#1 2018-10-07 05:20:44
menuhin
Emacs 25 or later in ASCII - dependency issues
Hi forum members,
I just did a clean install of ASCII after finding upgrading from 1.0 had many issues, e.g. network etc.
I did an update to all default packages after initial installation, and then tried to install some packages that I need to use:
Emacs25 package can not install due to dependency issues.
How can I solve this?
Or can I even install Emacs 26?
Of course, compiling Emacs by myself can be a way to do, but I really don’t want to get to that path.
M
#2 2018-10-07 08:30:25
Re: Emacs 25 or later in ASCII - dependency issues
emacs26 is not available in ASCII. Which dependency issues do you have?
#3 2018-10-07 23:55:40
menuhin
Thanks for your reply.
I updated sources.list from those on the Devuan ASCII DVD default to the recommended lists on the website.
Emacs 25 can be installed now.
