Pages: 1
Well, Days ago I decided to give the Jump from Linux Mint 17.03, my main distro since 2015 to Devuan ASCII. In my last configuration I had installed FreeBSD, Windows7, and Haiku alongside Mint. To Install Devuan I decided to format all the HD and then adding the other OS. My first one was FreeBSD, but Devuan grub says it doesn't recognize the filesystem.
At the moment my /etc/grub.d/custom_40
menuentry 'FreeBSD' --class freebsd --class bsd --class os {
insmod part_msdos
insmod ufs2
set root="(hd0,msdos1,bsd1 >)"
kfreebsd /boot/loader
Perhaps the fourth or fifth combination I tried ![]()
Another important data.
Making
fdisk -lgives:
# fdisk -l
Disk /dev/sda: 298 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x9b3fc34f
Disposit. Boot Start End Sectors Size Id System
/dev/sda1 * 64 201326655 201326592 96G a5 FreeBSD
/dev/sda3 201820158 625141556 423321399 201,9G 5 Extended
/dev/sda5 461301760 467159039 5857280 2,8G 82 Linux swap / Solaris
/dev/sda6 467161088 625141556 157980469 75,3G 83 LinuxAny idea? I think that devuan's grub doesn't support UFS but, I am not sure
<<Lupus est homo homini, non homo, quom qualis sit non novit>>
Hello
Read 12.2.1. The Boot Manager: https://www.freebsd.org/doc/handbook/bo … ction.html
I have done this but it was a while ago and it is all blurry now. I can tell you this:
1. Install Devuan first without GRUB
2. Then, install FreeBSD with boot0
This ought to do it. It is fairly easy as long as you don't install GRUB.
I dual-boot Devuan and FreeBSD...well, actually I multi-boot several Devuan-based distros and FreeBSD. The way that I did it may be unconventional though...
I reformatted my hardrive with all of the partitions that I knew I wanted. I formatted the partition that I wanted to use for FreeBSD as fat32 (which was /dev/sda3). I then installed my main OS on /dev/sda2 (/dev/sda1 is swap). I also used Grub.
Installed FreeBSD on the fat32 partition, and rebooted to my main OS. Added the following to the file /etc/grub.d/40_custom
menuentry "FreeBSD" {
set root='(hd0,3)'
chainloader +1
}Notice the (hd0,3) above...the 3 is the number of the partition that I installed FreeBSD on...your partition number may vary.
After adding that to the file, I saved and closed it. Then I ran...
update-grubRebooted, and FreeBSD was listed in the Grub. ![]()
This worked well for me, but I don't know if it's the best method. ![]()
Edited to add: I also chose UFS for my FreeBSD install rather than ZFS.
Veni, vidi, vici vdevuaned. I came, I saw, I Devuaned. ![]()
Hello astheroth. Check this nice tutorial: Dual booting Linux and FreeBSD. Good luck!
----+- Peter Kropotkin -+----
Pages: 1
