#1 2018-08-14 10:49:52
inukaze
[SOLVED] Manual Add Statup Script for NOIP2
HI there, i am trying the "noip2" startup automatically with system boot. but i dont know why the follow process don't work with Devuan Jessie 1.0 :
sudo touch /etc/init.d/noip2
sudo chmod a+o+x /etc/init.d/noip2
echo '#! /bin/sh
# /etc/init.d/noip2.sh
# Supplied by no-ip.com
# Modified for Debian GNU/Linux by Florian Moesch
. /lib/lsb/init-functions # modify for your init-functions
PROG=/usr/local/bin/noip2
NAME=noip2
test -x $PROG || exit 0
case "$1" in
        start)
        echo -n "Starting dynamic address update: "
        $PROG
        echo "$NAME."
        stop)
        echo -n "Shutting down dynamic address update:"
        killall $NAME
        echo "$NAME."
restart)
        echo -n "Restarting dynamic address update: "
        killall $NAME
        $PROG
        echo "$NAME."
status)
        status_of_proc $PROG $NAME && exit 0 || exit $?
        echo "Usage: $0 {status|start|stop|restart}"
        exit 1
        esac
exit 0
' | sudo tee /etc/init.d/noip2
sudo chmod a+x /etc/init.d/noip2 ; \
sudo rc-update add noip2 default ; \
sudo rc-service noip2 start
if i restart, and use :
ps -A | noip
Is not running for start i must use :
What is wrong with the script?
#2 2018-08-14 19:29:52
GNUser
Re: [SOLVED] Manual Add Statup Script for NOIP2
What init system are you using? The rc-update and rc-service commands at the end suggest that the instructions are for openrc, which is not Devuan's default.
#3 2018-08-14 23:34:21
inukaze
[SOLUTION]
echo '#!/sbin/runscript
description="Start/Stop the no-ip daemon"
depend()
        after *
        keyword notimeout
start()
        ebegin "Starting NoIP"
        /usr/bin/noip2
        eend $? "Failed to start NoIP"
stop()
        ebegin "Stopping NoIP"
        killall -TERM /usr/bin/noip2
        eend $? $"Failed to stop NoIP"
}' | sudo tee /etc/init.d/noip2 ; sudo chmod a+rx /etc/init.d/noip2
Source -> https://forums.gentoo.org/viewtopic-t-7 … art-0.html
