#1 2018-12-09 13:16:14
Johnnie390
Devuan Ceres Grub 2.02+dfsg1-8 (EFI)
Hello all,
after upgrading Ascii to Ceres (in situ), all went well for a week or so. Last week, after an apt upgrade, the abovementioned Grub version was installed. This leads to a  Grub prompt after boot. Regress/fallback to Grub 2.02~beta3-5 does not help (Grub prompt). Anyone else experiencing same?
I have done the usual grub-install, update-grub stuff etc. with no (apparent) errors. See below -
LC_ALL=C  grub-install  --target=x86_64-efi --bootloader=devuan
Efibootmgr reports -
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0000,0001,0017,0018,0019,001A,001B,001C,001D,001E,001F,0020,0021,0022
Boot0000* devuan    HD(2,GPT,1c827e00-759b-4e15-b15d-6a271b180f3c,0x3a352800,0x168e800)/File(\EFI\devuan\grubx64.efi)
My EFI setup -
root@Pezenas:/Transit# ll /boot/efi/EFI/devuan/
total 1424
   8 drwx------ 3 root root    8192 Dec  9 10:57 .
   8 drwx------ 6 root root    8192 Dec  8 16:45 ..
   8 drwx------ 5 root root    8192 Dec  8 12:54 grub
   8 -rwx------ 1 root root    6028 Dec  9 10:54 grub.cfg
   8 -rwx------ 1 root root     157 Dec  9 10:54 grub.cfg.min
1376 -rwx------ 1 root root 1407904 Dec  9 09:48 grubx64.efi
   8 -rwx------ 1 root root    6028 Dec  9 10:57 .new
lsblk output -
root@Pezenas:/Transit# lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINT
nvme0n1     259:0    0   477G  0 disk
└─nvme0n1p1 259:4    0 465.7G  0 part
  └─md0       9:0    0 931.1G  0 raid0 /
nvme1n1     259:1    0   477G  0 disk
├─nvme1n1p1 259:2    0 465.7G  0 part
│ └─md0       9:0    0 931.1G  0 raid0 /
└─nvme1n1p2 259:3    0  11.3G  0 part  /boot/efi
From the Grub prompt -
set pager=1
set root=(md/0)
linux /boot/vmlinux..... root=/dev/md0
initrd /boot/initrd...
boot
will bring the system up. For obvious reasons, I would prefer to avoid this. smile
It would seem I am not alone here -
https://lists.dyne.org/lurker/message/2 … f7.en.html
Any pointers much appreciated.
Johnnie390
#2 2018-12-09 16:28:28
Re: Devuan Ceres Grub 2.02+dfsg1-8 (EFI)
I haven't tried that yet, but I will let my ceres install take over the boot on this machine. Meanwhile, can you tell me how your grub directory got into the efi partition? The only file I have in any of the efi directories is grubx64.efi. My grub directory is a subdir of /boot, as it has always been.
#3 2018-12-09 17:43:52
grub-efi-amd64  2.02+dfsg1-8 seems to  be working correctly here. I rebooted into my ceres install, checked that the grub version was right and ran grub-install --bootloader-id=nodbus && update-grub.
This installation is on a single partition. No raid, lvm or encryption.
#4 2018-12-10 06:57:32
Johnnie390
Thanks for the reply. Does not help me much though.
Irrespective of the grub directory being in the esp/efi.. tree, I am still stumped. Did you read the link I provided on other person's woes?
Regards,
Johnnie390
#5 2018-12-15 10:38:22
Johnnie390
Hello all,
still landing in the grub prompt... Any pointers/ideas?
Regards,
Johnnie390
#6 2018-12-15 10:52:48
KatolaZ
there is a 2.02+dfsg1-9 in Ceres, which introduced a change to not enforce signature check if Secure Boot is disabled (as it seems to be the case here). Could you please try it?
HND
KatolaZ
#7 2018-12-15 11:12:35
Johnnie390
Hello KatolaZ,
thank you. Will do and report back.
Regards,
Johnnie390
#8 2018-12-15 11:50:57
Johnnie390
Hello all,
which package specifically (2.02+dfsg1-9) should be installed? There are quite a few in the Grub family.
Regards,
Johnnie390
#9 2018-12-15 13:16:30
Johnnie390
Hello all,
answering my own question here...
I uninstalled grub-efi-amd64-signed and re-ran update-grub. Now, no grub prompt. Things work.
Regards,
Johnnie390
