#1 2018-10-26 01:36:23
Heads up: X Server exploit CVE-2018-14665
I have not seen this posted in the Dev1 forum yet but if it this is the wrong place, please move it as necessary.
A two year old X Server vulnerability has seen the light, reported by Narendra Shinde and Red Hat a couple of days ago, it's CVE-2018-14665.
cve site wrote:
A flaw was found in xorg-x11-server before 1.20.3. An incorrect permission check for -modulepath and -logfile options when starting Xorg. X server allows unprivileged users with the ability to log in to the system via physical console to escalate their privileges and run arbitrary code under root privileges.
Here's an article about it from The Register:
https://www.theregister.co.uk/2018/10/2 … erability/
Here's the cve entry:
https://cve.mitre.org/cgi-bin/cvename.c … 2018-14665
Here's a link to a gitlab post:
https://gitlab.freedesktop.org/xorg/xse … 7c86fe330e
Apparently, it does not affect those of us using a display manager to start an X session, so I guess most of us are covered (?).
In any case, I guess a patch/update should be forthcoming soon.
Cheers,
#2 2018-10-26 15:06:24
Ogis1975
Re: Heads up: X Server exploit CVE-2018-14665
Hello. Security updates for this  vulnerability already in the mirrors. Just run
apt update
and
apt upgrade
            ----+- Peter Kropotkin -+----
#3 2018-10-26 16:09:46
Indeed ...
Saw it not 15' after I posted.
Fast as lightning.  =-)
A big Thank You! to the maintainers.
Cheers,
