#1 2018-04-23 11:32:05
sacarde
wireless problem on qemu
hi,
   I use same usb-wireless (Atheros AR9271) in 2 virtualized system:
1) debian/sid
2) devuan
I use same configuration:
allow-hotplug wlan0
iface wlan0 inet dhcp
wireless-essid NETGEAR
in debian system, wlan0 get IP address OK
in devuan system I receive error:
ifup wlan0
Internet Systems Consortium DHCP Client 4.3.1
Copyright 2004-2014 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/e0:46:9a:0d:72:0c
Sending on   LPF/wlan0/e0:46:9a:0d:72:0c
Sending on   Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 17
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
in both system eth0 in dhcp works OK
what can I check?
thank you
#2 2018-04-23 13:34:37
wdq
Re: wireless problem on qemu
have you installed wpasupplicant , if yes just add it in your etc/network/interfaces
 auto wlan0
  wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
restart networking
#3 2018-04-23 14:51:06
sacarde
in both systems I dont have wpasupplicant
#4 2018-04-23 15:16:48
wdq
Well let`s try this
apt-get install wpasupplicant
now you need to create a configuration file so
nano /etc/wpa_supplicant/wpa_supplicant.conf
Add the next content in your config file where you have to change network_id and password with your own
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
update_config=1
network={
  ssid="network_id"
  psk="password"
  proto=WPA
  key_mgmt=WPA-PSK
  pairwise=TKIP
  group=TKIP
Now let`s modify the network/interfaces
nano /etc/network/interfaces
and add modify like this
auto wlan0
and give a reboot
Hope this helps !
#5 2018-04-23 15:19:17
sacarde
my network has only essid NETGEAR
no any other key/password
what I have to set this:
  ssid="network_id"
  psk="password"
  proto=WPA
  key_mgmt=WPA-PSK
  pairwise=TKIP
  group=TKIP
#6 2018-04-23 15:24:09
wdq
Well then just modify like this the content of wpa_supplicant.conf
 key_mgmt=NONE
and do not add the
  psk="password"
line .
#7 2018-04-23 15:38:35
sacarde
this is my /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
  ssid="NETGEAR"
  proto=WPA
  key_mgmt=NONE
  pairwise=TKIP
  group=TKIP
but after reboot, same problem:
eth0 have an IP
wlan0 no
#8 2018-04-23 16:25:12
wdq
ok try to change the proto= WPA line to proto=RSN
and ifdown eth0 to see if there is a conflict between eth0 and wlan0
but you shoud try wicd more secure and has a gui .
#9 2018-04-23 18:46:53
sacarde
same problem
p.s.
adding other info
iwlist scan
ens3      Interface doesn't support scanning.
wlan0    Interface doesn't support scanning : Device or resource busy
lo           Interface doesn't support scanning.
#10 2018-04-29 07:40:07
sacarde
other info from dmesg:
[  106.224185] usb 1-1: new full-speed USB device number 2 using uhci_hcd
[  106.645996] usb 1-1: config 1 interface 0 altsetting 0 endpoint 0x1 has invalid maxpacket 512, setting to 64
[  106.646006] usb 1-1: config 1 interface 0 altsetting 0 endpoint 0x82 has invalid maxpacket 512, setting to 64
[  106.646009] usb 1-1: config 1 interface 0 altsetting 0 endpoint 0x5 has invalid maxpacket 512, setting to 64
[  106.646012] usb 1-1: config 1 interface 0 altsetting 0 endpoint 0x6 has invalid maxpacket 512, setting to 64
[  106.659511] usb 1-1: New USB device found, idVendor=0846, idProduct=9030
[  106.659524] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[  106.659530] usb 1-1: Product: WNA1100
[  106.659534] usb 1-1: Manufacturer: NETGEAR WNA
[  106.659538] usb 1-1: SerialNumber: 12345
[  106.715384] usb 1-1: ath9k_htc: Firmware htc_9271.fw requested
[  106.716669] usb 1-1: firmware: direct-loading firmware htc_9271.fw
[  106.717127] usbcore: registered new interface driver ath9k_htc
[  107.060489] usb 1-1: ath9k_htc: Transferred FW: htc_9271.fw, size: 50980
[  107.323928] ath9k_htc 1-1:1.0: ath9k_htc: HTC initialized with 33 credits
#11 2018-04-30 01:53:18
Have you tried with rfkill (tool for enabling and disabling wireless devices)? As in a "googled" example:
# modprobe -rf ath9k ath9k_htc
# rfkill unblock all
# modprobe ath9k ath9k_htc
I'm not sure what's the difference from Debian though. It would depend on versions, since the code for bringing up interfaces has had some development recently (last few years). Not long ago, it had a bug where the script could query the interface state too early after power-on. The patch against that problem was to add a sleep into the script between starting the interface and checking its state.
You could also try to use the "auto" method rather than "allow-hotplug", to let the networking init script raise the interface instead of (e)udev.
#12 2018-04-30 09:51:49
sacarde
- rfkill are not blocked
- auto or allow-hotplug same problem
- is OK that I view nothing running:
dmesg|grep wlan
#13 2018-04-30 10:55:45
As the dongle behaves in your Debian and mis-behaves in your Devuan, there must be some difference in the code involved, obviously. The start point for tracking that down would be in the versions: of the kernels, of the ath modules and firmwares, of the hotplug handlers, etc. Perhaps you can make a table. Then it would be possible to experiment by aligning versions where possible, and by inspecting the differences more exactly otherwise.
btw, there is also the iw tool (from wireless-tools) for
# iw dev wlan0 scan
Rumours has it that sometimes that works where iwlist fails.
#14 2018-04-30 11:43:27
sacarde
# iw dev wlan0 scan
same error
- what can I view about:
p.s.
I virtualized:
kubuntu16.04 works OK
kubuntu18.04 dont works
ubuntu14.04 works OK
