev arc4 hid_multitouch intel_rapl snd_soc_skl x86_pkg_temp_thermal intel_powerclamp snd_soc_skl_ipc snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core snd_compress coretemp btusb kvm_intel btrtl btbcm btintel uvcvideo iwlmvm snd_hda_intel kvm videobuf2_vmalloc irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel bluetooth mac80211 snd_hda_codec videobuf2_memops snd_hda_core videobuf2_v4l2 videobuf2_common nouveau snd_hwdep intel_cstate snd_pcm videodev drbg acer_wmi wmi_bmof iwlwifi sparse_keymap snd_timer intel_uncore ansi_cprng
[  106.955942]  media ecdh_generic snd cfg80211 i915 crc16 intel_rapl_perf mxm_wmi evdev iTCO_wdt rtsx_pci_ms ttm soundcore serio_raw iTCO_vendor_support pcspkr tpm_crb rfkill memstick drm_kms_helper tpm_tis tpm_tis_core idma64 intel_lpss_pci tpm video intel_lpss mei_me drm acpi_pad rng_core battery mei wmi intel_pch_thermal ac button pcc_cpufreq i2c_algo_bit uinput uas btrfs xor zstd_decompress zstd_compress xxhash usb_storage raid6_pq libcrc32c crc32c_generic hid_generic usbhid sg sr_mod cdrom sd_mod crc32c_intel rtsx_pci_sdmmc ahci xhci_pci libahci mmc_core xhci_hcd libata aesni_intel aes_x86_64 r8169 usbcore crypto_simd scsi_mod cryptd glue_helper i2c_hid libphy rtsx_pci i2c_i801 hid usb_common thermal
[  106.955976] CPU: 2 PID: 2636 Comm: Xorg.wrap Tainted: G        W         4.19.0-0.bpo.1-amd64 #1 Debian 4.19.12-1~bpo9+1
[  106.955977] Hardware name: Acer Aspire E5-576G/Ironman_SK, BIOS V1.29 07/21/2017
[  106.955998] RIP: 0010:nvkm_pmu_reset+0x14c/0x160 [nouveau]
[  106.955999] Code: 5c 41 5d 41 5e c3 48 8b 7d 10 48 8b 5f 50 48 85 db 74 24 e8 b6 11 cf d5 48 89 da 48 89 c6 48 c7 c7 75 7a f8 c0 e8 c4 e7 84 d5 <0f> 0b e9 42 ff ff ff 48 8b 5f 10 eb ab 48 8b 5f 10 eb d6 90 0f 1f
[  106.956000] RSP: 0018:ffffa06241517880 EFLAGS: 00010282
[  106.956001] RAX: 0000000000000000 RBX: ffff9106a48f7c60 RCX: 0000000000000006
[  106.956002] RDX: 0000000000000007 RSI: 0000000000000092 RDI: ffff9106a6a966a0
[  106.956002] RBP: ffff9106a3e02800 R08: 0000000000000001 R09: 00000000000003cf
[  106.956003] R10: ffff9106a15e9000 R11: 0000000000000000 R12: ffff9106a1fe6600
[  106.956003] R13: ffff91069e4fc000 R14: 000000186ff06f20 R15: ffffa06241517ac8
[  106.956004] FS:  00007fdfa24ba740(0000) GS:ffff9106a6a80000(0000) knlGS:0000000000000000
[  106.956005] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[  106.956006] CR2: 0000561871682d60 CR3: 000000025fe0c004 CR4: 00000000003606e0
[  106.956006] Call Trace:
[  106.956029]  nvkm_pmu_init+0x16/0x40 [nouveau]
[  106.956041]  nvkm_subdev_init+0x95/0x1f0 [nouveau]
[  106.956063]  nvkm_device_init+0x169/0x270 [nouveau]
[  106.956083]  nvkm_udevice_init+0x41/0x60 [nouveau]
[  106.956098]  nvkm_object_init+0x3e/0x190 [nouveau]
[  106.956110]  nvkm_object_init+0xb1/0x190 [nouveau]
[  106.956121]  nvkm_object_init+0xb1/0x190 [nouveau]
[  106.956142]  nouveau_do_resume+0x28/0x150 [nouveau]
[  106.956163]  nouveau_pmops_runtime_resume+0x88/0x160 [nouveau]
[  106.956166]  ? pci_restore_standard_config+0x40/0x40
[  106.956167]  pci_pm_runtime_resume+0x78/0xb0
[  106.956169]  __rpm_callback+0xc3/0x1c0
[  106.956172]  ? __switch_to_asm+0x40/0x70
[  106.956173]  ? pci_restore_standard_config+0x40/0x40
[  106.956174]  rpm_callback+0x1f/0x70
[  106.956175]  ? pci_restore_standard_config+0x40/0x40
[  106.956175]  rpm_resume+0x4fb/0x710
[  106.956177]  __pm_runtime_resume+0x47/0x70
[  106.956196]  nouveau_drm_open+0x3b/0x1b0 [nouveau]
[  106.956199]  ? refcount_inc_checked+0x5/0x30
[  106.956200]  ? apparmor_capable+0x70/0xb0
[  106.956215]  drm_file_alloc+0x16b/0x240 [drm]
[  106.956221]  drm_open+0xa7/0x210 [drm]
[  106.956227]  ? drm_dev_enter+0x19/0x40 [drm]
[  106.956233]  drm_stub_open+0xb0/0xe0 [drm]
[  106.956235]  chrdev_open+0xbe/0x1d0
[  106.956237]  ? cdev_put+0x20/0x20
[  106.956238]  do_dentry_open+0x1e1/0x320
[  106.956240]  path_openat+0x76c/0x13e0
[  106.956269]  ? intel_atomic_commit+0x2b1/0x2f0 [i915]
[  106.956278]  ? restore_fbdev_mode_atomic+0x19d/0x1d0 [drm_kms_helper]
[  106.956279]  do_filp_open+0x99/0x110
[  106.956286]  ? drm_client_dev_restore+0x3e/0xb0 [drm]
[  106.956287]  ? __check_object_size+0x9d/0x1a0
[  106.956288]  ? do_sys_open+0x12e/0x210
[  106.956289]  do_sys_open+0x12e/0x210
[  106.956292]  do_syscall_64+0x55/0x110
[  106.956293]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[  106.956294] RIP: 0033:0x7fdfa1970820
[  106.956296] Code: 73 01 c3 48 8b 0d 88 77 20 00 f7 d8 64 89 01 48 83 c8 ff c3 66 0f 1f 44 00 00 83 3d a9 bb 20 00 00 75 10 b8 02 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 1e f6 ff ff 48 89 04 24
[  106.956296] RSP: 002b:00007fff12966d68 EFLAGS: 00000246 ORIG_RAX: 0000000000000002
[  106.956298] RAX: ffffffffffffffda RBX: 00007fff12966e70 RCX: 00007fdfa1970820
[  106.956298] RDX: 00007fff12966e7e RSI: 0000000000000002 RDI: 00007fff12966e70
[  106.956299] RBP: 0000000000000001 R08: 0000000000000001 R09: 000000000000000e
[  106.956299] R10: 0000000000000064 R11: 0000000000000246 R12: 00007fff12966d90
[  106.956300] R13: 0000000000000001 R14: 0000000000000001 R15: 0000000000000004
[  106.956301] ---[ end trace 78a6cf067b8d2747 ]---
[  107.021802] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  112.199738] elogind[2439]: New session 1 of user sphere.
[  113.480096] ahci 0000:00:17.0: port does not support device sleep
[  113.720032] Bluetooth: RFCOMM TTY layer initialized
[  113.720038] Bluetooth: RFCOMM socket layer initialized
[  113.720042] Bluetooth: RFCOMM ver 1.11
[  117.630699] usb 1-5: USB disconnect, device number 3
[  159.801622] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[  170.637831] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[  452.012969] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  458.522862] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null)
[  519.970960] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  531.809641] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[  539.189705] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[  550.031960] tun: Universal TUN/TAP device driver, 1.6
[  562.880086] ------------[ cut here ]------------
[  562.880099] nouveau 0000:01:00.0: timeout
[  562.880189] WARNING: CPU: 4 PID: 4829 at /build/linux-Ut6wTa/linux-4.19.12/drivers/gpu/drm/nouveau/nvkm/subdev/pmu/base.c:86 nvkm_pmu_reset+0x14c/0x160 [nouveau]
[  562.880189] Modules linked in: ip6t_REJECT nf_reject_ipv6 tun ip6table_filter ip6_tables iptable_filter ip_tables x_tables ctr ccm rfcomm cmac bnep cpufreq_userspace cpufreq_powersave cpufreq_conservative snd_hda_codec_hdmi ext4 mbcache jbd2 fscrypto ecb dcdbas dell_wmi_descriptor snd_hda_codec_realtek snd_hda_codec_generic joydev arc4 hid_multitouch intel_rapl snd_soc_skl x86_pkg_temp_thermal intel_powerclamp snd_soc_skl_ipc snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core snd_compress coretemp btusb kvm_intel btrtl btbcm btintel uvcvideo iwlmvm snd_hda_intel kvm videobuf2_vmalloc irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel bluetooth mac80211 snd_hda_codec videobuf2_memops snd_hda_core videobuf2_v4l2 videobuf2_common nouveau snd_hwdep
[  562.880213]  intel_cstate snd_pcm videodev drbg acer_wmi wmi_bmof iwlwifi sparse_keymap snd_timer intel_uncore ansi_cprng media ecdh_generic snd cfg80211 i915 crc16 intel_rapl_perf mxm_wmi evdev iTCO_wdt rtsx_pci_ms ttm soundcore serio_raw iTCO_vendor_support pcspkr tpm_crb rfkill memstick drm_kms_helper tpm_tis tpm_tis_core idma64 intel_lpss_pci tpm video intel_lpss mei_me drm acpi_pad rng_core battery mei wmi intel_pch_thermal ac button pcc_cpufreq i2c_algo_bit uinput uas btrfs xor zstd_decompress zstd_compress xxhash usb_storage raid6_pq libcrc32c crc32c_generic hid_generic usbhid sg sr_mod cdrom sd_mod crc32c_intel rtsx_pci_sdmmc ahci xhci_pci libahci mmc_core xhci_hcd libata aesni_intel aes_x86_64 r8169 usbcore crypto_simd scsi_mod cryptd glue_helper i2c_hid libphy rtsx_pci i2c_i801 hid usb_common
[  562.880246]  thermal
[  562.880249] CPU: 4 PID: 4829 Comm: riot-web Tainted: G        W         4.19.0-0.bpo.1-amd64 #1 Debian 4.19.12-1~bpo9+1
[  562.880250] Hardware name: Acer Aspire E5-576G/Ironman_SK, BIOS V1.29 07/21/2017
[  562.880271] RIP: 0010:nvkm_pmu_reset+0x14c/0x160 [nouveau]
[  562.880273] Code: 5c 41 5d 41 5e c3 48 8b 7d 10 48 8b 5f 50 48 85 db 74 24 e8 b6 11 cf d5 48 89 da 48 89 c6 48 c7 c7 75 7a f8 c0 e8 c4 e7 84 d5 <0f> 0b e9 42 ff ff ff 48 8b 5f 10 eb ab 48 8b 5f 10 eb d6 90 0f 1f
[  562.880273] RSP: 0018:ffffa06243b83b48 EFLAGS: 00010282
[  562.880274] RAX: 0000000000000000 RBX: ffff9106a48f7c60 RCX: 0000000000000006
[  562.880275] RDX: 0000000000000007 RSI: 0000000000000086 RDI: ffff9106a6b166a0
[  562.880276] RBP: ffff9106a3e02800 R08: 0000000000000001 R09: 0000000000000429
[  562.880276] R10: ffff91067b4fc000 R11: 0000000000000000 R12: ffff9106a1fe6600
[  562.880277] R13: ffff91069e4fc000 R14: 0000008297243580 R15: ffffa06243b83d90
[  562.880278] FS:  00007ff252ac8a00(0000) GS:ffff9106a6b00000(0000) knlGS:0000000000000000
[  562.880278] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[  562.880279] CR2: 00007fb9e40c0000 CR3: 000000020bc32001 CR4: 00000000003606e0
[  562.880280] Call Trace:
[  562.880302]  nvkm_pmu_init+0x16/0x40 [nouveau]
[  562.880315]  nvkm_subdev_init+0x95/0x1f0 [nouveau]
[  562.880337]  nvkm_device_init+0x169/0x270 [nouveau]
[  562.880357]  nvkm_udevice_init+0x41/0x60 [nouveau]
[  562.880369]  nvkm_object_init+0x3e/0x190 [nouveau]
[  562.880381]  nvkm_object_init+0xb1/0x190 [nouveau]
[  562.880393]  nvkm_object_init+0xb1/0x190 [nouveau]
[  562.880415]  nouveau_do_resume+0x28/0x150 [nouveau]
[  562.880435]  nouveau_pmops_runtime_resume+0x88/0x160 [nouveau]
[  562.880438]  ? pci_restore_standard_config+0x40/0x40
[  562.880439]  pci_pm_runtime_resume+0x78/0xb0
[  562.880441]  __rpm_callback+0xc3/0x1c0
[  562.880442]  ? pci_restore_standard_config+0x40/0x40
[  562.880443]  rpm_callback+0x1f/0x70
[  562.880444]  ? pci_restore_standard_config+0x40/0x40
[  562.880445]  rpm_resume+0x4fb/0x710
[  562.880447]  pm_runtime_barrier+0x87/0xa0
[  562.880449]  pci_config_pm_runtime_get+0x36/0x50
[  562.880450]  pci_read_config+0x8c/0x280
[  562.880452]  ? _cond_resched+0x16/0x40
[  562.880454]  ? __kmalloc+0x60/0x1f0
[  562.880456]  kernfs_fop_read+0xa9/0x180
[  562.880458]  vfs_read+0x91/0x130
[  562.880460]  ksys_read+0x52/0xc0
[  562.880461]  do_syscall_64+0x55/0x110
[  562.880463]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[  562.880464] RIP: 0033:0x7ff25205e20d
[  562.880465] Code: c1 20 00 00 75 10 b8 00 00 00 00 0f 05 48 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 4e fc ff ff 48 89 04 24 b8 00 00 00 00 0f 05 <48> 8b 3c 24 48 89 c2 e8 97 fc ff ff 48 89 d0 48 83 c4 08 48 3d 01
[  562.880466] RSP: 002b:00007ffdabdd70e0 EFLAGS: 00000293 ORIG_RAX: 0000000000000000
[  562.880467] RAX: ffffffffffffffda RBX: 000017a13862e8f6 RCX: 00007ff25205e20d
[  562.880468] RDX: 0000000000000040 RSI: 00007ffdabdd70f0 RDI: 000000000000000f
[  562.880468] RBP: 000000000000000f R08: 000017a1386e1073 R09: 0000000000000022
[  562.880469] R10: 0000000000000073 R11: 0000000000000293 R12: 00007ffdabdd8208
[  562.880469] R13: 00000000000000e2 R14: 00007ffdabdd82a0 R15: 0000000000000001
[  562.880470] ---[ end trace 78a6cf067b8d2748 ]---
[  650.871892] ------------[ cut here ]------------
[  650.871894] nouveau 0000:01:00.0: timeout
[  650.871960] WARNING: CPU: 2 PID: 5335 at /build/linux-Ut6wTa/linux-4.19.12/drivers/gpu/drm/nouveau/nvkm/subdev/pmu/base.c:86 nvkm_pmu_reset+0x14c/0x160 [nouveau]
[  650.871960] Modules linked in: ip6t_REJECT nf_reject_ipv6 tun ip6table_filter ip6_tables iptable_filter ip_tables x_tables ctr ccm rfcomm cmac bnep cpufreq_userspace cpufreq_powersave cpufreq_conservative snd_hda_codec_hdmi ext4 mbcache jbd2 fscrypto ecb dcdbas dell_wmi_descriptor snd_hda_codec_realtek snd_hda_codec_generic joydev arc4 hid_multitouch intel_rapl snd_soc_skl x86_pkg_temp_thermal intel_powerclamp snd_soc_skl_ipc snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core snd_compress coretemp btusb kvm_intel btrtl btbcm btintel uvcvideo iwlmvm snd_hda_intel kvm videobuf2_vmalloc irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel bluetooth mac80211 snd_hda_codec videobuf2_memops snd_hda_core videobuf2_v4l2 videobuf2_common nouveau snd_hwdep
[  650.871985]  intel_cstate snd_pcm videodev drbg acer_wmi wmi_bmof iwlwifi sparse_keymap snd_timer intel_uncore ansi_cprng media ecdh_generic snd cfg80211 i915 crc16 intel_rapl_perf mxm_wmi evdev iTCO_wdt rtsx_pci_ms ttm soundcore serio_raw iTCO_vendor_support pcspkr tpm_crb rfkill memstick drm_kms_helper tpm_tis tpm_tis_core idma64 intel_lpss_pci tpm video intel_lpss mei_me drm acpi_pad rng_core battery mei wmi intel_pch_thermal ac button pcc_cpufreq i2c_algo_bit uinput uas btrfs xor zstd_decompress zstd_compress xxhash usb_storage raid6_pq libcrc32c crc32c_generic hid_generic usbhid sg sr_mod cdrom sd_mod crc32c_intel rtsx_pci_sdmmc ahci xhci_pci libahci mmc_core xhci_hcd libata aesni_intel aes_x86_64 r8169 usbcore crypto_simd scsi_mod cryptd glue_helper i2c_hid libphy rtsx_pci i2c_i801 hid usb_common
[  650.872020]  thermal
[  650.872023] CPU: 2 PID: 5335 Comm: riot-web Tainted: G        W         4.19.0-0.bpo.1-amd64 #1 Debian 4.19.12-1~bpo9+1
[  650.872024] Hardware name: Acer Aspire E5-576G/Ironman_SK, BIOS V1.29 07/21/2017
[  650.872045] RIP: 0010:nvkm_pmu_reset+0x14c/0x160 [nouveau]
[  650.872046] Code: 5c 41 5d 41 5e c3 48 8b 7d 10 48 8b 5f 50 48 85 db 74 24 e8 b6 11 cf d5 48 89 da 48 89 c6 48 c7 c7 75 7a f8 c0 e8 c4 e7 84 d5 <0f> 0b e9 42 ff ff ff 48 8b 5f 10 eb ab 48 8b 5f 10 eb d6 90 0f 1f
[  650.872047] RSP: 0018:ffffa062454d7b48 EFLAGS: 00010282
[  650.872048] RAX: 0000000000000000 RBX: ffff9106a48f7c60 RCX: 0000000000000006
[  650.872049] RDX: 0000000000000007 RSI: 0000000000000086 RDI: ffff9106a6a966a0
[  650.872049] RBP: ffff9106a3e02800 R08: 0000000000000001 R09: 0000000000000460
[  650.872050] R10: ffff9106a15ec000 R11: 0000000000000000 R12: ffff9106a1fe6600
[  650.872051] R13: ffff91069e4fc000 R14: 0000009713dcd7a0 R15: ffffa062454d7d90
[  650.872052] FS:  00007f8cd272aa00(0000) GS:ffff9106a6a80000(0000) knlGS:0000000000000000
[  650.872052] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[  650.872053] CR2: 0000078cdad3a000 CR3: 0000000247cba005 CR4: 00000000003606e0
[  650.872054] Call Trace:
[  650.872077]  nvkm_pmu_init+0x16/0x40 [nouveau]
[  650.872090]  nvkm_subdev_init+0x95/0x1f0 [nouveau]
[  650.872112]  nvkm_device_init+0x169/0x270 [nouveau]
[  650.872132]  nvkm_udevice_init+0x41/0x60 [nouveau]
[  650.872144]  nvkm_object_init+0x3e/0x190 [nouveau]
[  650.872156]  nvkm_object_init+0xb1/0x190 [nouveau]
[  650.872168]  nvkm_object_init+0xb1/0x190 [nouveau]
[  650.872189]  nouveau_do_resume+0x28/0x150 [nouveau]
[  650.872210]  nouveau_pmops_runtime_resume+0x88/0x160 [nouveau]
[  650.872214]  ? pci_restore_standard_config+0x40/0x40
[  650.872215]  pci_pm_runtime_resume+0x78/0xb0
[  650.872217]  __rpm_callback+0xc3/0x1c0
[  650.872218]  ? pci_restore_standard_config+0x40/0x40
[  650.872219]  rpm_callback+0x1f/0x70
[  650.872220]  ? pci_restore_standard_config+0x40/0x40
[  650.872221]  rpm_resume+0x4fb/0x710
[  650.872222]  pm_runtime_barrier+0x87/0xa0
[  650.872224]  pci_config_pm_runtime_get+0x36/0x50
[  650.872226]  pci_read_config+0x8c/0x280
[  650.872228]  ? _cond_resched+0x16/0x40
[  650.872230]  ? __kmalloc+0x60/0x1f0
[  650.872232]  kernfs_fop_read+0xa9/0x180
[  650.872234]  vfs_read+0x91/0x130
[  650.872236]  ksys_read+0x52/0xc0
[  650.872238]  do_syscall_64+0x55/0x110
[  650.872240]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[  650.872241] RIP: 0033:0x7f8cd1cc020d
[  650.872242] Code: c1 20 00 00 75 10 b8 00 00 00 00 0f 05 48 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 4e fc ff ff 48 89 04 24 b8 00 00 00 00 0f 05 <48> 8b 3c 24 48 89 c2 e8 97 fc ff ff 48 89 d0 48 83 c4 08 48 3d 01
[  650.872243] RSP: 002b:00007fff708e98b0 EFLAGS: 00000293 ORIG_RAX: 0000000000000000
[  650.872244] RAX: ffffffffffffffda RBX: 0000089816c8e8f6 RCX: 00007f8cd1cc020d
[  650.872244] RDX: 0000000000000040 RSI: 00007fff708e98c0 RDI: 000000000000000f
[  650.872245] RBP: 000000000000000f R08: 0000089816d40073 R09: 0000000000000022
[  650.872245] R10: 0000000000000073 R11: 0000000000000293 R12: 00007fff708ea9d8
[  650.872246] R13: 00000000000000e2 R14: 00007fff708eaa70 R15: 0000000000000001
[  650.872247] ---[ end trace 78a6cf067b8d2749 ]---
[  720.798409] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[  726.501525] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[  730.053759] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[  734.105650] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[  735.605482] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[  968.977903] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[ 1002.393624] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[ 1111.849708] i2c_hid i2c-ELAN0501:00: i2c_hid_get_input: incomplete report (14/65535)
[ 1128.796105] ------------[ cut here ]------------
[ 1128.796106] nouveau 0000:01:00.0: timeout
[ 1128.796171] WARNING: CPU: 0 PID: 8008 at /build/linux-Ut6wTa/linux-4.19.12/drivers/gpu/drm/nouveau/nvkm/subdev/pmu/base.c:86 nvkm_pmu_reset+0x14c/0x160 [nouveau]
[ 1128.796171] Modules linked in: ip6t_REJECT nf_reject_ipv6 tun ip6table_filter ip6_tables iptable_filter ip_tables x_tables ctr ccm rfcomm cmac bnep cpufreq_userspace cpufreq_powersave cpufreq_conservative snd_hda_codec_hdmi ext4 mbcache jbd2 fscrypto ecb dcdbas dell_wmi_descriptor snd_hda_codec_realtek snd_hda_codec_generic joydev arc4 hid_multitouch intel_rapl snd_soc_skl x86_pkg_temp_thermal intel_powerclamp snd_soc_skl_ipc snd_soc_sst_ipc snd_soc_sst_dsp snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi snd_soc_core snd_compress coretemp btusb kvm_intel btrtl btbcm btintel uvcvideo iwlmvm snd_hda_intel kvm videobuf2_vmalloc irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel bluetooth mac80211 snd_hda_codec videobuf2_memops snd_hda_core videobuf2_v4l2 videobuf2_common nouveau snd_hwdep
[ 1128.796195]  intel_cstate snd_pcm videodev drbg acer_wmi wmi_bmof iwlwifi sparse_keymap snd_timer intel_uncore ansi_cprng media ecdh_generic snd cfg80211 i915 crc16 intel_rapl_perf mxm_wmi evdev iTCO_wdt rtsx_pci_ms ttm soundcore serio_raw iTCO_vendor_support pcspkr tpm_crb rfkill memstick drm_kms_helper tpm_tis tpm_tis_core idma64 intel_lpss_pci tpm video intel_lpss mei_me drm acpi_pad rng_core battery mei wmi intel_pch_thermal ac button pcc_cpufreq i2c_algo_bit uinput uas btrfs xor zstd_decompress zstd_compress xxhash usb_storage raid6_pq libcrc32c crc32c_generic hid_generic usbhid sg sr_mod cdrom sd_mod crc32c_intel rtsx_pci_sdmmc ahci xhci_pci libahci mmc_core xhci_hcd libata aesni_intel aes_x86_64 r8169 usbcore crypto_simd scsi_mod cryptd glue_helper i2c_hid libphy rtsx_pci i2c_i801 hid usb_common
[ 1128.796230]  thermal
[ 1128.796233] CPU: 0 PID: 8008 Comm: icecat Tainted: G        W         4.19.0-0.bpo.1-amd64 #1 Debian 4.19.12-1~bpo9+1
[ 1128.796234] Hardware name: Acer Aspire E5-576G/Ironman_SK, BIOS V1.29 07/21/2017
[ 1128.796255] RIP: 0010:nvkm_pmu_reset+0x14c/0x160 [nouveau]
[ 1128.796256] Code: 5c 41 5d 41 5e c3 48 8b 7d 10 48 8b 5f 50 48 85 db 74 24 e8 b6 11 cf d5 48 89 da 48 89 c6 48 c7 c7 75 7a f8 c0 e8 c4 e7 84 d5 <0f> 0b e9 42 ff ff ff 48 8b 5f 10 eb ab 48 8b 5f 10 eb d6 90 0f 1f
[ 1128.796257] RSP: 0018:ffffa06247607b48 EFLAGS: 00010282
[ 1128.796258] RAX: 0000000000000000 RBX: ffff9106a48f7c60 RCX: 0000000000000006
[ 1128.796259] RDX: 0000000000000007 RSI: 0000000000000086 RDI: ffff9106a6a166a0
[ 1128.796259] RBP: ffff9106a3e02800 R08: 0000000000000001 R09: 000000000000049f
[ 1128.796260] R10: ffff910658f73000 R11: 0000000000000000 R12: ffff9106a1fe6600
[ 1128.796261] R13: ffff91069e4fc000 R14: 000001065a5dffe0 R15: ffffa06247607d90
[ 1128.796262] FS:  00007ff77bd13740(0000) GS:ffff9106a6a00000(0000) knlGS:0000000000000000
[ 1128.796262] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1128.796263] CR2: 0000000001bcd864 CR3: 0000000232734004 CR4: 00000000003606f0
[ 1128.796264] Call Trace:
[ 1128.796286]  nvkm_pmu_init+0x16/0x40 [nouveau]
[ 1128.796299]  nvkm_subdev_init+0x95/0x1f0 [nouveau]
[ 1128.796321]  nvkm_device_init+0x169/0x270 [nouveau]
[ 1128.796341]  nvkm_udevice_init+0x41/0x60 [nouveau]
[ 1128.796354]  nvkm_object_init+0x3e/0x190 [nouveau]
[ 1128.796365]  nvkm_object_init+0xb1/0x190 [nouveau]
[ 1128.796377]  nvkm_object_init+0xb1/0x190 [nouveau]
[ 1128.796398]  nouveau_do_resume+0x28/0x150 [nouveau]
[ 1128.796419]  nouveau_pmops_runtime_resume+0x88/0x160 [nouveau]
[ 1128.796422]  ? pci_restore_standard_config+0x40/0x40
[ 1128.796423]  pci_pm_runtime_resume+0x78/0xb0
[ 1128.796425]  __rpm_callback+0xc3/0x1c0
[ 1128.796426]  ? pci_restore_standard_config+0x40/0x40
[ 1128.796427]  rpm_callback+0x1f/0x70
[ 1128.796428]  ? pci_restore_standard_config+0x40/0x40
[ 1128.796429]  rpm_resume+0x4fb/0x710
[ 1128.796431]  pm_runtime_barrier+0x87/0xa0
[ 1128.796433]  pci_config_pm_runtime_get+0x36/0x50
[ 1128.796434]  pci_read_config+0x8c/0x280
[ 1128.796436]  ? _cond_resched+0x16/0x40
[ 1128.796438]  ? __kmalloc+0x60/0x1f0
[ 1128.796439]  kernfs_fop_read+0xa9/0x180
[ 1128.796441]  vfs_read+0x91/0x130
[ 1128.796443]  ksys_read+0x52/0xc0
[ 1128.796444]  do_syscall_64+0x55/0x110
[ 1128.796446]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 1128.796447] RIP: 0033:0x7ff77b90b20d
[ 1128.796448] Code: c1 20 00 00 75 10 b8 00 00 00 00 0f 05 48 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 4e fc ff ff 48 89 04 24 b8 00 00 00 00 0f 05 <48> 8b 3c 24 48 89 c2 e8 97 fc ff ff 48 89 d0 48 83 c4 08 48 3d 01
[ 1128.796449] RSP: 002b:00007ffc3664b9f0 EFLAGS: 00000293 ORIG_RAX: 0000000000000000
[ 1128.796450] RAX: ffffffffffffffda RBX: 00007ff77a8557c6 RCX: 00007ff77b90b20d
[ 1128.796451] RDX: 0000000000000040 RSI: 00007ffc3664ba00 RDI: 0000000000000007
[ 1128.796451] RBP: 0000000000000007 R08: 00007ff76a71e073 R09: 0000000000000022
[ 1128.796452] R10: 0000000000000073 R11: 0000000000000293 R12: 00007ffc3664cb18
[ 1128.796452] R13: 00000000000000e2 R14: 00007ffc3664cbb0 R15: 0000000000000001
[ 1128.796453] ---[ end trace 78a6cf067b8d274a ]---
#8 2019-02-17 09:46:27
PedroReina
Re: ethernet and login manager concerns
It seems to me that the low level staff of eth0 is right in your two systems. The relevant line of dmesg being:
So, I think that the difference could be the logical configurations. Do you have installed a network manager (network-manager, wicd,...)? In any case, please post your /etc/network/interfaces
