#1 2018-06-09 21:45:49
dxrobertson
/usr/bin/x11 symlink to /usr/bin/X11?
Is there a reason for this symlink, that points to itself?  Seems odd to me, an easy way for code to get stuck in a recursive infinite loop.
dxrobertson@dxr-acer:/usr/bin$ ls -l -a | grep X11
lrwxrwxrwx  1 root root           1 May  3  2017 X11 -> .
dxrobertson@dxr-acer:/usr/bin$ cd X11
dxrobertson@dxr-acer:/usr/bin/X11$ cd X11
dxrobertson@dxr-acer:/usr/bin/X11/X11$ cd X11
dxrobertson@dxr-acer:/usr/bin/X11/X11/X11$
I noticed it doing a search in files using kde kate.  It became stuck in a recursive search inside /usr/bin/X11.  Seems kate is programmed to handle such a situation because it eventually quit and left that directory search and continued on.
#2 2018-06-10 11:03:43
Re: /usr/bin/x11 symlink to /usr/bin/X11?
I don't know the answer, but I've seen similar recursive symlinks in various locations and various distributions over the years.
#3 2018-06-10 22:06:27
emanym
I'm guessing X11-related binaries where in a /usr/bin/X11 or /usr/bin/X11R6 directory originally? Any old script or program might still expect to find something there...
According to my x11-common changelog:
xorg (6.8.2-34) breezy; urgency=low
 * Move Xorg symlink from /usr/bin/X11 to /usr/bin, as the former is becoming
    a symlink to the latter with the new x-common.  Ditto X symlink.
 -- Daniel Stone <daniel.stone@ubuntu.com>  Mon, 27 Jun 2005 19:10:24 +1000
Took me a while to find that one too, there are many symlinks mentioned in those changelogs ;-)
#4 2018-06-11 11:36:09
dxrobertson
Now I see.  I can use /usr/bin/X11/xvinfo, for example.  Yes, seems there once was an actual /usr/bin/X11 directory.  Just dont try to navigate into it.
I never noticed a link pointing in this particular configuration before, makes perfect sense now.
