#1 2018-07-22 14:34:55
Terence
amdgpu-pro drivers
Dear All,
it was time for new hardware (actually LGA 775 + LGA 1336) and I have bayed parts for complete new system, one part is an AMD RX 580 graphic-card. I know, it's overkill for Linux but I want to live within next 10 years like last one.
On AMD-site is neither a driver for 'Devuan' nor for 'Debian' https://support.amd.com/en-us/kb-articl … Notes.aspx but for Ubuntu.
Here https://linuxconfig.org/how-to-install- … etch-linux just tell to modify the '/etc/apt/sources.list' but in the comments is written that's buggie.
On this German thread https://www.kde-neon.de/topic/amdgpu-pr … tallieren/ recommend to download (for Neon) the drivers for Ubuntu 16.04, to read the 'ID' of
/etc/os-release
in my/our case
ID=devuan
and modify accordingly
amdgpu-pro-install
case "$ID" in
ubuntu)
PACKAGES="amdgpu-pro amdgpu-pro-lib32 amdgpu-pro-dkms"
to (in my/our case):
case "$ID" in
devuan)
I know that drivers are written for certain 'kernels' and my:
uname -a
Linux devuan 4.9.0-7-amd64 #1 SMP Debian 4.9.110-1 (2018-07-05) x86_64 GNU/Linux
Fact: I have no idea, can someone help me please?
Thanks in advance for any newbie explanations, links.
#2 2020-08-14 08:49:23
penguin
Re: amdgpu-pro drivers
@Terence
I recently bought Asus 8GB RX 580 graphics card just for Blender 2.8x's rendering engine. Blender supports OpenCL for rendering.
It was on fresh installation of Devuan 3.0.0 in new partition (/dev/sda1) after spending hours to setup the AMD's graphics driver without success.
Here is the steps I've done to setup for RX 580.
Installed amd64-microcode, firmware-amd-graphics packages.
Switched to text mode during boot by removing /etc/rc2.d/S04slim
Created ~/.xinitrc
# /etc/X11/xinit/xinitrc
# global xinitrc file, used by all X sessions started by xinit (startx)
exec startxfce4
It solved "permission denied", "/bin/sh: Can't open /usr/bin/X" failures.
To start Xfce, run startx.
> inxi -G
Graphics:
  Device-1: AMD Ellesmere [Radeon RX 470/480] driver: amdgpu v: kernel
  Display: tty server: X.Org 1.20.4 driver: amdgpu,ati
  unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz
  OpenGL:
  renderer: Radeon RX 580 Series (POLARIS10 DRM 3.35.0 5.4.0-0.bpo.2-amd64 LLVM 7.0.1)
  v: 4.5 Mesa 18.3.6
Installation of AMD's graphics driver
Downloaded amdgpu-pro-19.50-967956-ubuntu-18.04.tar.xz
I found the page and followed the instruction but it did not work out.
https://gist.github.com/kytulendu/3351b … 1ea3c95cbe
I extracted the amdgpu-pro package and moved to the directory
ran the installation script with options
./amdgpu-pro-install --opencl=legacy,pal --headless --no-dkms
the installation log
deb [ trusted=yes ] file:/var/opt/amdgpu-pro-local/ ./
Get:1 file:/var/opt/amdgpu-pro-local ./ InRelease
Ign:1 file:/var/opt/amdgpu-pro-local ./ InRelease
Get:2 file:/var/opt/amdgpu-pro-local ./ Release [816 B]
Get:3 file:/var/opt/amdgpu-pro-local ./ Release.gpg
Ign:3 file:/var/opt/amdgpu-pro-local ./ Release.gpg
Get:4 file:/var/opt/amdgpu-pro-local ./ Packages [127 kB]
Hit:5 http://deb.devuan.org/merged beowulf InRelease
Hit:6 http://deb.devuan.org/merged beowulf-security InRelease
Hit:7 http://deb.devuan.org/merged beowulf-backports InRelease
Reading package lists...
Building dependency tree...
Reading state information...
  linux-image-4.19.0-9-amd64
Use 'apt autoremove' to remove it.
  amdgpu-pro-pin
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/6,192 B of archives.
After this operation, 30.7 kB of additional disk space will be used.
Get:1 file:/var/opt/amdgpu-pro-local ./ amdgpu-pro-pin 19.50-967956 [6,192 B]
Selecting previously unselected package amdgpu-pro-pin.
(Reading database ...
Preparing to unpack .../amdgpu-pro-pin_19.50-967956_all.deb ...
Unpacking amdgpu-pro-pin (19.50-967956) ...
Setting up amdgpu-pro-pin (19.50-967956) ...
WARNING: This package was intended to be installed on Ubuntu 18.04 and may not work as exp
ected on Devuan GNU/Linux 3.
  amdgpu-core amdgpu-pro-core libdrm-amdgpu-amdgpu1 libdrm-amdgpu-common
  libdrm2-amdgpu libopencl1-amdgpu-pro opencl-amdgpu-pro-comgr
  amdgpu-core amdgpu-pro-core clinfo-amdgpu-pro libdrm-amdgpu-amdgpu1
  libdrm-amdgpu-common libdrm2-amdgpu libopencl1-amdgpu-pro
  opencl-amdgpu-pro-comgr opencl-amdgpu-pro-icd opencl-orca-amdgpu-pro-icd
0 upgraded, 10 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/76.3 MB of archives.
After this operation, 320 MB of additional disk space will be used.
Do you want to continue? [Y/n] Get:1 file:/var/opt/amdgpu-pro-local ./ amdgpu-core 19.50-9
67956 [2,220 B]
Get:2 file:/var/opt/amdgpu-pro-local ./ amdgpu-pro-core 19.50-967956 [5,560 B]
Get:3 file:/var/opt/amdgpu-pro-local ./ libdrm2-amdgpu 1:2.4.99-967956 [35.2 kB]
Get:4 file:/var/opt/amdgpu-pro-local ./ libdrm-amdgpu-common 1.0.0-967956 [4,600 B]
Get:5 file:/var/opt/amdgpu-pro-local ./ libdrm-amdgpu-amdgpu1 1:2.4.99-967956 [20.6 kB]
Get:6 file:/var/opt/amdgpu-pro-local ./ libopencl1-amdgpu-pro 19.50-967956 [13.3 kB]
Get:7 file:/var/opt/amdgpu-pro-local ./ clinfo-amdgpu-pro 19.50-967956 [149 kB]
Get:8 file:/var/opt/amdgpu-pro-local ./ opencl-amdgpu-pro-comgr 19.50-967956 [21.7 MB]
Get:9 file:/var/opt/amdgpu-pro-local ./ opencl-amdgpu-pro-icd 19.50-967956 [23.2 MB]
Get:10 file:/var/opt/amdgpu-pro-local ./ opencl-orca-amdgpu-pro-icd 19.50-967956 [31.3 MB]
Selecting previously unselected package amdgpu-core.
Preparing to unpack .../0-amdgpu-core_19.50-967956_all.deb ...
Unpacking amdgpu-core (19.50-967956) ...
Selecting previously unselected package amdgpu-pro-core.
Preparing to unpack .../1-amdgpu-pro-core_19.50-967956_all.deb ...
Unpacking amdgpu-pro-core (19.50-967956) ...
Selecting previously unselected package libdrm2-amdgpu:amd64.
Preparing to unpack .../2-libdrm2-amdgpu_2.4.99-967956_amd64.deb ...
Unpacking libdrm2-amdgpu:amd64 (1:2.4.99-967956) ...
Selecting previously unselected package libdrm-amdgpu-common.
Preparing to unpack .../3-libdrm-amdgpu-common_1.0.0-967956_all.deb ...
Unpacking libdrm-amdgpu-common (1.0.0-967956) ...
Selecting previously unselected package libdrm-amdgpu-amdgpu1:amd64.
Preparing to unpack .../4-libdrm-amdgpu-amdgpu1_2.4.99-967956_amd64.deb ...
Unpacking libdrm-amdgpu-amdgpu1:amd64 (1:2.4.99-967956) ...
Selecting previously unselected package libopencl1-amdgpu-pro:amd64.
Preparing to unpack .../5-libopencl1-amdgpu-pro_19.50-967956_amd64.deb ...
Unpacking libopencl1-amdgpu-pro:amd64 (19.50-967956) ...
Selecting previously unselected package clinfo-amdgpu-pro.
Preparing to unpack .../6-clinfo-amdgpu-pro_19.50-967956_amd64.deb ...
Unpacking clinfo-amdgpu-pro (19.50-967956) ...
Selecting previously unselected package opencl-amdgpu-pro-comgr.
Preparing to unpack .../7-opencl-amdgpu-pro-comgr_19.50-967956_amd64.deb ...
Unpacking opencl-amdgpu-pro-comgr (19.50-967956) ...
Selecting previously unselected package opencl-amdgpu-pro-icd.
Preparing to unpack .../8-opencl-amdgpu-pro-icd_19.50-967956_amd64.deb ...
Unpacking opencl-amdgpu-pro-icd (19.50-967956) ...
Selecting previously unselected package opencl-orca-amdgpu-pro-icd:amd64.
Preparing to unpack .../9-opencl-orca-amdgpu-pro-icd_19.50-967956_amd64.deb ...
Unpacking opencl-orca-amdgpu-pro-icd:amd64 (19.50-967956) ...
Setting up amdgpu-core (19.50-967956) ...
Setting up libdrm-amdgpu-common (1.0.0-967956) ...
Setting up amdgpu-pro-core (19.50-967956) ...
Setting up opencl-amdgpu-pro-comgr (19.50-967956) ...
Setting up opencl-orca-amdgpu-pro-icd:amd64 (19.50-967956) ...
Setting up opencl-amdgpu-pro-icd (19.50-967956) ...
Setting up libdrm2-amdgpu:amd64 (1:2.4.99-967956) ...
Setting up libdrm-amdgpu-amdgpu1:amd64 (1:2.4.99-967956) ...
Setting up libopencl1-amdgpu-pro:amd64 (19.50-967956) ...
Setting up clinfo-amdgpu-pro (19.50-967956) ...
Processing triggers for libc-bin (2.28-10) ...
glxinfo | grep amd
    Device: Radeon RX 580 Series (POLARIS10, DRM 3.35.0, 5.4.0-0.bpo.2-amd64, LLVM 7.0.1) (0x67df)
OpenGL renderer string: Radeon RX 580 Series (POLARIS10, DRM 3.35.0, 5.4.0-0.bpo.2-amd64, LLVM 7.0.1)
> aptitude search '~i amdgpu'
i A amdgpu-core                          - Core meta package for unified amdgpu driver.
i A amdgpu-pro-core                      - Core meta package for Pro components of the uni
i   amdgpu-pro-pin                       - Meta package to pin a specific amdgpu driver ve
i   clinfo-amdgpu-pro                    - AMD OpenCL info utility
i A libdrm-amdgpu-amdgpu1                - Userspace interface to amdgpu-specific kernel D
i A libdrm-amdgpu-common                 - List of AMD/ATI cards' device IDs, revision IDs
i   libdrm-amdgpu1                       - Userspace interface to amdgpu-specific kernel D
i A libdrm2-amdgpu                       - Userspace interface to kernel DRM services -- r
i A libopencl1-amdgpu-pro                - AMD OpenCL ICD Loader library
i A opencl-amdgpu-pro-comgr              - non-free AMD OpenCL ICD Loaders
i   opencl-amdgpu-pro-icd                - non-free AMD OpenCL ICD Loaders
i   opencl-orca-amdgpu-pro-icd           - non-free AMD OpenCL ICD Loaders
i   xserver-xorg-video-amdgpu            - X.Org X server -- AMDGPU display driver
Blender 2.83 sees the RX 580 graphics card in Edit > Preferences > System > OpenCL menu.
I rendered few models using GPU compute in Blender 2.83.
I upgraded  kernel 4.19 to 5.4.0-0.bpo.2-amd64 before I tried above method.
#3 2020-08-14 17:07:56
AMD themselves do not recommend the proprietary drivers for the RX 580 graphics card: https://www.amd.com/en/support/kb/relea … stallation
The open-source amdgpu drivers out-perform the proprietary versions for almost all tasks (check Phoronix) and Blender works just fine with the non-proprietary versions. Just make sure the firmware-amd-graphics package is installed.
#4 2020-08-14 18:55:53
Got a RX580 installed on a Ryzen 2700X computer. Worked fine with ASCII and now with Beowulf with KMS driver (included in the kernel) and firmware. You need non-free added to the sources.list, you install amd64-microcode and firmware-amd-graphics. On ASCII you better pull firmware-amd-graphics from backports.
If you need some guidance, check out the Devuan.org website, there you will find some instructions how to set the sources.list.
No fiddling required with amdgpu-pro.
#5 2020-08-25 10:46:08
Terence
@ http://dev1galaxy.org/profile.php?id=5581.
Yes, I know. It was a (failed) tentative/attempt to get 4k resolution.
@ http://dev1galaxy.org/profile.php?id=5048.
It's not (meanwhile) a question of `sources.list`, it's a question of to small resolution.
After long time and reading this http://dev1galaxy.org/viewtopic.php?pid=5067#p5067 I loose almost the hope to setup Devuan as main OS.
I will open a new thread for 4k.
#6 2020-08-25 14:16:59
Terence
penguin wrote:
@Terence
Created ~/.xinitrc
exec startxfce4
> inxi -G
Graphics:
  OpenGL:
  v: 4.5 Mesa 18.3.6
Thanks for your answer, that's great.
I read about advantages of newer Kernel, newer Plasma5 and newer drivers, but... I'm newbie.
I installed `Beowulf` in the past in the VM and on NVMe. The VM give me only 1024 resolution with no chance to change it anyway, the NVMe give me no GUI; only text and cursor. This time, the VM give me full 4k-resolution and I hope to be successful with your help.
My hardware: x399 MB, TR4 1900 CPU, Vega 64 GPU (the x580 got my wife), 512GB NVMe, 64 GB RAM.
OS: Kubuntu 20.04
Target OS: Beowulf (Devuan 3), newer Kernel (5.4), newer GPU-drivers, 4k resolution and maybe Plasma 5.18.5 instead of 5.14.5, but Plasma is secondary/not mandatory. Another 'nice to have' could be 10 Bit deep color representation, but... maybe is only a dream at moment under Linux.
Target OS-details: Devuan-Beowulf, KDE, parallelized OpenRC. That I know how to but... I don't know how to start/stop GUI (you use xfce). Note: KDE is a must (for my wife), the only given alternative is "Astra-Linux" (I dislike this one).
Following the outputs of running system (Kubuntu 20.04 = host) and virtual system (Beowulf 3 = client)
> `Virtualbox:` inxi -G
Graphics:  Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.15.0.0
           Display: x11 server: X.Org 1.20.4 driver: vmware unloaded: fbdev,modesetting,vesa resolution: 3840x2160_vbox~60Hz
           OpenGL: renderer: SVGA3D; build v: 2.1 Mesa 18.3.6
> `Kubuntu 20.20:` inxi -G
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Vega 10 XL/XT [Radeon RX Vega 56/64] driver: amdgpu v: kernel
           Display: x11 server: X.Org 1.20.8 driver: amdgpu FAILED: ati unloaded: fbdev,modesetting,vesa
           resolution: 3840x2160~60Hz
           OpenGL: renderer: Radeon RX Vega (VEGA10 DRM 3.35.0 5.4.0-42-generic LLVM 10.0.0) v: 4.6 Mesa 20.0.8
> `Virtualbox:` glxinfo | grep AMD
           GL_AMD_shader_trinary_minmax, GL_ANGLE_texture_compression_dxt3,
> `Kubuntu 20.20:` glxinfo | grep AMD
> no output here
>`Virtualbox: uname -a
Linux devuan 4.19.0-10-amd64 #1 SMP Debian 4.19.132-1 (2020-07-24) x86_64 GNU/Linux
> `Kubuntu 20.20:` uname -a
Linux ter-Kub-20-04 5.4.0-42-generic #46-Ubuntu SMP Fri Jul 10 00:24:02 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
My questions:
1. How to install 'kernel 5.4.0-42-generic'? have you a guide for newbie?
2. Have I to reinstall the GPU-driver by each kernel upgrade? You don't install 'dkms'!
3. I haven't "/etc/rc2.d/S04slim" (at least in the VM), will I have on NVMe? Even if I use 'openrc' and 'kde'? Just rename, displace or remove? How to boot in GUI afterward?
4. In this thread http://dev1galaxy.org/viewtopic.php?pid=5067#p5067 and on my kubuntu machine are `/etc/modprobe.d/fbdev-blacklist.conf` and `/etc/modprobe.d/amd64-microcode-blacklist.conf`. Whats about that?
5. To can start the `./amdgpu-pro-install --opencl=legacy,pal --headless --no-dkms` is needed to modify the `case "$ID" in` or not? Can you be more precise please?
Thanks and best regards
#7 2020-08-25 15:06:06
@OP: the post from @penguin is full of crap, that user doesn't know what they're doing and you shouldn't follow their advice.
Do not do that, that kernel is hopelessly outdated and only available from Ubuntu.
If you want to try a newer kernel than the 4.19 LTS branch supplied with beowulf then install the linux-image-amd64 metapackage from the beowulf-backports repository.
And to repeat: you *do not* need to install the AMDGPU-PRO drivers, they will offer worse performance than the stock open-source drivers supplied with the kernel (and written by AMD themselves).
Please post the output of
apt policy firmware-amd-graphics
# dmesg | grep firmware # needs to be run as root
uname -a
Your desired resolution will only be supported if you have the firmware package from the non-free component of the repositories so they are entirely relevant here.
It is possible that your monitor isn't supplying a valid EDID block (or perhaps the cable or connector is sub-standard) but the most likely cause is a lack of firmware.
EDIT:
Create an X.Org configuration file with a Screen section containing this option:
   DefaultDepth 30
See also https://linuxreviews.org/HOWTO_enable_1 … r_on_Linux
#8 2020-08-27 12:59:57
Terence
Regarding the backports-repository, I could install `Header files for Linux 5.4.0-0.bpo.2-amd64` from `backports/main` but... there are also things like `libreoffice 1.7` and generally I made bad experience with backports at least under kubuntu.
You are right. For comparison, I made a list of *ubuntu, Debian and Devuan and all three Distros use completely different Kernel even between different flavour (by ubuntu some times).
And you are also right about AMD-Drivers. I was accustomed to use (until three years ago) NVidia proprietary drivers and continue to do so also at (my) beginning with AMD-GPU. Not only daily update/upgrade of those drivers (PPA) but also daily change of display-quality with system-crash/freezing. I stop this.
uname -a
Actually (see above) I run Kubuntu as host and Beowulf in the VM
Host
$ apt policy firmware-amd-graphics
firmware-amd-graphics:
  Installed: (none)
  Candidate: (none)
  Version table:
searching for `firmware-amd` in `synaptic`, show me `amd64-microcode`, this one is blacklisted (see above post).
> no output there on the host
this I posted already but, here is:
$ uname -a
and thus it's works under kubuntu
Client after inserting `backports`
  Installed: (none)
  Candidate: 20190114-2
  Version table:
     20190114-2 500
        500 http://deb.devuan.org/merged beowulf/non-free amd64 Packages
and after installation:
  Installed: 20190114-2
  Version table:
 *** 20190114-2 500
        100 /var/lib/dpkg/status
> also here no output (client)
this I posted (too) already but, here is:
uname -a
EDIT:
   DefaultDepth 30
I install each OS with `non-free` components due online games (for my wife) using `flash`, netflix, etc. and I'm sure to have installed `firmware-amd-graphics` on beowulf want not start at all on my main machine giving me only black-screen and cursor. By the way, this is not newbie-friendly at all, I mean: this package, if crucial for displaying even 1k (1920*1080) and today even smart-phones has such resolution.
Thanks for your submitted link at first, that allowed me to find EDID-report, and here is a part of them to find under `/var/log/Xorg.0log` in the kubuntu-machine
[     7.139] (II) AMDGPU(0): EDID Version: 1.4
[     7.139] (II) AMDGPU(0): Digital Display Input
[     7.139] (II) AMDGPU(0): 10 bits per channel
[     7.139] (II) AMDGPU(0): Digital interface is DisplayPort
[     7.139] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 61  vert.: 35
[     7.139] (II) AMDGPU(0): Gamma: 2.20
[     7.139] (II) AMDGPU(0): DPMS capabilities: Off
[     7.139] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[     7.139] (II) AMDGPU(0): First detailed timing is preferred mode
[     7.139] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[     7.139] (II) AMDGPU(0): Display is continuous-frequency
[     7.139] (II) AMDGPU(0): redX: 0.634 redY: 0.341   greenX: 0.312 greenY: 0.636
[     7.139] (II) AMDGPU(0): blueX: 0.158 blueY: 0.062   whiteX: 0.312 whiteY: 0.329
[     7.139] (II) AMDGPU(0): Supported established timings:
[     7.139] (II) AMDGPU(0): 640x480@60Hz
[     7.139] (II) AMDGPU(0): 800x600@56Hz
[     7.139] (II) AMDGPU(0): 800x600@60Hz
[     7.139] (II) AMDGPU(0): 1024x768@60Hz
[     7.139] (II) AMDGPU(0): Manufacturer's mask: 0
[     7.139] (II) AMDGPU(0): Supported standard timings:
[     7.139] (II) AMDGPU(0): #0: hsize: 1280  vsize 800  refresh: 60  vid: 129
[     7.139] (II) AMDGPU(0): #1: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[     7.139] (II) AMDGPU(0): #2: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[     7.139] (II) AMDGPU(0): #3: hsize: 1600  vsize 900  refresh: 60  vid: 49321
[     7.139] (II) AMDGPU(0): #4: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[     7.139] (II) AMDGPU(0): #5: hsize: 1440  vsize 900  refresh: 60  vid: 149
[     7.139] (II) AMDGPU(0): Supported detailed timing:
[     7.139] (II) AMDGPU(0): clock: 533.2 MHz   Image Size:  607 x 345 mm
[     7.139] (II) AMDGPU(0): h_active: 3840  h_sync: 3888  h_sync_end 3920 h_blank_end 4000 h_border: 0
[     7.139] (II) AMDGPU(0): v_active: 2160  v_sync: 2163  v_sync_end 2168 v_blanking: 2222 v_border: 0
[     7.139] (II) AMDGPU(0): Ranges: V min: 40 V max: 60 Hz, H min: 135 H max: 135 kHz, PixClock max 605 MHz
[     7.139] (II) AMDGPU(0): Monitor name: U28E590
[     7.139] (II) AMDGPU(0): Serial No: HTPK402543
[     7.139] (II) AMDGPU(0): clock: 148.5 MHz   Image Size:  607 x 345 mm
[     7.139] (II) AMDGPU(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[     7.139] (II) AMDGPU(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[     7.139] (II) AMDGPU(0): clock: 241.5 MHz   Image Size:  607 x 345 mm
[     7.139] (II) AMDGPU(0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[     7.139] (II) AMDGPU(0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[     7.139] (II) AMDGPU(0): Number of EDID sections to follow: 1
[     7.139] (II) AMDGPU(0): EDID (in hex):
[     7.139] (II) AMDGPU(0): 	00ffffffffffff004c2d4d0c46584d30
[     7.139] (II) AMDGPU(0): 	0f1c0104b53d23783b5fb1a2574fa228
[     7.139] (II) AMDGPU(0): 	0f5054230800810081c08180a9c0b300
[     7.139] (II) AMDGPU(0): 	9500010101014dd000a0f0703e803020
[     7.139] (II) AMDGPU(0): 	35005f592100001a000000fd00283c87
[     7.139] (II) AMDGPU(0): 	873c010a202020202020000000fc0055
[     7.139] (II) AMDGPU(0): 	3238453539300a2020202020000000ff
[     7.139] (II) AMDGPU(0): 	004854504b3430323534330a202001e5
[     7.139] (II) AMDGPU(0): 	02030ef041102309070783010000023a
[     7.139] (II) AMDGPU(0): 	801871382d40582c45005f592100001e
[     7.139] (II) AMDGPU(0): 	565e00a0a0a02950302035005f592100
[     7.139] (II) AMDGPU(0): 	001a0000000000000000000000000000
[     7.139] (II) AMDGPU(0): 	00000000000000000000000000000000
[     7.139] (II) AMDGPU(0): 	000000000000000000000000000000bf
[     7.139] (II) AMDGPU(0): Printing probed modes for output DisplayPort-2
[     7.139] (II) AMDGPU(0): Modeline "3840x2160"x60.0  533.25  3840 3888 3920 4000  2160 2163 2168 2222 +hsync -vsync (133.3 kHz eP)
[     7.139] (II) AMDGPU(0): Modeline "2560x1440"x60.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1920x1200"x60.0  533.25  1920 3888 3920 4000  1200 2163 2168 2222 +hsync -vsync (133.3 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1600x1200"x60.0  533.25  1600 3888 3920 4000  1200 2163 2168 2222 +hsync -vsync (133.3 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1600x900"x60.0  108.00  1600 1624 1704 1800  900 901 904 1000 +hsync +vsync (60.0 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[     7.139] (II) AMDGPU(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
and no, I don't touch cable or move hardware, just insert USB-stick with Devuan, install it and got black screen.
If you ask me (as newbie) I would say: Devuan take anyway
with/at 1024 instead of
or
with/at 4k.
But, that's just nagging from my side. Facts are:
1. Installed former Devuan3.iso in VM and cannot get a bigger resolution than 1024, no matter what I try.
2. Installed former Devuan3.iso as main system and got black screen, can login, make apdates, install software but was not able to start GUI.
3. Installed newer Devuan3 in VM and (thank you) this time can I get under `systemsettings5` the full choice on resolutions.
4. In the link you provide (was anyway useful) is not explained how to create the necessary file and how to point the system during start to look at this file, besides no explanation on how to start applications (not supporting 10 ) in 8-bit-mode.
My questions:
1. Start Xorg anyway even in text-mode without GUI?
2. Does GRUB use Xorg?
3. If yes, how can I set the right resolution for GUI, TTY and GRUB?
4. How can I increase the resolution during Installation? I cannot see anything!
5. How to start GUI in Devuan with KDE and OpenRC?
6. How to create the `Xorg-configuration-file` properly and how to point the system to look at that during start?
7. How to let read the system at EDID and configure Xorg properly?
8. Where to store the information/data of `xrandr`?
I read/study now this since almost one year, everydody write someting but all is fractionary, nothing complete, even not in the Arch-Linux wiki, e.g. there is written how to crate a `xorg.conf` but not where to fing the right data to write/insert in the right section.
Can you help me? Do you know a newbie-wiki?
#9 2020-08-27 18:48:49
Well that's because Kubuntu is a pile of crap big_smile
For Devuan the backports have a pin value of 100 by default and so will only be installed and upgraded from there if the --target option is used: https://backports.debian.org/Instructions/
Kubuntu include the firmware blobs in the kernel (bunch of degenerates) and a beowulf VM will not "see" your video card unless you pass through the PCI address.
Check the lspci output in the VM, it will almost certainly show a virtual video card.
Well the RX580 card is definitely supported, as confirmed by rolfie earlier in this thread.
If you're using VirtualBox (which you shouldn't because it's shit) then you need the "guest additions" for proper graphics support. Ask the interweb about it (or switch to QEMU/KVM, which is faster and generally better all-round).
For a bare metal installation you will need the firmware-amd-graphics package, as I have mentioned several times now.
Terence wrote:
Does GRUB use Xorg?
No.
Press c at the GRUB screen, use the vbeinfo command to list the supported resolutions then press escape and edit the installer GRUB menuentry to add the desired resolution to the end of the line that starts with linux; for example:
video=800x600@75
Read man xorg.conf. The system will automatically read the file if it is placed in the correct location.
If Kubuntu displays the correct resolution then the EDID block is not the problem.
#10 2020-08-30 09:09:11
Terence
I have tested in the VM, the addition of `backports` don't automatically update/upgrade all installed packages, but only the special picked. Buntu-Distros update/upgrade everything.
That's clear.
It is now a Vega64
Well, I followed your recommendation. Installed Beowulf on KVM (`virt-manager`) with `backports` and `firmaware-amd-graphics`.
Max. chooseable resolution is 1920*1200. Does it mean, due the fact that in KVM hasn't 'guest.iso', that if I install `Beowulf`on my NVMe I will have a max of ca. 1k instead of 4k?
Baremetal yes, 4k (3840*2160) not at all. EDID is OK, firmware is OK, xrandr is ok, resolution not, the thread will never close this way.
Reading this https://wiki.gentoo.org/wiki/Xorg/Guide (start plasma5 with `openrc`) and due already tentative (in the past) to `startx` with the same commands:
startx
startkde
startx /usr/bin/startkde
startx -- vt7
it appear that (former) installation on real machine failed completely/was not able to start plasma5.
video=800x600@75
vbeinfo is deprecated, videoinfo is actual command, but by the ISO-start I can use a magnifier for that. Later on I can increase font-dpi for grub, etc. if I need.
I meant the installation-representation, under *buntus is called `ubiquity`. There is much more to read and write. Maybe I can switch shortly to terminal command and force `os-installer-resolution` to higher value and be able to read the installer-text.
I don't think I have to use # Xorg :0 -configure as here https://wiki.archlinux.org/index.php/Xorg explained because `xorg` already exist, what I need is:
1. Right placement of GPU-drivers
2. Resolution 3840*2160
3. 144*144 dpi
4. 10-bit color deepness
That's absolutely not clear for me, so far not clear that I cannot even start an attempt in the virtual OS. No newbie explanation here?
#11 2020-08-30 10:32:05
You don't need a backported kernel or the AMD graphics firmware if you're running in a VM because the VM isn't exposed to the AMD card (as I already explained and as you already claimed to have understood).
I don't use virt-manager but I know that the default -vga std option for QEMU supports up to 2560x1600. The -vga qxl option will support up to 2560x1440 and higher resolutions are available if the VGA memory size for the QXL drivers is increased: https://wiki.archlinux.org/index.php/QE … or_support
I presume your guest has the xserver-xorg-video-qxl package installed?
No, it will never end unless you start providing some logs that are relevant to the problem (in this case the X.Org log) and clearly state which version of the kernel and firmware packages are installed.
@rolfie says that the RX580 works for them, I don't have that card or a 4k monitor so I can't really comment directly.
Oops, sorry.
Well just use the non-graphical installer then. I was under the impression that the beowulf ISO didn't provide a graphical installer anyway.
Apparently not, no.
#12 2020-09-04 16:04:39
Terence
I recognize a dissonance between your writing and the pseudo-reality of VM's, in fact I installed now also MX-Linux (another Xfce with sysvinit) with MVs exact same adjustments. Here the xrandr-outputs...
Kubuntu real OS:
xrandr
Screen 0: minimum 320 x 200, current 3840 x 2160, maximum 16384 x 16384
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 607mm x 345mm
   3840x2160     60.00*+
   2560x1440     59.95
   1920x1200     60.00
   1920x1080     60.00    59.94
   1600x1200     60.00
   1680x1050     59.95
   1600x900      60.00
   1280x1024     60.02
   1440x900      59.89
   1280x800      59.81
   1280x720      60.00    59.94
   1024x768      60.00
   800x600       60.32    56.25
   640x480       60.00    59.94
this OS hasn't 'firmware-amd-graphics' but 'linux-firmware' Ver. 1.187.3
Devuan-Beowulf VM:
xrandr
Screen 0: minimum 1 x 1, current 2560 x 1600, maximum 8192 x 8192
Virtual1 connected primary 2560x1600+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   800x600        60.00 + 60.32
   2560x1600    59.99*
   1920x1440    60.00
   1856x1392    60.00
   1792x1344    60.00
   1920x1200    59.88
   1600x1200    60.00
   1680x1050    59.95
   1400x1050    59.98
   1280x1024    60.02
   1440x900      59.89
   1280x960      60.00
   1360x768      60.02
   1280x800      59.81
   1152x864      75.00
   1280x768      59.87
   1024x768      60.00
   640x480        59.94
this OS has 'firmware-amd-graphics' Vers. '20190114-2' and 'firmware-linux-free' Vers. '3.4`and 'firmware-linux-nonfree' Vers. '20190114-2'. Here in Devuan is all completely different, even from MX-Linux (also Debian-like with 'sysvinit').
MX-Linux VM:
xrandr
Screen 0: minimum 1 x 1, current 3840 x 2160, maximum 8192 x 8192
Virtual1 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   2560x1600     59.99
   1920x1440     60.00
   1856x1392     60.00
   1792x1344     60.00
   1920x1200     59.88
   1600x1200     60.00
   1680x1050     59.95
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1360x768      60.02
   1280x800      59.81
   1152x864      75.00
   1280x768      59.87
   1024x768      60.00
   640x480       59.94
   3840x2160_vbox  59.98*
this OS has 'firmware-amd-graphics' Vers. '20200721-1~mx19+1' and 'firmware-linux-free' Vers. '20200721-1~mx19+1`and 'firmware-linux-nonfree' Vers. '20200721-1~mx19+1'
Note-s:
1. All, in the VM installed OS show natively (just after install) a reduced resolution (1024x768 Devuan, 2500x1600 MX-linux), the full or possible max. resolution is given only after installing 'firmware-amd-graphics'. This all without 'guest-addition.iso'
2. I delete the old VM's and reinstall them new.
3. Beowulf install by default 'firmware-linux-free' Vers. '3.4' the 'firmware-linux-nonfree' (I have installed afterwards for testing) don't bring anythings.
It doesn't or 'Beowulf' is not able. Reading instructions I increase the memory amount to 128K (the same quantity as in Virtual-Box), didn't help, here the outputs:
/etc/libvirt/qemu/devuan3.xml
sudo virsh edit devuan3
Select an editor.  To change later, run 'select-editor'.
  1. /bin/nano        <---- easiest
  2. /usr/bin/vim.tiny
  3. /usr/bin/emacs
  4. /bin/ed
Choose 1-4 [1]: 1
<video>
      <model type='qxl' ram='131072' vram='131072' vgamem='131072' heads='1' primary='yes'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
    </video>
If you don't use 'virt-manager' what are you using? Do we make only a theoretical discussion or we tray to find a practical solution? Maybe detailed instructions `step-by-step` so we can help also other people besides of our-self.
of course.
Packages and Version delivered, see above, 'X.Org log' (I think) will only help if drivers/firmware-version is mentioned, anyway here are the '/var/log/Xorg.0log's...
Sorry to big; I can't post them complete (not of real system, nor of Devuan) but...
MX-Linux VM:
[    11.340] (--) Log file renamed from "/var/log/Xorg.pid-2808.log" to "/var/log/Xorg.0.log"
[    11.341]
X.Org X Server 1.20.4
[    11.341] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
[    11.341] Current Operating System: Linux mx-tony 4.19.0-10-amd64 #1 SMP Debian 4.19.132-1 (2020-07-24) x86_64
[    11.341] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-10-amd64 root=UUID=2833381e-bcce-4f95-80ef-73a6a47e984b ro quiet splash
[    11.341] Build Date: 05 March 2019  08:11:12PM
[    11.341] xorg-server 2:1.20.4-1 (https://www.debian.org/support)
[    11.341] Current version of pixman: 0.36.0
[    11.341] 	Before reporting problems, check http://wiki.x.org
[    11.341] Markers: (--) probed, (**) from config file, (==) default setting,
[    11.341] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Sep  4 09:46:13 2020
[    11.344] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    11.344] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    11.348] (==) No Layout section.  Using the first Screen section.
[    11.348] (==) No screen section available. Using defaults.
[    11.348] (**) |-->Screen "Default Screen Section" (0)
[    11.348] (**) |   |-->Monitor "<default monitor>"
[    11.350] (==) No monitor specified for screen "Default Screen Section".
[    11.350] (==) Automatically adding devices
[    11.350] (==) Automatically enabling devices
[    11.350] (==) Automatically adding GPU devices
[    11.350] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    11.356] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    11.356] 	Entry deleted from font path.
[    11.360] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    11.360] (==) ModulePath set to "/usr/lib/xorg/modules"
[    11.360] (II) The server relies on udev to provide the list of input devices.
[    11.360] (II) Loader magic: 0x55a07dc1ee20
[    11.360] (II) Module ABI versions:
[    11.360] 	X.Org ANSI C Emulation: 0.4
[    11.360] 	X.Org Video Driver: 24.0
[    11.360] 	X.Org XInput driver : 24.1
[    11.360] 	X.Org Server Extension : 10.0
[    11.362] (++) using VT number 7
[    11.362] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    11.363] (II) xfree86: Adding drm device (/dev/dri/card0)
[    11.366] (--) PCI:*(0@0:2:0) 15ad:0405:15ad:0405 rev 0, Mem @ 0xf0000000/134217728, 0xf8000000/2097152, I/O @ 0x0000d010/16, BIOS @ 0x????????/131072
[    11.366] (II) LoadModule: "glx"
[    11.367] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    11.373] (II) Module glx: vendor="X.Org Foundation"
[    11.373] 	compiled for 1.20.4, module version = 1.0.0
[    11.373] 	ABI class: X.Org Server Extension, version 10.0
[    11.373] (==) Matched vmware as autoconfigured driver 0
[    11.373] (==) Matched modesetting as autoconfigured driver 1
[    11.373] (==) Matched fbdev as autoconfigured driver 2
[    11.373] (==) Matched vesa as autoconfigured driver 3
[    11.373] (==) Assigned the driver to the xf86ConfigLayout
[    11.373] (II) LoadModule: "vmware"
[    11.373] (II) Loading /usr/lib/xorg/modules/drivers/vmware_drv.so
[    11.477] (II) Module vmware: vendor="X.Org Foundation"
[    11.477] 	compiled for 1.20.0, module version = 13.3.0
[    11.477] 	Module class: X.Org Video Driver
[    11.477] 	ABI class: X.Org Video Driver, version 24.0
[    11.477] (II) LoadModule: "modesetting"
[    11.477] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    11.479] (II) Module modesetting: vendor="X.Org Foundation"
[    11.479] 	compiled for 1.20.4, module version = 1.20.4
[    11.479] 	Module class: X.Org Video Driver
[    11.479] 	ABI class: X.Org Video Driver, version 24.0
[    11.479] (II) LoadModule: "fbdev"
[    11.479] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    11.480] (II) Module fbdev: vendor="X.Org Foundation"
[    11.480] 	compiled for 1.20.0, module version = 0.5.0
[    11.480] 	Module class: X.Org Video Driver
[    11.480] 	ABI class: X.Org Video Driver, version 24.0
[    11.480] (II) LoadModule: "vesa"
[    11.480] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[    11.481] (II) Module vesa: vendor="X.Org Foundation"
[    11.481] 	compiled for 1.20.1, module version = 2.4.0
[    11.481] 	Module class: X.Org Video Driver
[    11.481] 	ABI class: X.Org Video Driver, version 24.0
[    11.481] (II) vmware: driver for VMware SVGA: vmware0405, vmware0710
[    11.481] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    11.481] (II) FBDEV: driver for framebuffer: fbdev
[    11.481] (II) VESA: driver for VESA chipsets: vesa
[    11.482] (WW) Falling back to old probe method for modesetting
[    11.482] (WW) Falling back to old probe method for fbdev
[    11.482] (II) Loading sub module "fbdevhw"
[    11.482] (II) LoadModule: "fbdevhw"
[    11.483] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    11.483] (II) Module fbdevhw: vendor="X.Org Foundation"
[    11.483] 	compiled for 1.20.4, module version = 0.0.2
[    11.483] 	ABI class: X.Org Video Driver, version 24.0
[    11.483] (II) vmware(0): Creating default Display subsection in Screen section
[    11.484] (--) vmware(0): DRM driver version is 2.15.0
[    11.484] (==) vmware(0): Depth 24, (--) framebuffer bpp 32
[    11.484] (==) vmware(0): RGB weight 888
[    11.484] (==) vmware(0): Default visual is TrueColor
[    11.484] (--) vmware(0): Min width 1, Max Width 8192.
[    11.484] (--) vmware(0): Min height 1, Max Height 8192.
[    11.484] (II) vmware(0): Output Virtual1 has no monitor section
[    11.484] (II) vmware(0): Output Virtual2 has no monitor section
[    11.484] (II) vmware(0): Output Virtual3 has no monitor section
[    11.484] (II) vmware(0): Output Virtual4 has no monitor section
[    11.484] (II) vmware(0): Output Virtual5 has no monitor section
[    11.484] (II) vmware(0): Output Virtual6 has no monitor section
[    11.484] (II) vmware(0): Output Virtual7 has no monitor section
[    11.484] (II) vmware(0): Output Virtual8 has no monitor section
[    11.484] (II) vmware(0): Printing probed modes for output Virtual1
[    11.484] (II) vmware(0): Modeline "800x600"x60.0   42.75  800 850 900 950  600 650 700 750 -hsync +vsync (45.0 kHz eP)
[    11.484] (II) vmware(0): Modeline "2560x1600"x60.0  348.50  2560 2752 3032 3504  1600 1603 1609 1658 -hsync +vsync (99.5 kHz e)
[    11.484] (II) vmware(0): Modeline "1920x1440"x60.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[    11.484] (II) vmware(0): Modeline "1856x1392"x60.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[    11.484] (II) vmware(0): Modeline "1792x1344"x60.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[    11.484] (II) vmware(0): Modeline "1920x1200"x59.9  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[    11.484] (II) vmware(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[    11.484] (II) vmware(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[    11.484] (II) vmware(0): Modeline "1400x1050"x60.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[    11.484] (II) vmware(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[    11.484] (II) vmware(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[    11.484] (II) vmware(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[    11.484] (II) vmware(0): Modeline "1360x768"x60.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[    11.484] (II) vmware(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 +hsync -vsync (49.7 kHz e)
[    11.484] (II) vmware(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    11.484] (II) vmware(0): Modeline "1280x768"x59.9   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[    11.484] (II) vmware(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    11.484] (II) vmware(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    11.484] (II) vmware(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 489 492 525 -hsync -vsync (31.5 kHz e)
[    11.484] (II) vmware(0): EDID for output Virtual2
[    11.484] (II) vmware(0): EDID for output Virtual3
[    11.484] (II) vmware(0): EDID for output Virtual4
[    11.484] (II) vmware(0): EDID for output Virtual5
[    11.484] (II) vmware(0): EDID for output Virtual6
[    11.484] (II) vmware(0): EDID for output Virtual7
[    11.484] (II) vmware(0): EDID for output Virtual8
[    11.484] (II) vmware(0): Output Virtual1 connected
[    11.484] (II) vmware(0): Output Virtual2 disconnected
[    11.484] (II) vmware(0): Output Virtual3 disconnected
[    11.484] (II) vmware(0): Output Virtual4 disconnected
[    11.484] (II) vmware(0): Output Virtual5 disconnected
[    11.484] (II) vmware(0): Output Virtual6 disconnected
[    11.484] (II) vmware(0): Output Virtual7 disconnected
[    11.484] (II) vmware(0): Output Virtual8 disconnected
[    11.484] (II) vmware(0): Using exact sizes for initial modes
[    11.484] (II) vmware(0): Output Virtual1 using initial mode 800x600 +0+0
[    11.484] (==) vmware(0): DPI set to (96, 96)
[    11.484] (==) vmware(0): Using gamma correction (1.0, 1.0, 1.0)
[    11.484] (II) Loading sub module "fb"
[    11.484] (II) LoadModule: "fb"
[    11.484] (II) Loading /usr/lib/xorg/modules/libfb.so
[    11.485] (II) Module fb: vendor="X.Org Foundation"
[    11.485] 	compiled for 1.20.4, module version = 1.0.0
[    11.485] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    11.485] (II) Loading sub module "dri2"
[    11.485] (II) LoadModule: "dri2"
[    11.485] (II) Module "dri2" already built-in
[    11.485] (II) Loading sub module "dri3"
[    11.485] (II) LoadModule: "dri3"
[    11.485] (II) Module "dri3" already built-in
[    11.485] (II) UnloadModule: "modesetting"
[    11.485] (II) Unloading modesetting
[    11.485] (II) UnloadModule: "fbdev"
[    11.485] (II) Unloading fbdev
[    11.485] (II) UnloadSubModule: "fbdevhw"
[    11.485] (II) Unloading fbdevhw
[    11.485] (II) UnloadModule: "vesa"
[    11.485] (II) Unloading vesa
[    11.486] (II) vmware(0): Initialized VMWARE_CTRL extension version 0.2
[    11.511] (II) vmware(0): Gallium3D XA version: 2.5.0.
[    11.511] (II) vmware(0): Path of drm device is "/dev/dri/card0".
[    11.512] (II) vmware(0): [DRI2] Setup complete
[    11.512] (II) vmware(0): [DRI2]   DRI driver: vmwgfx
[    11.512] (EE) vmware(0): Failed to initialize direct rendering DRI3.
[    11.512] (--) vmware(0): Render acceleration is enabled.
[    11.512] (==) vmware(0): Rendercheck mode is disabled.
[    11.512] (--) vmware(0): Direct rendering (DRI2 3D) is enabled.
[    11.512] (--) vmware(0): Direct rendering (DRI3 3D) is disabled.
[    11.512] (==) vmware(0): Direct presents are disabled.
[    11.512] (==) vmware(0): Hardware only presents are disabled.
[    11.512] (==) vmware(0): Backing store enabled
[    11.512] (==) vmware(0): Silken mouse enabled
[    11.513] (==) vmware(0): DPMS enabled
[    11.513] (II) Initializing extension Generic Event Extension
[    11.513] (II) Initializing extension SHAPE
[    11.513] (II) Initializing extension MIT-SHM
[    11.513] (II) Initializing extension XInputExtension
[    11.514] (II) Initializing extension XTEST
[    11.514] (II) Initializing extension BIG-REQUESTS
[    11.514] (II) Initializing extension SYNC
[    11.514] (II) Initializing extension XKEYBOARD
[    11.515] (II) Initializing extension XC-MISC
[    11.515] (II) Initializing extension SECURITY
[    11.515] (II) Initializing extension XFIXES
[    11.515] (II) Initializing extension RENDER
[    11.515] (II) Initializing extension RANDR
[    11.516] (II) Initializing extension COMPOSITE
[    11.516] (II) Initializing extension DAMAGE
[    11.516] (II) Initializing extension MIT-SCREEN-SAVER
[    11.516] (II) Initializing extension DOUBLE-BUFFER
[    11.517] (II) Initializing extension RECORD
[    11.517] (II) Initializing extension DPMS
[    11.517] (II) Initializing extension Present
[    11.517] (II) Initializing extension DRI3
[    11.517] (II) Initializing extension X-Resource
[    11.517] (II) Initializing extension XVideo
[    11.517] (II) Initializing extension XVideo-MotionCompensation
[    11.517] (II) Initializing extension SELinux
[    11.517] (II) SELinux: Disabled on system
[    11.517] (II) Initializing extension GLX
[    11.548] (II) AIGLX: Loaded and initialized vmwgfx
[    11.548] (II) GLX: Initialized DRI2 GL provider for screen 0
[    11.548] (II) Initializing extension XFree86-VidModeExtension
[    11.548] (II) Initializing extension XFree86-DGA
[    11.548] (II) Initializing extension XFree86-DRI
[    11.548] (II) Initializing extension DRI2
[    11.551] (II) vmware(0): Setting screen physical size to 211 x 158
[    11.618] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    11.618] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    11.618] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    11.618] (II) LoadModule: "evdev"
[    11.618] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    11.620] (II) Module evdev: vendor="X.Org Foundation"
[    11.620] 	compiled for 1.20.1, module version = 2.10.6
[    11.620] 	Module class: X.Org XInput Driver
[    11.620] 	ABI class: X.Org XInput driver, version 24.1
[    11.620] (II) Using input driver 'evdev' for 'Power Button'
[    11.620] (**) Power Button: always reports core events
[    11.620] (**) evdev: Power Button: Device: "/dev/input/event1"
[    11.620] (--) evdev: Power Button: Vendor 0 Product 0x1
[    11.620] (--) evdev: Power Button: Found keys
[    11.620] (II) evdev: Power Button: Configuring as keyboard
[    11.620] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event1"
[    11.620] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    11.620] (**) Option "xkb_rules" "evdev"
[    11.620] (**) Option "xkb_model" "pc105"
[    11.620] (**) Option "xkb_layout" "de"
[    11.620] (**) Option "xkb_variant" "nodeadkeys"
[    11.620] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll,terminate:ctrl_alt_bksp"
[    11.641] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[    11.641] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    11.641] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    11.641] (II) Using input driver 'evdev' for 'Sleep Button'
[    11.641] (**) Sleep Button: always reports core events
[    11.641] (**) evdev: Sleep Button: Device: "/dev/input/event2"
[    11.641] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[    11.641] (--) evdev: Sleep Button: Found keys
[    11.641] (II) evdev: Sleep Button: Configuring as keyboard
[    11.641] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSLPBN:00/input/input3/event2"
[    11.641] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[    11.641] (**) Option "xkb_rules" "evdev"
[    11.641] (**) Option "xkb_model" "pc105"
[    11.641] (**) Option "xkb_layout" "de"
[    11.641] (**) Option "xkb_variant" "nodeadkeys"
[    11.642] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll,terminate:ctrl_alt_bksp"
[    11.642] (II) config/udev: Adding input device Video Bus (/dev/input/event3)
[    11.642] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    11.642] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    11.643] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    11.643] (II) Using input driver 'evdev' for 'Video Bus'
[    11.643] (**) Video Bus: always reports core events
[    11.643] (**) evdev: Video Bus: Device: "/dev/input/event3"
[    11.643] (--) evdev: Video Bus: Vendor 0 Product 0x6
[    11.643] (--) evdev: Video Bus: Found keys
[    11.643] (II) evdev: Video Bus: Configuring as keyboard
[    11.643] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:00/input/input4/event3"
[    11.643] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    11.643] (**) Option "xkb_rules" "evdev"
[    11.643] (**) Option "xkb_model" "pc105"
[    11.643] (**) Option "xkb_layout" "de"
[    11.643] (**) Option "xkb_variant" "nodeadkeys"
[    11.643] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll,terminate:ctrl_alt_bksp"
[    11.644] (II) config/udev: Adding input device VirtualBox mouse integration (/dev/input/event6)
[    11.645] (**) VirtualBox mouse integration: Applying InputClass "evdev pointer catchall"
[    11.645] (**) VirtualBox mouse integration: Applying InputClass "libinput pointer catchall"
[    11.645] (II) Using input driver 'evdev' for 'VirtualBox mouse integration'
[    11.645] (**) VirtualBox mouse integration: always reports core events
[    11.645] (**) evdev: VirtualBox mouse integration: Device: "/dev/input/event6"
[    11.645] (--) evdev: VirtualBox mouse integration: Vendor 0x80ee Product 0xcafe
[    11.645] (--) evdev: VirtualBox mouse integration: Found 1 mouse buttons
[    11.645] (--) evdev: VirtualBox mouse integration: Found absolute axes
[    11.645] (--) evdev: VirtualBox mouse integration: Found x and y absolute axes
[    11.645] (--) evdev: VirtualBox mouse integration: Found absolute touchscreen
[    11.645] (II) evdev: VirtualBox mouse integration: Configuring as touchscreen
[    11.645] (**) evdev: VirtualBox mouse integration: YAxisMapping: buttons 4 and 5
[    11.645] (**) evdev: VirtualBox mouse integration: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    11.645] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:04.0/input/input7/event6"
[    11.645] (II) XINPUT: Adding extended input device "VirtualBox mouse integration" (type: TOUCHSCREEN, id 9)
[    11.645] (II) evdev: VirtualBox mouse integration: initialized for absolute axes.
[    11.645] (**) VirtualBox mouse integration: (accel) keeping acceleration scheme 1
[    11.645] (**) VirtualBox mouse integration: (accel) acceleration profile 0
[    11.645] (**) VirtualBox mouse integration: (accel) acceleration factor: 2.000
[    11.645] (**) VirtualBox mouse integration: (accel) acceleration threshold: 4
[    11.646] (II) config/udev: Adding input device VirtualBox mouse integration (/dev/input/js1)
[    11.646] (II) No input driver specified, ignoring this device.
[    11.646] (II) This device may have been added with another device file.
[    11.646] (II) config/udev: Adding input device HDA Intel Speaker Front (/dev/input/event9)
[    11.646] (II) config/udev: Adding input device HDA Intel Speaker CLFE (/dev/input/event10)
[    11.647] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event11)
[    11.647] (II) No input driver specified, ignoring this device.
[    11.647] (II) This device may have been added with another device file.
[    11.647] (II) config/udev: Adding input device HDA Intel SPDIF In (/dev/input/event12)
[    11.647] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event7)
[    11.647] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event8)
[    11.648] (II) config/udev: Adding input device VirtualBox USB Tablet (/dev/input/event5)
[    11.648] (**) VirtualBox USB Tablet: Applying InputClass "evdev pointer catchall"
[    11.648] (**) VirtualBox USB Tablet: Applying InputClass "libinput pointer catchall"
[    11.648] (II) Using input driver 'evdev' for 'VirtualBox USB Tablet'
[    11.648] (**) VirtualBox USB Tablet: always reports core events
[    11.648] (**) evdev: VirtualBox USB Tablet: Device: "/dev/input/event5"
[    11.708] (--) evdev: VirtualBox USB Tablet: Vendor 0x80ee Product 0x21
[    11.708] (--) evdev: VirtualBox USB Tablet: Found 9 mouse buttons
[    11.708] (--) evdev: VirtualBox USB Tablet: Found scroll wheel(s)
[    11.708] (--) evdev: VirtualBox USB Tablet: Found relative axes
[    11.709] (--) evdev: VirtualBox USB Tablet: Found absolute axes
[    11.709] (--) evdev: VirtualBox USB Tablet: Found x and y absolute axes
[    11.709] (--) evdev: VirtualBox USB Tablet: Found absolute touchscreen
[    11.709] (II) evdev: VirtualBox USB Tablet: Configuring as touchscreen
[    11.709] (II) evdev: VirtualBox USB Tablet: Adding scrollwheel support
[    11.709] (**) evdev: VirtualBox USB Tablet: YAxisMapping: buttons 4 and 5
[    11.709] (**) evdev: VirtualBox USB Tablet: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    11.709] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:06.0/usb1/1-1/1-1:1.0/0003:80EE:0021.0001/input/input6/event5"
[    11.709] (II) XINPUT: Adding extended input device "VirtualBox USB Tablet" (type: TOUCHSCREEN, id 10)
[    11.709] (WW) evdev: VirtualBox USB Tablet: touchpads, tablets and touchscreens ignore relative axes.
[    11.709] (II) evdev: VirtualBox USB Tablet: initialized for absolute axes.
[    11.709] (**) VirtualBox USB Tablet: (accel) keeping acceleration scheme 1
[    11.709] (**) VirtualBox USB Tablet: (accel) acceleration profile 0
[    11.709] (**) VirtualBox USB Tablet: (accel) acceleration factor: 2.000
[    11.709] (**) VirtualBox USB Tablet: (accel) acceleration threshold: 4
[    11.710] (II) config/udev: Adding input device VirtualBox USB Tablet (/dev/input/js0)
[    11.710] (II) No input driver specified, ignoring this device.
[    11.710] (II) This device may have been added with another device file.
[    11.710] (II) config/udev: Adding input device VirtualBox USB Tablet (/dev/input/mouse1)
[    11.711] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    11.711] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    11.711] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    11.711] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    11.711] (**) AT Translated Set 2 keyboard: always reports core events
[    11.711] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[    11.711] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[    11.711] (--) evdev: AT Translated Set 2 keyboard: Found keys
[    11.711] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[    11.711] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    11.711] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[    11.711] (**) Option "xkb_rules" "evdev"
[    11.711] (**) Option "xkb_model" "pc105"
[    11.711] (**) Option "xkb_layout" "de"
[    11.711] (**) Option "xkb_variant" "nodeadkeys"
[    11.711] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll,terminate:ctrl_alt_bksp"
[    11.712] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/event4)
[    11.712] (**) ImExPS/2 Generic Explorer Mouse: Applying InputClass "evdev pointer catchall"
[    11.712] (**) ImExPS/2 Generic Explorer Mouse: Applying InputClass "libinput pointer catchall"
[    11.712] (II) Using input driver 'evdev' for 'ImExPS/2 Generic Explorer Mouse'
[    11.712] (**) ImExPS/2 Generic Explorer Mouse: always reports core events
[    11.712] (**) evdev: ImExPS/2 Generic Explorer Mouse: Device: "/dev/input/event4"
[    11.712] (--) evdev: ImExPS/2 Generic Explorer Mouse: Vendor 0x2 Product 0x6
[    11.712] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found 9 mouse buttons
[    11.712] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found scroll wheel(s)
[    11.712] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found relative axes
[    11.712] (--) evdev: ImExPS/2 Generic Explorer Mouse: Found x and y relative axes
[    11.712] (II) evdev: ImExPS/2 Generic Explorer Mouse: Configuring as mouse
[    11.712] (II) evdev: ImExPS/2 Generic Explorer Mouse: Adding scrollwheel support
[    11.712] (**) evdev: ImExPS/2 Generic Explorer Mouse: YAxisMapping: buttons 4 and 5
[    11.712] (**) evdev: ImExPS/2 Generic Explorer Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    11.712] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input5/event4"
[    11.712] (II) XINPUT: Adding extended input device "ImExPS/2 Generic Explorer Mouse" (type: MOUSE, id 12)
[    11.712] (II) evdev: ImExPS/2 Generic Explorer Mouse: initialized for relative axes.
[    11.712] (**) ImExPS/2 Generic Explorer Mouse: (accel) keeping acceleration scheme 1
[    11.712] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration profile 0
[    11.712] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration factor: 2.000
[    11.712] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration threshold: 4
[    11.713] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/mouse0)
[    11.713] (II) No input driver specified, ignoring this device.
[    11.713] (II) This device may have been added with another device file.
[    11.714] (II) config/udev: Adding input device ACPI Virtual Keyboard Device (/dev/input/event13)
[    11.714] (**) ACPI Virtual Keyboard Device: Applying InputClass "evdev keyboard catchall"
[    11.714] (**) ACPI Virtual Keyboard Device: Applying InputClass "libinput keyboard catchall"
[    11.714] (II) Using input driver 'evdev' for 'ACPI Virtual Keyboard Device'
[    11.714] (**) ACPI Virtual Keyboard Device: always reports core events
[    11.714] (**) evdev: ACPI Virtual Keyboard Device: Device: "/dev/input/event13"
[    11.714] (--) evdev: ACPI Virtual Keyboard Device: Vendor 0 Product 0
[    11.714] (--) evdev: ACPI Virtual Keyboard Device: Found keys
[    11.714] (II) evdev: ACPI Virtual Keyboard Device: Configuring as keyboard
[    11.714] (**) Option "config_info" "udev:/sys/devices/virtual/input/input14/event13"
[    11.714] (II) XINPUT: Adding extended input device "ACPI Virtual Keyboard Device" (type: KEYBOARD, id 13)
[    11.714] (**) Option "xkb_rules" "evdev"
[    11.714] (**) Option "xkb_model" "pc105"
[    11.714] (**) Option "xkb_layout" "de"
[    11.714] (**) Option "xkb_variant" "nodeadkeys"
[    11.714] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll,terminate:ctrl_alt_bksp"
[    11.726] (EE) Failed to open authorization file "/var/run/sddm/{0d86ffd0-aeec-4ffa-9ba1-7f2fa7edf610}": No such file or directory
Note: The same kernel-version as beowulf
He as well other claim to have done something functioning but... either don't know how they have doing that or just need to write someone with the hope respond.
Oops, sorry.
NoPs
Of course, and that's problem (with 4k-monitor), while kubuntu-installer (graphic/live) can scaale the resolution ('systemsettings5') or Virtual-Box can scale up (for seeing better by installation) and down (to 100%) after the installation... on real install is only a kind  of colored terminal. This one ('colored terminal') I want scale up, anyway it not influence the installed system (for this remaine all mentioned 'problems').
Apparently not, no.
If so, that's bad, very bad.
Considerations:
1. Xfce is not my solution (as well gnome and Co.) due to 200% scaling (and scaling back with writing in numerouse config.files).
2. Gtk is even not a solution (getting error messages even in synaptic besides Xfce).
3. Nobody know how to setup a good 4k or want not tell or I put the wrong questions (maybe I start a new thread).
4. If I not get a working solution for Devuan I will aquantaine myself with Gentoo.
#13 2020-09-04 18:31:19
Looks like MX is booted in VirtualBox (they include the guest additions in the stock system), was Devuan also in VirtualBox and if so did it also have the guest additions installed?
What video card and kernel driver does lspci -k report for the VMs?
qemu-system-x86_64 -enable kvm -m 4G -vga qxl -soundhw hda -cdrom /path/to/ISO.img
See also http://forums.debian.net/viewtopic.php?f=16&t=144775
Upload the file to a pastebin and share the link:
curl -F 'f:1=<-' ix.io < /var/log/Xorg.0.log
I'm not interested in the MX log, that is of no use for this thread.
Terence wrote:
Apparently not, no.
I just can't be arsed posting a "newbie explanation" for how to create an X.Org configuration file, that's all. I'm sure there are some out there if you search a bit, or maybe another forum member with more patience than me will take pity on you.
What makes you think I care which distribution you use? hmm
#14 2020-09-07 16:45:43
Terence
Re: amdgpu-pro drivers
'Synaptic' report a 'virtualbox-guest-addition.iso' is installed, I remove it. To be able to copy/paste between host and guest I installed it in the virtual-os. In this way I have full resolution as expected, but... you say 'it's crap'.
Does it mean that if I install the OS on real hardware will start and run normally?
Now with Guest-addition.iso can I post /var/log/
[     5.984] (--) Log file renamed from "/var/log/Xorg.pid-3050.log" to "/var/log/Xorg.0.log"
[     5.985]
[     5.985] Build Operating System: Linux 4.19.0-10-amd64 x86_64 Debian
[     5.985] Current Operating System: Linux devuan3 5.7.0-0.bpo.2-amd64 #1 SMP Debian 5.7.10-1~bpo10+1 (2020-07-30) x86_64
[     5.985] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.7.0-0.bpo.2-amd64 root=UUID=617b22fa-55d1-4a35-94fa-73bd82eadd69 ro quiet
[     5.985] Build Date: 27 August 2020  08:51:48AM
[     5.985] xorg-server 2:1.20.4-1+deb10u1 (https://www.debian.org/support)
[     5.985] Current version of pixman: 0.36.0
[     5.985] 	Before reporting problems, check http://wiki.x.org
[     5.985] Markers: (--) probed, (**) from config file, (==) default setting,
[     5.985] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep  7 11:53:01 2020
[     5.987] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     5.988] (==) No Layout section.  Using the first Screen section.
[     5.988] (==) No screen section available. Using defaults.
[     5.988] (**) |-->Screen "Default Screen Section" (0)
[     5.988] (**) |   |-->Monitor "<default monitor>"
[     5.988] (==) No monitor specified for screen "Default Screen Section".
[     5.988] (==) Automatically adding devices
[     5.988] (==) Automatically enabling devices
[     5.988] (==) Automatically adding GPU devices
[     5.989] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     5.989] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[     5.989] 	Entry deleted from font path.
[     5.991] (==) FontPath set to:
	built-ins
[     5.991] (==) ModulePath set to "/usr/lib/xorg/modules"
[     5.991] (II) The server relies on udev to provide the list of input devices.
[     5.991] (II) Loader magic: 0x558131fe2e20
[     5.991] (II) Module ABI versions:
[     5.991] 	X.Org ANSI C Emulation: 0.4
[     5.991] 	X.Org Video Driver: 24.0
[     5.991] 	X.Org XInput driver : 24.1
[     5.991] 	X.Org Server Extension : 10.0
[     5.991] (++) using VT number 7
[     5.991] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     5.992] (II) xfree86: Adding drm device (/dev/dri/card0)
[     5.993] (--) PCI:*(0@0:2:0) 15ad:0405:15ad:0405 rev 0, Mem @ 0xf0000000/134217728, 0xf8000000/2097152, I/O @ 0x0000d010/16, BIOS @ 0x????????/131072
[     5.993] (II) LoadModule: "glx"
[     5.993] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     6.000] (II) Module glx: vendor="X.Org Foundation"
[     6.000] 	compiled for 1.20.4, module version = 1.0.0
[     6.000] 	ABI class: X.Org Server Extension, version 10.0
[     6.000] (==) Matched vmware as autoconfigured driver 0
[     6.000] (==) Matched modesetting as autoconfigured driver 1
[     6.000] (==) Matched fbdev as autoconfigured driver 2
[     6.000] (==) Matched vesa as autoconfigured driver 3
[     6.000] (==) Assigned the driver to the xf86ConfigLayout
[     6.000] (II) LoadModule: "vmware"
[     6.001] (II) Loading /usr/lib/xorg/modules/drivers/vmware_drv.so
[     6.068] (II) Module vmware: vendor="X.Org Foundation"
[     6.068] 	compiled for 1.20.0, module version = 13.3.0
[     6.068] 	Module class: X.Org Video Driver
[     6.068] 	ABI class: X.Org Video Driver, version 24.0
[     6.068] (II) LoadModule: "modesetting"
[     6.068] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     6.068] (II) Module modesetting: vendor="X.Org Foundation"
[     6.068] 	compiled for 1.20.4, module version = 1.20.4
[     6.069] 	Module class: X.Org Video Driver
[     6.069] 	ABI class: X.Org Video Driver, version 24.0
[     6.069] (II) LoadModule: "fbdev"
[     6.069] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[     6.069] (II) Module fbdev: vendor="X.Org Foundation"
[     6.069] 	compiled for 1.20.0, module version = 0.5.0
[     6.069] (II) LoadModule: "vesa"
[     6.069] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[     6.069] (II) Module vesa: vendor="X.Org Foundation"
[     6.069] 	compiled for 1.20.1, module version = 2.4.0
[     6.069] (II) vmware: driver for VMware SVGA: vmware0405, vmware0710
[     6.069] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     6.069] (II) FBDEV: driver for framebuffer: fbdev
[     6.069] (II) VESA: driver for VESA chipsets: vesa
[     6.071] (WW) Falling back to old probe method for modesetting
[     6.071] (WW) Falling back to old probe method for fbdev
[     6.071] (II) Loading sub module "fbdevhw"
[     6.071] (II) LoadModule: "fbdevhw"
[     6.071] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[     6.072] (II) Module fbdevhw: vendor="X.Org Foundation"
[     6.072] 	compiled for 1.20.4, module version = 0.0.2
[     6.072] 	ABI class: X.Org Video Driver, version 24.0
[     6.072] (II) vmware(0): Creating default Display subsection in Screen section
[     6.072] (--) vmware(0): DRM driver version is 2.18.0
[     6.072] (==) vmware(0): Depth 24, (--) framebuffer bpp 32
[     6.072] (==) vmware(0): RGB weight 888
[     6.072] (==) vmware(0): Default visual is TrueColor
[     6.072] (--) vmware(0): Min width 1, Max Width 8192.
[     6.072] (--) vmware(0): Min height 1, Max Height 8192.
[     6.072] (II) vmware(0): Output Virtual1 has no monitor section
[     6.072] (II) vmware(0): Output Virtual2 has no monitor section
[     6.072] (II) vmware(0): Output Virtual3 has no monitor section
[     6.072] (II) vmware(0): Output Virtual4 has no monitor section
[     6.072] (II) vmware(0): Output Virtual5 has no monitor section
[     6.072] (II) vmware(0): Output Virtual6 has no monitor section
[     6.072] (II) vmware(0): Output Virtual7 has no monitor section
[     6.072] (II) vmware(0): Output Virtual8 has no monitor section
[     6.072] (II) vmware(0): Printing probed modes for output Virtual1
[     6.072] (II) vmware(0): Modeline "800x600"x60.0   42.75  800 850 900 950  600 650 700 750 -hsync +vsync (45.0 kHz eP)
[     6.073] (II) vmware(0): Modeline "2560x1600"x60.0  348.50  2560 2752 3032 3504  1600 1603 1609 1658 -hsync +vsync (99.5 kHz e)
[     6.073] (II) vmware(0): Modeline "1920x1440"x60.0  234.00  1920 2048 2256 2600  1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[     6.073] (II) vmware(0): Modeline "1856x1392"x60.0  218.25  1856 1952 2176 2528  1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[     6.073] (II) vmware(0): Modeline "1792x1344"x60.0  204.75  1792 1920 2120 2448  1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[     6.073] (II) vmware(0): Modeline "1920x1200"x59.9  193.25  1920 2056 2256 2592  1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[     6.073] (II) vmware(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[     6.073] (II) vmware(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[     6.073] (II) vmware(0): Modeline "1400x1050"x60.0  121.75  1400 1488 1632 1864  1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[     6.073] (II) vmware(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[     6.073] (II) vmware(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz e)
[     6.073] (II) vmware(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[     6.073] (II) vmware(0): Modeline "1360x768"x60.0   85.50  1360 1424 1536 1792  768 771 777 795 +hsync +vsync (47.7 kHz e)
[     6.073] (II) vmware(0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 +hsync -vsync (49.7 kHz e)
[     6.073] (II) vmware(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[     6.073] (II) vmware(0): Modeline "1280x768"x59.9   79.50  1280 1344 1472 1664  768 771 778 798 -hsync +vsync (47.8 kHz e)
[     6.073] (II) vmware(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[     6.073] (II) vmware(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[     6.073] (II) vmware(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 489 492 525 -hsync -vsync (31.5 kHz e)
[     6.073] (II) vmware(0): EDID for output Virtual2
[     6.073] (II) vmware(0): EDID for output Virtual3
[     6.073] (II) vmware(0): EDID for output Virtual4
[     6.073] (II) vmware(0): EDID for output Virtual5
[     6.073] (II) vmware(0): EDID for output Virtual6
[     6.073] (II) vmware(0): EDID for output Virtual7
[     6.073] (II) vmware(0): EDID for output Virtual8
[     6.073] (II) vmware(0): Output Virtual1 connected
[     6.073] (II) vmware(0): Output Virtual2 disconnected
[     6.073] (II) vmware(0): Output Virtual3 disconnected
[     6.073] (II) vmware(0): Output Virtual4 disconnected
[     6.073] (II) vmware(0): Output Virtual5 disconnected
[     6.073] (II) vmware(0): Output Virtual6 disconnected
[     6.073] (II) vmware(0): Output Virtual7 disconnected
[     6.073] (II) vmware(0): Output Virtual8 disconnected
[     6.073] (II) vmware(0): Using exact sizes for initial modes
[     6.073] (II) vmware(0): Output Virtual1 using initial mode 800x600 +0+0
[     6.073] (==) vmware(0): DPI set to (96, 96)
[     6.073] (==) vmware(0): Using gamma correction (1.0, 1.0, 1.0)
[     6.073] (II) Loading sub module "fb"
[     6.073] (II) LoadModule: "fb"
[     6.073] (II) Loading /usr/lib/xorg/modules/libfb.so
[     6.074] (II) Module fb: vendor="X.Org Foundation"
[     6.074] 	compiled for 1.20.4, module version = 1.0.0
[     6.074] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     6.074] (II) Loading sub module "dri2"
[     6.074] (II) LoadModule: "dri2"
[     6.074] (II) Module "dri2" already built-in
[     6.074] (II) Loading sub module "dri3"
[     6.074] (II) LoadModule: "dri3"
[     6.074] (II) Module "dri3" already built-in
[     6.074] (II) UnloadModule: "modesetting"
[     6.074] (II) Unloading modesetting
[     6.074] (II) UnloadModule: "fbdev"
[     6.074] (II) Unloading fbdev
[     6.074] (II) UnloadSubModule: "fbdevhw"
[     6.074] (II) Unloading fbdevhw
[     6.074] (II) UnloadModule: "vesa"
[     6.074] (II) Unloading vesa
[     6.074] (II) vmware(0): Initialized VMWARE_CTRL extension version 0.2
[     6.094] (II) vmware(0): Gallium3D XA version: 2.4.0.
[     6.094] (II) vmware(0): Path of drm device is "/dev/dri/card0".
[     6.094] (II) vmware(0): [DRI2] Setup complete
[     6.094] (II) vmware(0): [DRI2]   DRI driver: vmwgfx
[     6.094] (EE) vmware(0): Failed to initialize direct rendering DRI3.
[     6.094] (--) vmware(0): Render acceleration is enabled.
[     6.094] (==) vmware(0): Rendercheck mode is disabled.
[     6.094] (--) vmware(0): Direct rendering (DRI2 3D) is enabled.
[     6.094] (--) vmware(0): Direct rendering (DRI3 3D) is disabled.
[     6.094] (==) vmware(0): Direct presents are disabled.
[     6.094] (==) vmware(0): Hardware only presents are disabled.
[     6.094] (==) vmware(0): Backing store enabled
[     6.094] (==) vmware(0): Silken mouse enabled
[     6.095] (==) vmware(0): DPMS enabled
[     6.095] (II) Initializing extension Generic Event Extension
[     6.095] (II) Initializing extension SHAPE
[     6.095] (II) Initializing extension MIT-SHM
[     6.095] (II) Initializing extension XInputExtension
[     6.096] (II) Initializing extension XTEST
[     6.096] (II) Initializing extension BIG-REQUESTS
[     6.096] (II) Initializing extension SYNC
[     6.096] (II) Initializing extension XKEYBOARD
[     6.096] (II) Initializing extension XC-MISC
[     6.097] (II) Initializing extension SECURITY
[     6.097] (II) Initializing extension XFIXES
[     6.097] (II) Initializing extension RENDER
[     6.097] (II) Initializing extension RANDR
[     6.097] (II) Initializing extension COMPOSITE
[     6.097] (II) Initializing extension DAMAGE
[     6.097] (II) Initializing extension MIT-SCREEN-SAVER
[     6.097] (II) Initializing extension DOUBLE-BUFFER
[     6.097] (II) Initializing extension RECORD
[     6.098] (II) Initializing extension DPMS
[     6.098] (II) Initializing extension Present
[     6.098] (II) Initializing extension DRI3
[     6.098] (II) Initializing extension X-Resource
[     6.098] (II) Initializing extension XVideo
[     6.098] (II) Initializing extension XVideo-MotionCompensation
[     6.098] (II) Initializing extension SELinux
[     6.098] (II) SELinux: Disabled on system
[     6.098] (II) Initializing extension GLX
[     6.115] (II) AIGLX: Loaded and initialized vmwgfx
[     6.115] (II) GLX: Initialized DRI2 GL provider for screen 0
[     6.115] (II) Initializing extension XFree86-VidModeExtension
[     6.115] (II) Initializing extension XFree86-DGA
[     6.115] (II) Initializing extension XFree86-DRI
[     6.115] (II) Initializing extension DRI2
[     6.118] (II) vmware(0): Setting screen physical size to 211 x 158
[     6.160] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[     6.160] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.160] (II) LoadModule: "libinput"
[     6.160] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     6.164] (II) Module libinput: vendor="X.Org Foundation"
[     6.164] 	compiled for 1.20.4, module version = 0.28.2
[     6.164] 	Module class: X.Org XInput Driver
[     6.164] 	ABI class: X.Org XInput driver, version 24.1
[     6.164] (II) Using input driver 'libinput' for 'Power Button'
[     6.164] (**) Power Button: always reports core events
[     6.164] (**) Option "Device" "/dev/input/event3"
[     6.164] (**) Option "_source" "server/udev"
[     6.169] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     6.169] (II) event3  - Power Button: device is a keyboard
[     6.169] (II) event3  - Power Button: device removed
[     6.251] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input4/event3"
[     6.251] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     6.251] (**) Option "xkb_model" "pc105"
[     6.251] (**) Option "xkb_layout" "de"
[     6.275] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     6.275] (II) event3  - Power Button: device is a keyboard
[     6.275] (II) config/udev: Adding input device Sleep Button (/dev/input/event4)
[     6.275] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     6.275] (II) Using input driver 'libinput' for 'Sleep Button'
[     6.275] (**) Sleep Button: always reports core events
[     6.275] (**) Option "Device" "/dev/input/event4"
[     6.275] (**) Option "_source" "server/udev"
[     6.276] (II) event4  - Sleep Button: is tagged by udev as: Keyboard
[     6.276] (II) event4  - Sleep Button: device is a keyboard
[     6.276] (II) event4  - Sleep Button: device removed
[     6.304] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSLPBN:00/input/input5/event4"
[     6.304] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 7)
[     6.304] (**) Option "xkb_model" "pc105"
[     6.304] (**) Option "xkb_layout" "de"
[     6.305] (II) event4  - Sleep Button: is tagged by udev as: Keyboard
[     6.305] (II) event4  - Sleep Button: device is a keyboard
[     6.305] (II) config/udev: Adding input device Video Bus (/dev/input/event1)
[     6.305] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     6.305] (II) Using input driver 'libinput' for 'Video Bus'
[     6.305] (**) Video Bus: always reports core events
[     6.305] (**) Option "Device" "/dev/input/event1"
[     6.305] (**) Option "_source" "server/udev"
[     6.306] (II) event1  - Video Bus: is tagged by udev as: Keyboard
[     6.306] (II) event1  - Video Bus: device is a keyboard
[     6.306] (II) event1  - Video Bus: device removed
[     6.364] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:00/input/input2/event1"
[     6.364] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[     6.364] (**) Option "xkb_model" "pc105"
[     6.364] (**) Option "xkb_layout" "de"
[     6.365] (II) event1  - Video Bus: is tagged by udev as: Keyboard
[     6.365] (II) event1  - Video Bus: device is a keyboard
[     6.366] (II) config/udev: Adding input device VirtualBox mouse integration (/dev/input/event5)
[     6.366] (**) VirtualBox mouse integration: Applying InputClass "libinput pointer catchall"
[     6.366] (II) Using input driver 'libinput' for 'VirtualBox mouse integration'
[     6.366] (**) VirtualBox mouse integration: always reports core events
[     6.366] (**) Option "Device" "/dev/input/event5"
[     6.366] (**) Option "_source" "server/udev"
[     6.366] (II) event5  - VirtualBox mouse integration: is tagged by udev as: Mouse
[     6.366] (II) event5  - VirtualBox mouse integration: device is a pointer
[     6.366] (II) event5  - VirtualBox mouse integration: device removed
[     6.481] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:04.0/input/input6/event5"
[     6.481] (II) XINPUT: Adding extended input device "VirtualBox mouse integration" (type: MOUSE, id 9)
[     6.481] (**) Option "AccelerationScheme" "none"
[     6.481] (**) VirtualBox mouse integration: (accel) selected scheme none/0
[     6.481] (**) VirtualBox mouse integration: (accel) acceleration factor: 2.000
[     6.481] (**) VirtualBox mouse integration: (accel) acceleration threshold: 4
[     6.482] (II) event5  - VirtualBox mouse integration: is tagged by udev as: Mouse
[     6.482] (II) event5  - VirtualBox mouse integration: device is a pointer
[     6.482] (II) config/udev: Adding input device VirtualBox mouse integration (/dev/input/js0)
[     6.482] (II) No input driver specified, ignoring this device.
[     6.482] (II) This device may have been added with another device file.
[     6.482] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event9)
[     6.483] (II) No input driver specified, ignoring this device.
[     6.483] (II) This device may have been added with another device file.
[     6.483] (II) config/udev: Adding input device HDA Intel Speaker Front (/dev/input/event10)
[     6.483] (II) config/udev: Adding input device HDA Intel Speaker CLFE (/dev/input/event11)
[     6.483] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event12)
[     6.483] (II) config/udev: Adding input device HDA Intel SPDIF In (/dev/input/event13)
[     6.484] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event8)
[     6.484] (II) No input driver specified, ignoring this device.
[     6.484] (II) This device may have been added with another device file.
[     6.484] (II) config/udev: Adding input device VirtualBox USB Tablet (/dev/input/event7)
[     6.484] (**) VirtualBox USB Tablet: Applying InputClass "libinput pointer catchall"
[     6.484] (II) Using input driver 'libinput' for 'VirtualBox USB Tablet'
[     6.484] (**) VirtualBox USB Tablet: always reports core events
[     6.484] (**) Option "Device" "/dev/input/event7"
[     6.484] (**) Option "_source" "server/udev"
[     6.485] (II) event7  - VirtualBox USB Tablet: is tagged by udev as: Mouse
[     6.486] (II) event7  - VirtualBox USB Tablet: device is a pointer
[     6.486] (II) event7  - VirtualBox USB Tablet: device removed
[     6.573] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:06.0/usb1/1-1/1-1:1.0/0003:80EE:0021.0001/input/input8/event7"
[     6.573] (II) XINPUT: Adding extended input device "VirtualBox USB Tablet" (type: MOUSE, id 10)
[     6.573] (**) Option "AccelerationScheme" "none"
[     6.573] (**) VirtualBox USB Tablet: (accel) selected scheme none/0
[     6.573] (**) VirtualBox USB Tablet: (accel) acceleration factor: 2.000
[     6.573] (**) VirtualBox USB Tablet: (accel) acceleration threshold: 4
[     6.574] (II) event7  - VirtualBox USB Tablet: is tagged by udev as: Mouse
[     6.574] (II) event7  - VirtualBox USB Tablet: device is a pointer
[     6.575] (II) config/udev: Adding input device VirtualBox USB Tablet (/dev/input/js1)
[     6.575] (II) No input driver specified, ignoring this device.
[     6.575] (II) This device may have been added with another device file.
[     6.575] (II) config/udev: Adding input device VirtualBox USB Tablet (/dev/input/mouse1)
[     6.575] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[     6.575] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     6.575] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     6.575] (**) AT Translated Set 2 keyboard: always reports core events
[     6.575] (**) Option "Device" "/dev/input/event0"
[     6.575] (**) Option "_source" "server/udev"
[     6.576] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     6.576] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[     6.576] (II) event0  - AT Translated Set 2 keyboard: device removed
[     6.604] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[     6.604] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
[     6.604] (**) Option "xkb_model" "pc105"
[     6.604] (**) Option "xkb_layout" "de"
[     6.605] (II) event0  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     6.605] (II) event0  - AT Translated Set 2 keyboard: device is a keyboard
[     6.605] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/event2)
[     6.606] (**) ImExPS/2 Generic Explorer Mouse: Applying InputClass "libinput pointer catchall"
[     6.606] (II) Using input driver 'libinput' for 'ImExPS/2 Generic Explorer Mouse'
[     6.606] (**) ImExPS/2 Generic Explorer Mouse: always reports core events
[     6.606] (**) Option "Device" "/dev/input/event2"
[     6.606] (**) Option "_source" "server/udev"
[     6.606] (II) event2  - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[     6.606] (II) event2  - ImExPS/2 Generic Explorer Mouse: device is a pointer
[     6.606] (II) event2  - ImExPS/2 Generic Explorer Mouse: device removed
[     6.636] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input3/event2"
[     6.636] (II) XINPUT: Adding extended input device "ImExPS/2 Generic Explorer Mouse" (type: MOUSE, id 12)
[     6.637] (**) Option "AccelerationScheme" "none"
[     6.637] (**) ImExPS/2 Generic Explorer Mouse: (accel) selected scheme none/0
[     6.637] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration factor: 2.000
[     6.637] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration threshold: 4
[     6.637] (II) event2  - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[     6.637] (II) event2  - ImExPS/2 Generic Explorer Mouse: device is a pointer
[     6.638] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/mouse0)
[     6.638] (II) No input driver specified, ignoring this device.
[     6.638] (II) This device may have been added with another device file.
[     6.638] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[     6.638] (II) config/udev: Adding input device BRLTTY 5.6 Linux Screen Driver Keyboard (/dev/input/event14)
[     6.638] (**) BRLTTY 5.6 Linux Screen Driver Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.638] (II) Using input driver 'libinput' for 'BRLTTY 5.6 Linux Screen Driver Keyboard'
[     6.638] (**) BRLTTY 5.6 Linux Screen Driver Keyboard: always reports core events
[     6.638] (**) Option "Device" "/dev/input/event14"
[     6.638] (**) Option "_source" "server/udev"
[     6.639] (II) event14 - BRLTTY 5.6 Linux Screen Driver Keyboard: is tagged by udev as: Keyboard
[     6.639] (II) event14 - BRLTTY 5.6 Linux Screen Driver Keyboard: device is a keyboard
[     6.639] (II) event14 - BRLTTY 5.6 Linux Screen Driver Keyboard: device removed
[     6.668] (**) Option "config_info" "udev:/sys/devices/virtual/input/input15/event14"
[     6.668] (II) XINPUT: Adding extended input device "BRLTTY 5.6 Linux Screen Driver Keyboard" (type: KEYBOARD, id 13)
[     6.668] (**) Option "xkb_model" "pc105"
[     6.668] (**) Option "xkb_layout" "de"
[     6.669] (II) event14 - BRLTTY 5.6 Linux Screen Driver Keyboard: is tagged by udev as: Keyboard
[     6.669] (II) event14 - BRLTTY 5.6 Linux Screen Driver Keyboard: device is a keyboard
[     6.678] (EE) Failed to open authorization file "/var/run/sddm/{ef1bdd82-bcc6-4542-a191-42a6a538ca11}": No such file or directory
[    24.311] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[    25.180] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[    85.749] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[    87.485] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[    89.511] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   107.392] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   277.380] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   279.062] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   318.389] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   320.225] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   346.250] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   451.094] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   797.315] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   797.345] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   797.468] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   797.534] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   799.237] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[   799.237] (II) event5  - VirtualBox mouse integration: WARNING: log rate limit exceeded (5 msgs per 30000ms). Discarding future messages.
[  3415.268] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  3417.142] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  3417.180] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  3527.153] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  3529.147] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  3529.471] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  3531.272] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  3629.784] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  3652.497] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  3654.330] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  4082.251] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  4434.640] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  4434.710] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  4434.737] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  4436.252] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  4436.322] (II) event5  - VirtualBox mouse integration: SYN_DROPPED event - some input events have been lost.
[  4436.322] (II) event5  - VirtualBox mouse integration: WARNING: log rate limit exceeded (5 msgs per 30000ms). Discarding future messages.
the max. reported resolution is still 2560*1600.
Here the whole output with enabled/installed guest-addition.iso
terence@devuan3:~$ lspci -k
00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
00:01.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01)
        Kernel driver in use: ata_piix
        Kernel modules: ata_piix, ata_generic
00:02.0 VGA compatible controller: VMware SVGA II Adapter
        Subsystem: VMware SVGA II Adapter
        Kernel driver in use: vmwgfx
        Kernel modules: vmwgfx
00:03.0 Ethernet controller: Intel Corporation 82540EM Gigabit Ethernet Controller (rev 02)
        Subsystem: Intel Corporation PRO/1000 MT Desktop Adapter
        Kernel driver in use: e1000
        Kernel modules: e1000
00:04.0 System peripheral: InnoTek Systemberatung GmbH VirtualBox Guest Service
        Kernel driver in use: vboxguest
        Kernel modules: vboxguest
00:05.0 Audio device: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller (rev 01)
        Subsystem: SigmaTel 82801FB/FBM/FR/FW/FRW (ICH6 Family) High Definition Audio Controller
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
00:06.0 USB controller: Apple Inc. KeyLargo/Intrepid USB
        Kernel driver in use: ohci-pci
        Kernel modules: ohci_pci
00:07.0 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 08)
        Kernel driver in use: piix4_smbus
        Kernel modules: i2c_piix4
00:0d.0 SATA controller: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) SATA Controller [AHCI mode] (rev 02)
        Kernel driver in use: ahci
        Kernel modules: ahci
terence@devuan3:~$ uname -r
5.7.0-0.bpo.2-amd64
That's a good explanation, thanks! First I would state to use KVM like in the trhead for getting 'spice' and I have some questions:
Following your linked thread by 'shared-folder' is this command qemu_mount /shared 9p rw,sync,dirsync,access=client,trans=virtio,x-systemd.automount 0 0 but I have 'openrc' installed on the client.
How to modify the /etc/fstab accordignly?
Thanks for commit the command and OK for MX I was not sure.
I search since months now with very poor results on knowledge, each distro has own scheme, can you recommend some link-s? the qemu-link is very good (only one open question from my side).
I'm sure, by the way... Gentoo latest stable has 'systemd' too. Who will take care now about 'openrc'?
Thanks again for your patience.
#15 2020-09-07 16:54:23
larsH
Hi
Just looking into gentoo-handbook. ATM they are still using open-rc as init manager. But they do have systemd stage 3 for those who prefer or need that (for gnome among other things).
Have a nice day
Lars H
#16 2020-09-07 18:45:32
No, the performance in a VM has absolutely no bearing at all on the support for your hardware. Look at your posted lspci output — do you see any of your hardware listed there?
The posted X.Org logs are of no use in respect of determining the problems with hardware support, we need to see the X.Org log from a bare metal installation.
Remove ,x-systemd.automount.
https://wiki.archlinux.org/index.php/Xo … r_settings
