#1 2018-06-29 08:45:56
minghia
Problem reboot 3B+
I just got my new 3B+ today and it is having trouble rebooting. When I reboot it, it just hangs with no lights on. I saw a post on a Raspberry Pi site that indicated that there might be problems with the LAN driver. Is there a later LAN driver than doesn't have this problem? Of course the problems may be with my power supply but I don't think the system would cold boot if that was the case.
Does anyone have suggestions?
#2 2018-07-09 15:27:41
fanderal
Re: Problem reboot 3B+
Just got mine two weeks ago, also a 3B+. The 'no boot' has happened twice for me... once when I didn't seat the micro SD properly, and the other time I needed to re-flash the img file to the micro SD with Etcher to get it to boot. If that hadn't worked I'd have downloaded another img file and tried again.
#3 2018-07-10 11:53:51
minghia
I think you misunderstood my problem. Booting the device is not the problem as I am booting over the network. The non-booting happens when I reboot the 3B+ and it shuts down okay but all the lights go off and nothing happens until I power cycle the 3B+.
#4 2018-07-10 23:26:52
fanderal
Yes, I did misunderstand what you were after. If I had an answer I'd post it, but I don't. Good luck.
