#1 2018-09-22 13:44:56
sn
usb's not mounting
Sorry to repost haven't been able to fix the problem
Noticed this when the policykit-1 package was updated I was unable to shutdown or suspend from XFCE desktop without logging out and logging back in as root. I fixed it with the following workaround: Downgrade libpolkit-agent-1-0, libpolkit-backend-1-0, and libpolkit-gobject-1-0 from 0.105-15~deb8u3 to 0.105-9+devuan1.
- Launch Synaptic Package Manager.
gksudo synaptic-pkexec
- Find each of the 3 packages and press CTRL+E, or from the menu: Package -> Force Version.
- Select 0.105-9+devuan1.
Since then I've reinstalled policykit-1 which allows me to shutdown and suspend from XFCE menu.
The following didn't work
fsmithred wrote:
The devuanized versions of 0.105-15 are in jessie-security.
apt-get -t jessie-security install policykit-1
Thanks for any help
#2 2018-09-22 21:43:09
Re: usb's not mounting
How does it not work? Did you get an error message? Please post the contents of /etc/apt/sources.list
You should get something like this when you run that command:
# apt-get -t jessie-security install policykit-1
Building dependency tree
The following extra packages will be installed:
  libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0
  libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 policykit-1
4 upgraded, 0 newly installed, 0 to remove and 354 not upgraded.
Need to get 173 kB of archives.
After this operation, 298 kB disk space will be freed.
This looks odd.
You can start synaptic with gksudo or pkexec. No need to use both.
gksudo synaptic
or
synaptic-pkexec
#3 2018-09-23 16:10:19
sn
Sorry for the late reply fsmithred. I meant "apt-get -t jessie-security install policykit-1" didn't make usb's automount  like they had before. Not that I know for sure that policykit-1 was even the cause
#4 2018-09-23 16:39:23
Check to make sure you have the right versions of all those libraries listed in my codebox above.
(should be version 0.105-15~deb8u3+devuanSEC1)
Check removable device settings in xfce.
When you plug in a usb stick, do you get an icon on the desktop? If so, can you mount/open it from there?
