#1 2018-04-19 09:35:02
penguinwrangler
Latest update for libpolkit-backend-1-0 tries to uninstall KDE
Upgraded yesterday, all fine.  New upgrades are available today so I'm trying to install them onto my desktop machine which is running KDE.
$ sudo apt upgrade
Building dependency tree
Calculating upgrade... Done
 libpolkit-backend-1-0-elogind : Conflicts: libpolkit-backend-1-0
 libpolkit-gobject-1-0-elogind : Conflicts: libpolkit-gobject-1-0
E: Broken packages
I've checked and libpolkit-backend-1-0 and libpolkit-gobject-1-0 are not installed...
$ dpkg -l | grep libpolkit
ii  libpolkit-agent-1-0:amd64                         0.105-18+devuan2.4                          amd64        PolicyKit Authentication Agent API
ii  libpolkit-backend-1-0-elogind:amd64               0.105-18+devuan2.4                          amd64        PolicyKit backend API
ii  libpolkit-gobject-1-0-elogind:amd64               0.105-18+devuan2.4                          amd64        PolicyKit Authorization API
ii  libpolkit-qt-1-1:amd64                            0.112.0-5                                   amd64        PolicyKit-qt-1 library
ii  libpolkit-qt5-1-1:amd64
If I try to install 'libpolkit-backend-1-0' to replace -elogind specific variant, it tries to uninstall KDE!
$ sudo apt install libpolkit-backend-1-0
  libpolkit-agent-1-0 libpolkit-backend-consolekit-1-0 libpolkit-gobject-1-0 libpolkit-gobject-consolekit-1-0 policykit-1
  apper kde-plasma-desktop kde-standard libpolkit-backend-1-0-elogind libpolkit-gobject-1-0-elogind network-manager plasma-desktop plasma-nm polkit-kde-1 polkit-kde-agent-1 task-kde-desktop
  libpolkit-backend-1-0 libpolkit-backend-consolekit-1-0 libpolkit-gobject-1-0 libpolkit-gobject-consolekit-1-0
  libpolkit-agent-1-0 policykit-1
2 upgraded, 4 newly installed, 11 to remove and 5 not upgraded.
Need to get 186 kB of archives.
After this operation, 28.1 MB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
The only non-Devuan packages that I have installed are Google Chrome from Google and nodejs from the NodeJS repo.
So... something is twisted up somewhere but I've absolutely no idea where.  Anyone have a clue what I've managed to tie in a knot and how to untangle it?
Thanks in advance... ;-)
#2 2018-04-19 13:18:47
penguinwrangler
Re: Latest update for libpolkit-backend-1-0 tries to uninstall KDE
[FIXED]
So, some more digging and testing... and it seems the culprit is libpolkit-backend-1-0-elogind.  This package has been renamed to libpolkit-backend-elogind-1-0 and that seems to get everything upset.
The solution is to explicitly upgrade to libpolkit-backend-elogind-1-0 and that sorts everything out.
$ sudo apt install --upgrade libpolkit-backend-elogind-1-0
  libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 libpolkit-gobject-elogind-1-0 policykit-1
  consolekit libpam-ck-connector libpolkit-backend-1-0-elogind libpolkit-gobject-1-0-elogind slim
  libpolkit-backend-1-0 libpolkit-backend-elogind-1-0 libpolkit-gobject-1-0 libpolkit-gobject-elogind-1-0
2 upgraded, 4 newly installed, 5 to remove and 5 not upgraded.
After this operation, 1,092 kB disk space will be freed.
Get:1 http://gb.mirror.devuan.org/merged ascii/main amd64 policykit-1 amd64 0.105-18+devuan2.9 [60.3 kB]
Get:2 http://gb.mirror.devuan.org/merged ascii/main amd64 libpolkit-agent-1-0 amd64 0.105-18+devuan2.9 [22.6 kB]
Get:3 http://gb.mirror.devuan.org/merged ascii/main amd64 libpolkit-gobject-1-0 all 0.105-18+devuan2.9 [10.1 kB]
Get:4 http://gb.mirror.devuan.org/merged ascii/main amd64 libpolkit-gobject-elogind-1-0 amd64 0.105-18+devuan2.9 [40.0 kB]
Get:5 http://gb.mirror.devuan.org/merged ascii/main amd64 libpolkit-backend-elogind-1-0 amd64 0.105-18+devuan2.9 [42.4 kB]
Get:6 http://gb.mirror.devuan.org/merged ascii/main amd64 libpolkit-backend-1-0 all 0.105-18+devuan2.9 [10.2 kB]
Fetched 186 kB in 0s (439 kB/s)
Reading changelogs... Done
(Reading database ... 246540 files and directories currently installed.)
Removing slim (1.3.6-5.1+devuan2) ...
update-alternatives: warning: alternative /usr/share/slim/themes/default (part of link group desktop-slim-theme) doesn't exist; removing from list of alternatives
Removing consolekit (0.4.6-6) ...
Removing libpam-ck-connector:amd64 (0.4.6-6) ...
(Reading database ... 246472 files and directories currently installed.)
Preparing to unpack .../policykit-1_0.105-18+devuan2.9_amd64.deb ...
Unpacking policykit-1 (0.105-18+devuan2.9) over (0.105-18+devuan2.4) ...
Preparing to unpack .../libpolkit-agent-1-0_0.105-18+devuan2.9_amd64.deb ...
Unpacking libpolkit-agent-1-0:amd64 (0.105-18+devuan2.9) over (0.105-18+devuan2.4) ...
dpkg: libpolkit-backend-1-0-elogind:amd64: dependency problems, but removing anyway as you requested:
 policykit-1 depends on libpolkit-backend-1-0 (= 0.105-18+devuan2.9); however:
  Package libpolkit-backend-1-0 is not installed.
  Package libpolkit-backend-1-0-elogind:amd64 which provides libpolkit-backend-1-0 is to be removed.
(Reading database ... 246471 files and directories currently installed.)
Removing libpolkit-backend-1-0-elogind:amd64 (0.105-18+devuan2.4) ...
dpkg: libpolkit-gobject-1-0-elogind:amd64: dependency problems, but removing anyway as you requested:
 packagekit depends on libpolkit-gobject-1-0 (>= 0.99); however:
  Package libpolkit-gobject-1-0 is not installed.
  Package libpolkit-gobject-1-0-elogind:amd64 which provides libpolkit-gobject-1-0 is to be removed.
 accountsservice depends on libpolkit-gobject-1-0 (>= 0.99); however:
 libpolkit-qt-1-1:amd64 depends on libpolkit-gobject-1-0 (>= 0.101); however:
 colord depends on libpolkit-gobject-1-0 (>= 0.99); however:
 cups-pk-helper depends on libpolkit-gobject-1-0 (>= 0.99); however:
 network-manager depends on libpolkit-gobject-1-0 (>= 0.104); however:
 upower depends on libpolkit-gobject-1-0 (>= 0.99); however:
 udisks2 depends on libpolkit-gobject-1-0 (>= 0.101); however:
 xfce4-session depends on libpolkit-gobject-1-0 (>= 0.101); however:
 policykit-1 depends on libpolkit-gobject-1-0 (= 0.105-18+devuan2.9); however:
 modemmanager depends on libpolkit-gobject-1-0 (>= 0.99); however:
 libpolkit-agent-1-0:amd64 depends on libpolkit-gobject-1-0 (= 0.105-18+devuan2.9); however:
 libpolkit-qt5-1-1:amd64 depends on libpolkit-gobject-1-0 (>= 0.101); however:
 xbrlapi depends on libpolkit-gobject-1-0 (>= 0.94); however:
Removing libpolkit-gobject-1-0-elogind:amd64 (0.105-18+devuan2.4) ...
Selecting previously unselected package libpolkit-gobject-1-0.
(Reading database ... 246462 files and directories currently installed.)
Preparing to unpack .../libpolkit-gobject-1-0_0.105-18+devuan2.9_all.deb ...
Unpacking libpolkit-gobject-1-0 (0.105-18+devuan2.9) ...
Selecting previously unselected package libpolkit-gobject-elogind-1-0:amd64.
Preparing to unpack .../libpolkit-gobject-elogind-1-0_0.105-18+devuan2.9_amd64.deb ...
Unpacking libpolkit-gobject-elogind-1-0:amd64 (0.105-18+devuan2.9) ...
Selecting previously unselected package libpolkit-backend-elogind-1-0:amd64.
Preparing to unpack .../libpolkit-backend-elogind-1-0_0.105-18+devuan2.9_amd64.deb ...
Unpacking libpolkit-backend-elogind-1-0:amd64 (0.105-18+devuan2.9) ...
Selecting previously unselected package libpolkit-backend-1-0.
Preparing to unpack .../libpolkit-backend-1-0_0.105-18+devuan2.9_all.deb ...
Unpacking libpolkit-backend-1-0 (0.105-18+devuan2.9) ...
Setting up libpolkit-gobject-elogind-1-0:amd64 (0.105-18+devuan2.9) ...
Processing triggers for libc-bin (2.24-11+deb9u3) ...
Processing triggers for man-db (2.7.6.1-2) ...
Processing triggers for dbus (1.10.22-1+devuan1) ...
Setting up libpolkit-gobject-1-0 (0.105-18+devuan2.9) ...
Setting up libpolkit-agent-1-0:amd64 (0.105-18+devuan2.9) ...
Setting up libpolkit-backend-elogind-1-0:amd64 (0.105-18+devuan2.9) ...
Setting up libpolkit-backend-1-0 (0.105-18+devuan2.9) ...
Setting up policykit-1 (0.105-18+devuan2.9) ...
Hope this helps someone else out of the spot!
