#1 2018-10-18 14:34:17
keos
How to uninstall Pychess? [solved]
Hi, i,m not able to uninstall pychess, every time i reinstall the package it is coming again and again with the same old configuration, this is what i did:
apt-get remove pychess
apt-get purge pychess
apt-get --purge remove `deborphan --libdev`
dpkg --purge `COLUMNS=300 dpkg -l | egrep "^rc" | cut -d' ' -f3`
aptitude purge '~'c
And Bleachbit but when i reinstall pychess it is back again like if nothing happened ...
What is missing? what is wrong?.
Thanks
devuan_ascii_2.0.0-rc_amd64_desktop-live.iso  [Xfce]
Graphics: AMD Radeon HD 7640G integrated graphics
GPU: AMD/ATI Trinity [Radeon HD 7640G]
#2 2018-10-18 14:41:27
Re: How to uninstall Pychess? [solved]
Look under ~/.config (in your home dir) for pychess config files. Delete them, and you will lose any config changes your use made to the application. No need to purge and reinstall.
#3 2018-10-18 14:58:28
keos
After ls -F i don't see any directory by pychess ...
i did this too:
keos@kaos:~$ whereis pychess
pychess:
keos@kaos:~$
#4 2018-10-18 16:51:43
keos
o'k i found it now by the graphic at thunar. Thanks.
