#1 2018-12-18 07:17:18
spartrekus
Gnumeric installs Gnome
Hello,
The simple command : apt-get install gnumeric will result in  a  lot of packages, which actually is part of gnome (evince,... and "millions" things).
The deb dependencies are therefore faulty.
Would it be some concern from Devuan about such issue(s)?
thank you
#2 2018-12-18 11:25:23
MiyoLinux
Re: Gnumeric installs Gnome
I checked this with...
apt-get install gnumeric ...vs... apt-get install gnumeric --no-install-recommends
Here are my results (please note: I didn't install it either way, so I don't know if its functionality was affected)
With apt-get install gnumeric...
dan@miyolinux:~$ sudo apt-get install gnumeric
[sudo] password for dan:
Building dependency tree
  evince evince-common gnome-desktop3-data gnumeric-common gnumeric-doc
  libdjvulibre-text libdjvulibre21 libevdocument3-4 libevview3-3
  libgnome-desktop-3-12 libgoffice-0.10-10 libgoffice-0.10-10-common
  libkpathsea6 libspectre1 lp-solve pxlib1
Suggested packages:
  nautilus-sendto unrar gnumeric-plugins-extra docbook-xsl
  evince evince-common gnome-desktop3-data gnumeric gnumeric-common
  gnumeric-doc libdjvulibre-text libdjvulibre21 libevdocument3-4 libevview3-3
0 upgraded, 17 newly installed, 0 to remove and 0 not upgraded.
Need to get 25.7 MB of archives.
After this operation, 73.7 MB of additional disk space will be used.
With apt-get install gnumeric --no-install-recommends...
dan@miyolinux:~$ sudo apt-get install gnumeric --no-install-recommends
  gnumeric-common libgoffice-0.10-10 libgoffice-0.10-10-common pxlib1
Suggested packages:
Recommended packages:
  gnumeric-doc evince | evince-gtk lp-solve
  gnumeric gnumeric-common libgoffice-0.10-10 libgoffice-0.10-10-common pxlib1
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 7,542 kB of archives.
After this operation, 37.0 MB of additional disk space will be used.
#3 2018-12-24 13:37:21
thierrybo
that is why I switched to "APT::Install-Recommends "false";" a long time ago...
