#1 2018-08-16 14:48:24
leegold
Possible missing firmware /lib/firmware/nvidia
Hi, I get warnings when I upgrade, is there a fix? What does it mean? Is it a bug? Thanks.
uname -a
Linux giga12 4.9.0-7-686-pae #1 SMP Debian 4.9.110-3+deb9u2 (2018-08-13) i686 GNU/Linux
$ uname -v
#1 SMP Debian 4.9.110-3+deb9u1 (2018-08-03)
$ lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation G84GLM [Quadro FX 1600M] (rev a1)
$ cat /etc/*-release
PRETTY_NAME="Devuan GNU/Linux ascii"
NAME="Devuan GNU/Linux"
ID=devuan
ID_LIKE=debian
HOME_URL="https://www.devuan.org/"
SUPPORT_URL="https://devuan.org/os/community"
BUG_REPORT_URL="https://bugs.devuan.org/"
$ sudo apt-get dist-upgrade
Building dependency tree
Calculating upgrade... Done
  linux-image-4.9.0-7-686-pae linux-libc-dev
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 39.2 MB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 http://pkgmaster.devuan.org/merged ascii-security/main i386 linux-image-4.9.0-7-686-pae i386 4.9.110-3+deb9u2 [37.9 MB]
Get:2 http://pkgmaster.devuan.org/merged ascii-security/main i386 linux-libc-dev i386 4.9.110-3+deb9u2 [1348 kB]
Fetched 39.2 MB in 1min 23s (470 kB/s)
Reading changelogs... Done
(Reading database ... 141873 files and directories currently installed.)
Preparing to unpack .../linux-image-4.9.0-7-686-pae_4.9.110-3+deb9u2_i386.deb ...
Unpacking linux-image-4.9.0-7-686-pae (4.9.110-3+deb9u2) over (4.9.110-3+deb9u1) ...
Preparing to unpack .../linux-libc-dev_4.9.110-3+deb9u2_i386.deb ...
Unpacking linux-libc-dev:i386 (4.9.110-3+deb9u2) over (4.9.110-3+deb9u1) ...
Setting up linux-libc-dev:i386 (4.9.110-3+deb9u2) ...
Setting up linux-image-4.9.0-7-686-pae (4.9.110-3+deb9u2) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-4.9.0-7-686-pae
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/sw_method_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/sw_bundle_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/sw_nonctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/sw_ctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/gpccs_sig.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/gpccs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/gpccs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/gpccs_bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/fecs_sig.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/fecs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/fecs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/gr/fecs_bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/acr/ucode_unload.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/acr/ucode_load.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gp100/acr/bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/sw_method_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/sw_bundle_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/sw_nonctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/sw_ctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/gpccs_sig.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/gpccs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/gpccs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/gpccs_bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/fecs_sig.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/fecs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/fecs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/gr/fecs_bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/acr/ucode_unload.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/acr/ucode_load.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm206/acr/bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/sw_method_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/sw_bundle_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/sw_nonctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/sw_ctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/gpccs_sig.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/gpccs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/gpccs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/gpccs_bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/fecs_sig.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/fecs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/fecs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/gr/fecs_bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/acr/ucode_unload.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/acr/ucode_load.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm204/acr/bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/sw_method_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/sw_bundle_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/sw_nonctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/sw_ctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/gpccs_sig.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/gpccs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/gpccs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/gpccs_bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/fecs_sig.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/fecs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/fecs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/gr/fecs_bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/acr/ucode_unload.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/acr/ucode_load.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm200/acr/bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/sw_method_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/sw_bundle_init.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/sw_nonctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/sw_ctx.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/gpccs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/gpccs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/fecs_sig.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/fecs_data.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/fecs_inst.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/gr/fecs_bl.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/acr/ucode_load.bin for module nouveau
W: Possible missing firmware /lib/firmware/nvidia/gm20b/acr/bl.bin for module nouveau
I: The initramfs will attempt to resume from /dev/sda5
I: (UUID=48753958-b4a4-44fb-b12f-b604743f41e1)
I: Set the RESUME variable to override this.
live-boot: core filesystems devices utils udev wget blockdev dns.
/etc/kernel/postinst.d/zz-update-grub:
Generating grub configuration file ...
Found theme: /usr/share/desktop-base/grub-themes/desktop-grub-theme/theme.txt
Found linux image: /boot/vmlinuz-4.9.0-7-686-pae
Found initrd image: /boot/initrd.img-4.9.0-7-686-pae
Found linux image: /boot/vmlinuz-4.9.0-6-686-pae
Found initrd image: /boot/initrd.img-4.9.0-6-686-pae
Found memtest86+ image: /boot/memtest86+.bin
Found memtest86+ multiboot image: /boot/memtest86+_multiboot.bin
Found Windows 10 on /dev/sda1
done
#2 2018-08-16 16:06:21
Re: Possible missing firmware /lib/firmware/nvidia
The messages are letting you know that some of your hardware can use non-free firmware. You would need to enable contrib and non-free repos, update, and then install firmware-misc-nonfree if you wanted it. I don't know if it will make a difference in how your vid card performs.
#3 2018-08-27 21:35:55
leegold
Not going to worry about it, vid seems fine as is. Thanks.
