#1 2018-07-29 01:30:31
Ron
[SOVED] App to print out labels
Is there any app in the repos that can print out labels, e.g., Avery address labels? I prefer not to use LibreOffice, and it doesn't appear that AbiWord supports label printing.
#2 2018-07-29 12:16:21
MiyoLinux
Re: [SOVED] App to print out labels
Ron,
There's an application called glabels...g = Gnome. I just installed it (out of curiosity) using...
sudo apt-get install glabels --no-install-recommends
After installing it, I opened it up (took it a moment to open). If you click "New File", another window opens up allowing you to choose from tons of predefined label products. Avery is what appeared as the default, but there are MANY more. Now...I haven't tested it to see if it works well or not, because I don't have a printer (or any labels) with me right now. Here's the output from the installation...look it over and see if you want to try it.
dan@miyolinux:~$ sudo apt-get install glabels --no-install-recommends
[sudo] password for dan:
Building dependency tree
  evolution-data-server-common glabels-data gnome-desktop3-data
  libboost-date-time1.62.0 libboost-filesystem1.62.0 libboost-system1.62.0
  libboost-thread1.62.0 libcamel-1.2-59 libebackend-1.2-10 libebook-1.2-16
  libebook-contacts-1.2-2 libedata-book-1.2-25 libedataserver-1.2-22
  libiec16022-0 libphonenumber7 libprotobuf10 libqrencode3
Suggested packages:
Recommended packages:
  evince | atril
  evolution-data-server-common glabels glabels-data gnome-desktop3-data
0 upgraded, 18 newly installed, 0 to remove and 0 not upgraded.
Need to get 7,333 kB of archives.
After this operation, 28.4 MB of additional disk space will be used.
#3 2018-07-29 15:53:03
Ron
Thanks MiyoLinux. I'm testing it out now.
EDIT
It works great. It's now my go-to app for label printing.
