Hello,
I would like to install KDE without too many packages. There is apt-get install kde-full.
Which installation procedure will help to install kde (just minimal packages)?
Looking forward to hearing you.
Best regards
There are several metapackages for installing kde. Some pull in more packages than others. To see what you would get with each, run apt-cache depends kde-full and do the same for
kde-plasma-desktop
plasma-desktop
kde-standard
task-kde-desktop
kde-baseapps
For a very basic Plasma desktop, install...
plasma-desktop...that doesn't install any of the normal Plasma related items; such as, Dolphin, Konqueror, Kwrite, etc... but it gives you the Plasma desktop. If you want to add Plasma related items, you'll have to install them separately.
Here's a link to where I built a very minimal Plasma. Keep in mind, this was done SEVERAL months ago...
Veni, vidi, vici vdevuaned. I came, I saw, I Devuaned. ![]()
kde-standard is a good middle install that includes most of what you would expect in KDE.
I personally prefer a KDE minimal install and installed kde-plasma-desktop and then installed what ever else I desired after that. If you decide to go this route I can post what I installed.
Something to be aware of is last I heard SDDM has problems, and its recommended to install and use LIGHTDM. You may also have the infamous polkit problem so you will need to apt-get install libpolkit-backend-elogind-1-0 to fix that.
I am very happy with KDE and devuan, experienced no problems. Basically I used:
apt-get install lightdm
apt-get install kde-plasma-desktop
encountered polkit problem
then my additional desired applicationsOffline
