#1 2018-06-16 11:02:29
spartrekus
How to record FIFA World Cup video/audio ?
Hello,
I have installed DEVUAN ASCII, then I did plug an USB audio/video. I did plug all video/audio cables to the usb pc video device.
(device logilink vg0001A)
It works flawlessly to view only with:
 mplayer tv:// -tv driver=v4l2:device=/dev/video1
Next step, I would like to record video/audio with LINUX DEVUAN. However, I noticed that those aren't available the following into the repositories:
ffmpeg, avconv and mencoder aren't in the source list.
What to do under DEVUAN to record video+audio?
I am looking forward to reading you. The fifa wold cup already began!!  SPAIN WILL WIN THIS YEAR, I would bet !!
My desktop is blackbox with alsa for the sound. Just simple desktop.
This thread will probably help many of you, for something next to DEVUAN : Soccer wink
#2 2018-06-16 12:38:19
Panopticon
Re: How to record FIFA World Cup video/audio ?
I think you may be looking for "libavcodec-dev".
Do an apt search for lib ffmpeg $ apt search lib ffmpeg and see if that helps.
Same with the rest of your list, avconv and mencoder.
Sorry if this is not much help but im just giving you some options to search for and research.
#3 2018-06-16 14:49:14
devuser
ffmpeg and libav-tools (avconv) seem to be available on ascii? https://trac.ffmpeg.org/wiki/Capture/Webcam has a guide on how to record from v4l2 or did you already try that and there is some problem? Sorry, can't try it as i don't have any video device available.
