#1 2018-08-15 02:13:02
0xf4b10
How to solve files hash sum mismatches when updating?
I've added to my sources lists the repositories of metasploit and virtualbox in order to make it easy to install them. It was working normally and the updates were coming but today when I tried to update I got the following output:
Err:4 [url]http://downloads.metasploit.com/data/releases/metasploit-framework/apt[/url] lucid/main i386 Packages
  Hash Sum mismatch
  Hashes of expected file:
   - Filesize:429 [weak]
   - SHA256:02899db9c850f78edc1f5abfdfe485ffbf3b7d04a4695d0ef7ff912aedb1a492
   - SHA1:37419453a05e2a2586e63cf078f597514b919a17 [weak]
   - MD5Sum:b2dcab0962b2b53319f4715beedcb911 [weak]
  Hashes of received file:
   - SHA256:3ae2486b947d2db14add85154b39a4fc35e30dda695d4b628edea71365c846a4
   - SHA1:4672a8054e770556316417658f335ba31cb4160a [weak]
   - MD5Sum:27517729f2a9ed7ec35e051c08983491 [weak]
   - Filesize:428 [weak]
  Last modification reported: Sun, 12 Aug 2018 16:13:17 +0000
  Release file created at: Tue, 14 Aug 2018 11:21:02 +0000
Get:5 [url]http://downloads.metasploit.com/data/releases/metasploit-framework/apt[/url] lucid/main amd64 Packages [429 B]
Err:5 [url]http://downloads.metasploit.com/data/releases/metasploit-framework/apt[/url] lucid/main amd64 Packages
Err:13 [url]http://download.virtualbox.org/virtualbox/debian[/url] stretch/contrib i386 Packages
  Hash Sum mismatch
   - Filesize:1739 [weak]
   - SHA256:e9756829a27c807bf8d25a90a1001adce03a31fb87efc96b13e9854cba66eed8
   - SHA1:83539259fc124b4bbba5f77a1e6e835fe34deebf [weak]
   - MD5Sum:aa86cc0404bedfd33919ca5977f15a24 [weak]
   - SHA256:f84652d7ac0afe92cb8fa010056f4121551342cdecf7ae104cb9e03057da4167
   - SHA1:1a0de458cdc36a66e8b8bbf68c141a9111775c86 [weak]
   - MD5Sum:37678c5fd937ecd1c2634ba544001112 [weak]
   - Filesize:1727 [weak]
  Last modification reported: Tue, 17 Jul 2018 07:50:04 +0000
  Release file created at: Tue, 14 Aug 2018 16:13:46 +0000
Fetched 89.8 MB in 41s (2,143 kB/s)
E: Failed to fetch [url]http://download.virtualbox.org/virtualbox/debian/dists/stretch/contrib/binary-i386/Packages.bz2[/url]  Hash Sum mismatch
E: Failed to fetch [url]http://downloads.metasploit.com/data/releases/metasploit-framework/apt/dists/lucid/main/binary-i386/Packages.gz[/url]  Hash Sum mismatch
E: Failed to fetch [url]http://downloads.metasploit.com/data/releases/metasploit-framework/apt/dists/lucid/main/binary-amd64/Packages.gz[/url]
E: Some index files failed to download. They have been ignored, or old ones used instead.
What can be causing this? And also, how to solve?
Thanks in advance
#2 2018-08-15 13:23:44
GNUser
Re: How to solve files hash sum mismatches when updating?
It seems that the repository's Packages, Packages.gz, and Packages.bz2 files recently changed but your system is still looking for the old version of these files because the repository metadata cached on your system is old.
Delete all repository metadata and try again with these commands:
# apt-get clean
# rm -rf /var/lib/apt/lists/*
# apt-get update
Hopefully that'll take care of it.
#3 2018-08-15 15:09:46
0xf4b10
yes, it did
thanks for the help
#4 2018-09-06 02:29:18
0xf4b10
strange thing, this error just happened again but now the proposed solution is not working anymore. Any tips?
#5 2019-04-08 02:47:34
keb
i just did the clearing commands too and am getting those errors, see below.
is it safe to do upgrades?
is the repository out of sync or hacked?
# apt update
Get:1 [url]http://deb.devuan.org/merged[/url] ascii InRelease [25.6 kB]
Get:2 [url]http://deb.devuan.org/merged[/url] ascii-updates InRelease [25.6 kB]
Get:3 [url]http://deb.devuan.org/merged[/url] ascii-security InRelease [24.9 kB]
Get:4 [url]http://deb.devuan.org/merged[/url] ascii-backports InRelease [25.6 kB]
Get:5 [url]http://deb.devuan.org/merged[/url] ascii/main amd64 Packages [7,227 kB]
Get:6 [url]https://deb.torproject.org/torproject.org[/url] stretch InRelease [4,965 B]
Get:7 [url]https://deb.torproject.org/torproject.org[/url] stretch/main Sources [1,253 B]
Get:8 [url]https://deb.torproject.org/torproject.org[/url] stretch/main amd64 Packages [3,496 B]
Get:9 [url]http://deb.devuan.org/merged[/url] ascii/main amd64 Contents (deb) [28.2 MB]
Err:9 [url]http://deb.devuan.org/merged[/url] ascii/main amd64 Contents (deb)
  Hash Sum mismatch
   - Filesize:28212548 [weak]
   - SHA256:e0e8ec7baba6bc2d4c26918b14aa8e27b95939d9f7440cb98fb087191e8de019
   - SHA256:76536d452756141be554290f1c99371f67fd7651e3375b25ef11988703d569b1
  Last modification reported: Sun, 07 Apr 2019 01:33:31 +0000
  Release file created at: Mon, 08 Apr 2019 01:32:03 +0000
Get:10 [url]http://deb.devuan.org/merged[/url] ascii-updates/main amd64 Packages [12.7 kB]
Get:11 [url]http://deb.devuan.org/merged[/url] ascii-updates/main amd64 Contents (deb) [335 kB]
Err:11 [url]http://deb.devuan.org/merged[/url] ascii-updates/main amd64 Contents (deb)
  Hash Sum mismatch
   - Filesize:335185 [weak]
   - SHA256:a958a8acee49af960759f7533231b075d184fa8ee7d708764b022d33c1d29e8f
   - SHA256:75acef3458d85396d38b730213b0fe801508a961f4d30495cfa585b8318ccf95
  Last modification reported: Sun, 07 Apr 2019 01:33:32 +0000
  Release file created at: Mon, 08 Apr 2019 01:30:05 +0000
Get:12 [url]http://deb.devuan.org/merged[/url] ascii-security/main amd64 Packages [446 kB]
Get:13 [url]http://deb.devuan.org/merged[/url] ascii-security/main amd64 Contents (deb) [36 B]
Get:14 [url]http://deb.devuan.org/merged[/url] ascii-backports/main amd64 Packages [592 kB]
Get:15 [url]http://deb.devuan.org/merged[/url] ascii-backports/main amd64 Contents (deb) [5,931 kB]
Err:15 [url]http://deb.devuan.org/merged[/url] ascii-backports/main amd64 Contents (deb)
  Writing more data than expected (5932168 > 5931180) [IP: 37.187.111.86 80]
   - Filesize:5931180 [weak]
   - SHA256:8924a5a78342c58434c93dcf676fc82d6efdb2eeea243c1d1fb98d89f9ecc55a
  Release file created at: Mon, 08 Apr 2019 01:30:04 +0000
Fetched 36.9 MB in 42s (872 kB/s)
E: Failed to fetch [url]http://deb.devuan.org/merged/dists/ascii/main/Contents-amd64.gz[/url]  Hash Sum mismatch
E: Failed to fetch [url]http://deb.devuan.org/merged/dists/ascii-updates/main/Contents-amd64.gz[/url]  Hash Sum mismatch
E: Failed to fetch [url]http://deb.devuan.org/merged/dists/ascii-backports/main/Contents-amd64.gz[/url]  Writing more data than expected (5932168 > 5931180) [IP: 37.187.111.86 80]
update: waiting a week seems to have fixed this.
