#1 2019-01-14 22:10:55
AntoFox
MATE 1.21 on devuan beowulf
Hi all,
today I have uploaded a new experimental version of MATE desktop on hezeh.org, if anyone wants to try it, use the following link:
http://hezeh.org/mate-1.21-on-devuan-beowulf
let me know if somethings is wrong
#2 2019-01-15 17:13:24
xinomilo
Re: MATE 1.21 on devuan beowulf
some issues so far with MATE 1.21 ...
mate-control-center doesn't start :
~ mate-control-center
mate-control-center: symbol lookup error: /usr/lib/x86_64-linux-gnu/libmate-slab.so.0: undefined symbol: matemenu_tree_new
mate-screensaver, similar error :
mate-screensaver-preferences: symbol lookup error: mate-screensaver-preferences: undefined symbol: matemenu_tree_new
mate-power-manager also suffers from the same error as the devuan packages. systray icon broken (triangle with exclamation mark) and no power events recognised. suspend only works from menu, laptop lid closing doesn't trigger suspend as it should.
pinning and downgrading mate-power-manager & mate-power-manager-common to version 1.20.0-1+hezeh1 from hezeh.org/ascii and everything there works again.
clock applet was missing after 1st reboot, but came back after a 2nd one. (?)
mate-notification-daemon only works with "standard theme". all other themes end in error :
Error while displaying notification:
GDBus.Error.org.freedesktop.DBus.Error.NoReply: Message recient disconnected from message bus without replying
also dmesg error :
mate-notificati[4273]: segfault at ee ip 00007fd6163e0b4f sp 00007ffc261d0a10 error 4 in libgdk-3.so.0.2402.0[7fd6163a9000+78000]
thanks,
#3 2019-01-15 21:26:12
ChuangTzu
Hi Anto,
Are you familiar with Willy Raharjo, he packages and maintains Mate for Slackware?  It could be beneficial since Devuan and Slackware both have an interest in not having systemd.  Willy is quite the wizard with packaging, scripting, hacking etc...  smile
https://plus.google.com/+WillySudiartoRaharjo
https://slackblogs.blogspot.com/
https://github.com/mateslackbuilds/msb
https://mateslackbuilds.github.io/
#4 2019-01-16 08:52:45
xinomilo
another bug with mate-screensaver. before upgrade it was set to blank screen after 1 hour of idleness. now that it's not working, i guess it's gone back to defaults (10mins). problem is that no button can bring the screen back after blanking...
only solution i found is to switch to tty1 or some other console and then back to X (ctrl+alt+f7) and everythings looks ok again. irritating when eg. watching videos >10mins....
blindly pressing buttons while screen is blank, and they seem to respond to apps (can pause video, switch windows, etc) ,but blank screen remains, till i do the above.
#5 2019-01-17 22:26:24
AntoFox
Hi guys,
@xinomilo
for the moment packages that give problems are removed, however there are still some problems
@ChuangTzu
never heard, hope in collaboration
remember MATE on beowulf (for the moment) is not testing but experimental
#6 2019-01-18 11:24:33
xinomilo
antofox thanks for the notice.
moved back to previous "stable" MATE setup for devuan beowulf:
mate packages from official devuan beowulf/testing, except for mate-power-manager[-common] that are pinned to 1.20.0-1+hezeh1 from hezeh.org/ascii.
