#1 2018-11-07 19:35:29
GNUser
what deletes contents of /tmp directory? [SOLVED]
Some questions about /tmp:
1. Which utility or service is responsible for deleting the contents of /tmp?
2. Does the deletion happen at time of shutdown or boot?
3. Is there a way to change the deletion settings? (I cannot find /etc/tmp* or /etc/temp*)
Just wondering and trying to better understand things. I'm on Devuan ASCII if it matters.
#2 2018-11-07 19:49:07
GNUser
Re: what deletes contents of /tmp directory? [SOLVED]
1. The checkroot-bootclean.sh service (service file is in /etc/init.d/, link in /etc/rcS.d/)
2. At boot
3. Via TMPTIME variable in /etc/default/rcS
Is this correct?
#3 2018-11-08 13:22:53
Geoff 42
Is /tmp guaranteed to be empty at Boot?
grep tmp /etc/rcS.d/S06checkroot.sh
returns nothing!
As it is fairly common to mount /tmp as a tmpfs, this will tend to leave it empty on a reboot.
Geoff
#4 2018-11-08 13:24:38
Geoff 42
Whoops! I got the wrong file!
grep tmp /etc/rcS.d/S08checkroot-bootclean.sh
	# Clean /tmp, /run and /run/lock.  Remove the .clean files to
	rm -f /tmp/.clean /run/.clean /run/lock/.clean
Sorry!
Geoff
#5 2018-11-08 13:27:38
Geoff 42
The comment in /etc/rcS.d/S08checkroot-bootclean.sh seems to suggest that it is only the mount point that is cleaned out, before anything is mounted over the top of it.
Geoff
#6 2018-11-08 13:59:21
GNUser
Geoff, I was sloppy in post #2. What is in /etc/rcS.d/ is a link, obviously. The actual service file is /etc/init.d/checkroot-bootclean.sh. (I fixed post #2 now.)
First, looking inside the service file I see that it calls the clean_all function, which it sources from /lib/init/bootclean.sh
Then, looking inside /lib/init/bootclean.sh I see at the top that the purpose of its functions is to "Clean /tmp, /run and /var/lock if not mounted as tmpfs". The clean_all function calls clean_tmp
At the end of clean_tmp function definition there are two commands: One is to "remove all old files" and the other removes "all empty directories".
So if /tmp is not mounted as tmpfs, the checkroot-bootclean.sh service deletes old files and empty directories in /tmp but does not seem to guarantee that /tmp will be empty.
That's the story as I understand it, but there probably are some details that I'm missing.
#7 2018-11-08 14:33:02
Geoff 42
But not as sloppy as me! :-)
Geoff
#8 2018-11-08 14:35:01
GNUser
P.S. I've been doing some reading on /tmp and tmpfs and it seems that on Debian/Devuan /tmp is a normal directory by default. For /tmp to be a tmpfs, user has to add an entry in /etc/fstab.
I can confirm that on my ASCII installation /tmp is a regular directory (notice that /tmp does not appear in the last column):
bruno@thinkpad:~$ df -h | grep tmpfs
tmpfs           773M  1.2M  771M   1% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           2.0G   31M  1.9G   2% /run/shm
tmpfs           3.8G     0  3.8G   0% /sys/fs/cgroup
tmpfs           772M   32K  772M   1% /run/user/1000
#9 2018-11-08 16:48:27
Geoff 42
While you can do it in /etc/fstab, you can also choose to use tmpfs for /tmp in /etc/default/tmpfs, where you can set RAMTMP=yes.
I think that the safest assumption about /tmp is that you cannot guarantee that anything in /tmp will survive a reboot, neither can you guarantee that it won't survive.
Geoff
#10 2018-11-08 17:00:20
GNUser
I didn't know that. That's a very nice shortcut. Thank you.
