#1 2019-02-03 14:30:30
alsen
[SOLVED] Ascii kernel for SMP (DELL T430 dual cpu)
Hi to all,
Can the Ascii Devuan kernel be installed on a server with two CPUs  using the two CPUs ?
or is it necessary to compile the kernel with this option? if not, is it a version already available somewhere ?
Thanks
Alberto
Maker and a fun of Devuan and enthusiastic about Aquinas
#2 2019-02-03 16:01:17
Re: [SOLVED] Ascii kernel for SMP (DELL T430 dual cpu)
All current kernels have SMP enabled already since many years. Install it and you are done.
Regards, Rolf
