#1 2018-07-18 16:47:16
keos
How to downgrade to wheezy?
Hi, i have many new problems everyday with Devuan ascii ... is it possible to downgrade from ascii to wheezy or wherever ... ? Thanks!
devuan_ascii_2.0.0-rc_amd64_desktop-live.iso  [Xfce]
Graphics: AMD Radeon HD 7640G integrated graphics
GPU: AMD/ATI Trinity [Radeon HD 7640G]
#2 2018-07-18 20:57:08
ChuangTzu
Re: How to downgrade to wheezy?
Wheezy is EOL, so I would not recommend that.  Regarding downgrading an OS, it's called reinstall.
#3 2018-07-19 12:25:58
keos
if i understand what you are advising me, reinstall the system, well ... i think that i will get the same at the end that i have now, you maybe want to say uninstall Devuan. -- i will continue for a while to see ...
Thanks.
#4 2018-07-19 15:34:44
ivanovnegro
It would be more interesting to know which kind of problems because Ascii runs just fine here.
