Pages: 1
Problem with xfs_repair corrupting a partition.
Using a high quality USB to SATA adapter.
Partition a disk with gparted.
Set the file type to xfs and format.
Mount a partition
    mount /dev/sdd1 /mnt/sdd1
cd to /usr/local
find . | cpio -pvdum /mnt/sdd1
umount /mnt/sdd1
xfs_repair -n /dev/sdd1
    Generates all sorts of corruption errors.
When the adapter is moved to another system running Slackware 14.2,
xfs_repair works fine. If the original system is booted on a GNU Rescue
CD (flash drive), xfs_repair works fine.
On the original system, modinfo xfs indicates that the kernel driver and
the xfs_repair utility are of the same version, 4.9.
The system is use is an 8 core Intel on an Asus system board with 16 GiB
of RAM, using Devuan ASCII 64bit.
Pages: 1
