#1 2018-08-14 09:39:52
stroudmw
[Solved} Miyo Awesome - no sound
Apologies for posting two questions on the same day!
I can't get any sound using Deadbeef or VLC on Miyo Awesome. I'm not sure when this started, or what I did to break it.
Inxi reports the following:
Audio:  Card Intel 82801H (ICH8 Family) HD Audio Controller
           driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.9.0-7-amd64
I've tried re-installing the codecs (libavcodec-extra ffmpeg flac) and I've checked that my volume isn't muted. I've also checked Alsa, and the volume controls are at maximum.
Thanks (again).
#2 2018-08-14 12:41:42
stroudmw
Re: [Solved} Miyo Awesome - no sound
solved:
sudo alsactl init
#3 2018-08-14 13:44:25
catprints
Thanks for the post. Your solution solved the sound issue I was having on dwm(window manager)/devuan install (no desktop chosen)and quodlibet.
Devuan inspires experimentation.
"The obstacle is the path."
#4 2018-08-14 14:24:44
stroudmw
I'm really glad that I could be of some help (for a change!)  smile
#5 2018-08-15 08:01:47
MiyoLinux
I didn't see this earlier...sorry!
So glad you got it figured out and were able to help others! big_smile
