#1 2018-12-19 15:15:14
GNUser
way for shell script to show a string in notification area? [SOLVED]
I need a recommendation for a command-line utility that will show text in notification area. I am familiar with and love yad, but it can only put icons--not text--in notification area/system tray. I'm also familiar with notify-send, but this utility shows pop-up notifications, which is not what I need.
One of my shell scripts needs to show a string in the notification area, and the string needs to stay there until it is updated (similar to what time/date panel applet does). I've searched the interwebs ad nauseam but am still empty-handed.
Any ideas? I just need utility name, not a how-to.
#2 2018-12-20 10:03:51
KatolaZ
Re: way for shell script to show a string in notification area? [SOLVED]
Depending on yout definition of "notification area", dzen2 could be what you are looking for.
HND
katolaZ
#3 2018-12-20 15:33:19
GNUser
Yes, this is perfect. It doesn't display the string at notification area by default, but it allows specifying x and y coordinates of where to display the string.
Thank you very much for this, KatolaZ. Exactly what I needed!
