#1 2018-12-06 16:16:13
Giorgos
Dmesg question [SOLVED].
Hi!  smile
How can I see my error bootup messages?
I opened as root the text file /var/log/dmesg, but it doesn't display all of them.
I tried also as root with the dmesg command, with similar results.
What I wanted to see, is a network manager related message, that said it that can't load the respective daemon.
TIA!  cool
G.
#2 2018-12-06 17:17:58
Re: Dmesg question [SOLVED].
For messages coming out during the bootup try control-s to freeze screen output and control-q to restart it. That should stop them long enough to copy them down (or take a photo of the screen).
Chris
#3 2018-12-06 17:50:28
Giorgos
THANKS Chris!!!  big_smile
I pressed ctrl-S and although the messages disappeared from the screen, pressing ctrl-alt-F1 take me to the boot screen again, where I was able to read the message.
