#1 2018-07-08 04:31:57
PPromet
DEs on testing/unstable
I tried to install KDE/LXqt on Beowulf and Ceres but to no avail.
Every time apt holds a lot of dependencies to prevent a successful installation.
I guess this is due to Devuan's settings to exclude systemd from being installed.
I didn't try to install GNOME, which is supposed to rely on systemd since I am afraid it's a waste of time given the above situation.
So is there any workaround on this, or do I have to wait until Beowulf becomes more stable and supports the installation of the above DEs?
#2 2018-07-08 14:58:22
scutterflux
Re: DEs on testing/unstable
Did you try a
apt dist-upgrade
after, it might help resolve the held dependencies.
Also you can try using aptitude, it can give better control with the software dependencies.
