#1 2018-08-15 12:30:22
keos
Problems installing yandex [solved]
Hi, i installed yandex following this instrutions:
https://www.linuxbabe.com/browser/yande … nsuse-arch
and now i can't update the system ... -- some packages are configurated many times.
Leyendo lista de paquetes... Hecho
W: El objetivo Packages (main/binary-amd64/Packages) está configurado varias veces en /etc/apt/sources.list:16 y /etc/apt/sources.list.d/yandex-browser.list:1
W: El objetivo Packages (main/binary-all/Packages) está configurado varias veces en /etc/apt/sources.list:16 y /etc/apt/sources.list.d/yandex-browser.list:1
W: El objetivo Translations (main/i18n/Translation-es_MX) está configurado varias veces en /etc/apt/sources.list:16 y /etc/apt/sources.list.d/yandex-browser.list:1
W: El objetivo Translations (main/i18n/Translation-es) está configurado varias veces en /etc/apt/sources.list:16 y /etc/apt/sources.list.d/yandex-browser.list:1
W: El objetivo Translations (main/i18n/Translation-en) está configurado varias veces en /etc/apt/sources.list:16 y /etc/apt/sources.list.d/yandex-browser.list:1
root@kaos:/home/keos#
I did what they recomended, but ..
devuan_ascii_2.0.0-rc_amd64_desktop-live.iso  [Xfce]
Graphics: AMD Radeon HD 7640G integrated graphics
GPU: AMD/ATI Trinity [Radeon HD 7640G]
#2 2018-08-15 12:40:51
keos
Re: Problems installing yandex [solved]
Install Yandex Browser on Debian 8 Jessie, Ubuntu 16.04 LTS, Linux Mint 18
To get the latest updates, it’s recommended to install Yandex browser from its official APT repository. First create a source list file for Yandex browser
sudo nano /etc/apt/sources.list.d/yandex-browser.list
Add the following line to the file.
deb [arch=amd64] http://repo.yandex.ru/yandex-browser/deb beta main
Press CTRL+O, then press Enter to save the file, CTRL+X to exit out of the file. The we also need to download and import the GPG key so that packages downloaded from this repository can be authenticated.
wget https://repo.yandex.ru/yandex-browser/Y … ER-KEY.GPG
sudo apt-key add YANDEX-BROWSER-KEY.GPG
After that, update local package index and install Yandex browser.
sudo apt update
sudo apt install yandex-browser-beta
#3 2018-08-18 14:12:14
keos
i follow an advice from another forum:
"just click the Install button on this page: https://browser.yandex.com/ and select Linux Version (deb, x64) to download the browser.
Then, in your file manager, click on the deb file to install it with gdebi-gtk."
And it works this time.
Thank you very much for your help.
