Sorry for a probably stupid question, but which repo should I add to install a firmware-b43-installer package? Package browser from the Devuan website indicates
firmware-b43-installer 019-3 [contrib/kernel - optional]
[Origin: Debian - ascii - contrib]
but I somehow failed to figure out which repo it is. This package is absent in pre-configured repos in the newly-installed x64 ASCII.
Thank you.
see this thread, it may help:
https://dev1galaxy.org/viewtopic.php?id=2340
b43-fwcutter is in contrib, and the firmware can be found at https://sources.openwrt.org/broadcom-wl … .5.tar.bz2.
Hello. As root, open file
/etc/apt/sources.listand add contrib and non-free (if you want) to it. It should look like this
deb http://us.deb.devuan.org/merged ascii main non-free contrib
# deb-src http://us.deb.devuan.org/merged ascii main non-free contrib
deb http://us.deb.devuan.org/merged ascii-security main non-free contrib
# deb-src http://us.deb.devuan.org/merged ascii-security main non-free contrib
deb http://us.deb.devuan.org/merged ascii-updates main non-free contrib
# deb-src http://us.deb.devuan.org/merged ascii-updates main non-free contribWhat economists call over-production is but a production that is above the purchasing power of the worker, who is reduced to poverty by capital and state.
----+- Peter Kropotkin -+----
A little clarification.
b43-fwcutter is a package from repository (contrib). Its an executable that EXTRACTS required firmware from a file, it doesnt supply firmware.
The actual firmware can be obtained from https://openwrt.org/. You need to download the whatever firmware file that matches your particular hardware device. I cant help with what file to download.
You can poke around here:
https://downloads.openwrt.org/releases/18.06.1/targets/
and here:
to determine what file matches your hardware.
Thank you guys, the repos are added, drivers are installed, wifi is working.
dxrobertson I used these instructions to acquire and install the driver:
https://wiki.debian.org/bcm43xx
Looks like everything was done automatically in the background. At least everything that was required from me was just this package.
Thank you.
