#1 2019-01-20 14:16:31
brday
Latest vs Quarterly software for devuan ASCII
Hello devuan community!
I would like to have a completely updated system with the latest free software, what repositories should I add and which directory?
#2 2019-01-27 10:43:56
xinomilo
Re: Latest vs Quarterly software for devuan ASCII
latest software include latest bugs as well, so you don't get a stable version that way... if you're fine with that (dealing with new bugs/researching workarounds every now and then),  add the Devuan beowulf/ceres repos (testing/unstable). you can find instructions elsewhere in this forum.
if you do go with beowulf, check this threads also :
https://dev1galaxy.org/viewtopic.php?id=2301
https://dev1galaxy.org/viewtopic.php?id=2584
