Pages: 1
Hello everybody,
so far I had used Debian.
There I put my iptables rules in a script in the directory /etc/network/if-up.d/iptables_on, like on this page.
Unfortunately, this method does not work with Devuan, there I always get an error message.
How should I ideally apply my iptables rules?
I dont know if theres are a better method, but I use to store my custom iptables script at /etc/init.d. Basically that script load iptables from /etc/iptables.rules:
cat /etc/init.d/iptables
#!/bin/bash
/sbin/iptables-restore < /etc/iptables.rulesThen you must link to /etc/rcX.d (by defaul 2)
/etc/rc2.d/S20iptables -> ../init.d/iptablesOffline
Thank you for answering.
Thats the errormessage:
iptables: No chain/target/match by that name.
Bad argument ` '
Try `iptables -h' or 'iptables --help' for more information.
Bad argument ` '
but if i type in every rule, there is no error. ??
The same skript runs finde on my debian/raspbian
@Phoen7x: Looks like what you're doing should work, but bear in mind that scripts in /etc/network/if*.d are run in sort order. So one needs to assign script names so that any dependencies are met.
The way I use to make sure my iptables script is processed in the correct order is to put it in /etc/init.d per @arnauz, then make use of dependency based initialization via the update-rc.d command to sort things out viz /etc/rc?.d.
Hope this helps.
Thank you for your advice.
You mean I should move my script into the folder /etc/init.d? I have not quite understood the order and the dependencies?
In my script I'm just releasing ports.
I have executed this script and in my laptop exit successfully without errors.
But it seems that -m state its deprecated, maybe your iptables version or kernel build dont accept that parameter.
Try to remove or change by -m conntrack --ctstate.
Another way: you can execute line by line in the shell to debug in which exact lines its failing.
To allow resolve DNS, you must add a line accepting UDP output conections, since DNS protocol uses querys throw UDP:
iptables -A OUTPUT -p udp --dport domain -j ACCEPTabout the script exec problem, also you can debug inserting a previous echo by each iptables command, so you can check on which its failing.
Oh sorry, i've forgotten to write. I'm runnig an unbound resolver wich forward all traffic to another resolver via DNS-over-TLS (-dport 853), the rule is therefore obsulete.
This is an good idea!
After a reinstallation of iptables-persistent, this solution worked for me.
I think my script failed because of the -nat -mangle parameters.
Pages: 1
