#1 2018-05-19 03:38:58
0xf4b10
Install kali linux tools on devuan?
Is there a simple way to do it? I guess if I just add it to source.list would certainly break my system. I also knew a script called katoolin but it also doesn't work. Any tips on this subject?
#2 2018-05-19 04:00:56
siva
Re: Install kali linux tools on devuan?
You'll need a list of the kali tools you want first.  If they're available, install them; if not, compile them.
Apparently, you can even install them on arm: https://github.com/Bhai4You/Kali-Linux.  What fun!
the thomos project
thomos support thread
cynwulf wrote: "You should get some more sleep and spend less time on forums."
#3 2018-05-19 07:52:50
Panopticon
Have you seen the sizes of the meta packages for kali, massive....
https://www.kali.org/news/kali-linux-metapackages/
I would think a great deal of those tools would be reliant on systemd.
