#1 2018-05-03 10:22:44
Nili
[SOLVED] DSA-4187-1 Security Update
Hello!
Debian released an Security Update for Linux Kernel Image on 01 May 2018
I believe we should taken it sometime later, today is the second day but i still see "0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded." on my console.
Debian said :
For the oldstable distribution (jessie), these problems have been fixed in version 3.16.56-1
While i am still on :
Linux kernel 3.16.0-4-686-pae #1 SMP Debian 3.16.51-3 (2017-12-13) i686 GNU/Linux
This absence has any reason?
This is my sources list
deb http://pkgmaster.devuan.org/merged/ jessie main non-free contrib
deb-src http://pkgmaster.devuan.org/merged/ jessie main non-free contrib
# jessie-security, previously known as 'volatile'
deb http://pkgmaster.devuan.org/merged/ jessie-security main contrib non-free
deb-src http://pkgmaster.devuan.org/merged/ jessie-security main contrib non-free
# jessie-updates, previously known as 'volatile'
deb http://pkgmaster.devuan.org/merged/ jessie-updates main contrib non-free
deb-src http://pkgmaster.devuan.org/merged/ jessie-updates main contrib non-free
# Devuan repositories
deb http://packages.devuan.org/merged jessie main contrib non-free
deb-src http://packages.devuan.org/merged jessie main contrib non-free
Usually i have taken immediately the security updates it never lasted two days.
Thanks for your feedback.
Edited: cleared i686 from title
Nili
OS: Devuan
DM: startx # WM: openbox # Panel: tint2 # SysInfo: conky-std
プロトタイプ: 双葉杏 (Futaba Anzu) THE iDOLM@STER、 山田 たえ (Yamada Tae) Zombieland Saga
Nothing beats peace and quiet - Tomoki Sakurai
#2 2018-05-03 10:31:58
GNUser
Re: [SOLVED] DSA-4187-1 Security Update
Can you please post the output of dpkg -l | perl -lane 'print "$F[1] $F[2]" if /^.i/' | grep linux?
#3 2018-05-03 10:37:24
Nili
Thanks for asking GNUser!
Sure...
console-setup-linux 1.123
libselinux1:i386 2.3-2
linux-base 3.5
linux-image-3.16.0-4-686-pae 3.16.51-3
util-linux 2.26.2-6+devuan1
util-linux-locales 2.25.2-6
OS: Devuan
#4 2018-05-03 10:48:21
GNUser
Automatic kernel upgrades only come in if one has the metapackage installed, which you don't have.
Do this: sudo apt-get install linux-image-686-pae then try upgrading your system again. Now (and going forward) you will get the kernel security upgrades automatically smile
(One more question: Do you use GRUB and have multiple OSs installed? If so and if your primary OS--the first one listed in GRUB--is something other than Jessie, you'll need to manually do sudo update-grub in your primary OS in order for GRUB to be "aware" that Jessie has a new kernel.)
#5 2018-05-03 11:09:47
Nili
Indeed i don't have "linux-image-686-pae" installed. I have installed right, got the update itself. Thanks smile
Yes, i use GRUB, but don't have multiple OS's installed.
I only have plain Jessie Devuan NETINS customized that listen fine on GRUB settings.
I consider solved my request regarding Kernel Security Update. Thanks GNUser for explained and suggested smile
OS: Devuan
