#1 2018-05-10 18:46:00
kc0dxf
FIPS ssh?
Is it possible to make openssh on Devuan FIPS compliant?
#2 2018-05-11 00:27:30
Re: FIPS ssh?
Isn't that just a matter of choosing which encryption algorithm(s) your server accepts? I.e., it's your choice, and a property of your running server; not a property of the software as such. And based on a rather superficial web search, I believe that the answer is "Yes": there is a sufficient number of algorithms to use to make your ssh service compliant.
