#1 2018-07-19 18:26:42
malinas
[SOLVED] Upgrade from Jessie to Ascii: apt thinks I'm using "testing"
I (not quite) recently upgraded my system, but it looks like apt is still confused about my base system:
# apt search linux-image-amd64
Sorting... Done
Full Text Search... Done
linux-image-amd64/testing,now 4.9+80+deb9u5 amd64 [installed]
  Linux for 64-bit PCs (meta-package)
Here it indicates /testing instead of /stable or even better, /ascii. I am under the impression that the version should come from /etc/os-release but there is no such field in mine:
# cat /etc/os-release
PRETTY_NAME="Devuan GNU/Linux ascii"
NAME="Devuan GNU/Linux"
ID=devuan
ID_LIKE=debian
HOME_URL="https://www.devuan.org/"
SUPPORT_URL="https://devuan.org/os/community"
BUG_REPORT_URL="https://bugs.devuan.org/"
What is going on here?
#2 2018-07-19 19:42:17
Re: [SOLVED] Upgrade from Jessie to Ascii: apt thinks I'm using "testing"
I am running a fresh installed ASCII with backports kernel 4.16 installed. What is your sources.list looking alike? Mine is clearly pointing to ascii. I get:
root@xxx:/# uname -a
Linux xxx 4.16.0-0.bpo.2-amd64 #1 SMP Debian 4.16.16-2~bpo9+1 (2018-06-26) x86_64 GNU/Linux
root@xxx:/# apt search linux-image-amd64
Sortierung... Fertig
Volltextsuche... Fertig
linux-image-amd64/stable,stable-security,now 4.9+80+deb9u4 amd64  [installiert]
linux-image-amd64-dbg/stable,stable-security 4.9+80+deb9u4 amd64
  Debugging symbols for Linux amd64 configuration (meta-package)
root@xxx:/# cat /etc/os-release
ID=devuan
ID_LIKE=debian
Regards, rolfie
#3 2018-07-30 06:29:57
malinas
These are my files:
# cat /etc/apt/sources.list
deb http://sg.mirror.devuan.org/merged/ ascii main contrib non-free
deb http://sg.mirror.devuan.org/merged/ ascii-security main contrib non-free
deb http://sg.mirror.devuan.org/merged/ ascii-updates main contrib non-free
# cat /etc/apt/sources.list.d/backports.list
deb http://sg.mirror.devuan.org/merged/ ascii-backports main contrib non-free
# cat /etc/apt/sources.list.d/virtualbox.list
deb http://download.virtualbox.org/virtualbox/debian stretch contrib non-free
If I use apt-cache instead:
# apt-cache policy linux-image-amd64
linux-image-amd64:
  Installed: 4.9+80+deb9u5
  Candidate: 4.9+80+deb9u5
  Version table:
     4.16+94~bpo9+1 100
        100 http://sg.mirror.devuan.org/merged ascii-backports/main amd64 Packages
 *** 4.9+80+deb9u5 500
        500 http://sg.mirror.devuan.org/merged ascii/main amd64 Packages
        100 /var/lib/dpkg/status
     4.9+80+deb9u4 500
        500 http://sg.mirror.devuan.org/merged ascii-security/main amd64 Packages
So the information about what are stable and testing must come from somewhere else?
#4 2018-07-31 14:45:38
There are new mirrors you should use. Change sg.mirror.devuan.org to deb.devuan.org (or maybe sg.deb.devuan.org) in sources.list, then update.
#5 2018-08-12 22:33:40
malinas
That fixed the problem! And it sort of answers the question of where the information comes from: the repository itself. Thanks!
