#1 2018-12-11 01:45:06
UnclePa
[Solved] Nvidia and wine
I'm trying to run a wine 3d program and it says libGL.so.1 cannot be found.  As best I can tell, the 384.130 NVidia drivers do not have 32 bit versions.  Am I correct that I need to install the 32bit and 64bit legacy-340 drivers in order to run wine 3D programs?
#2 2018-12-13 14:35:06
UnclePa
Re: [Solved] Nvidia and wine
Hadn't run any 3D stuff for a few months and nothing would work.  Even glxinfo crashed.  Not sure what caused it or exactly what fixed it but probably that I did a forced reinstall of all the nvidia packages.
