#1 2018-04-18 16:03:05
Geoff 42
[Solved?] Upgrade to remove LXDE
I am running Ascii and have just tried
apt-get update
apt-get dist-upgrade
and it tells me
  consolekit lxde lxde-core lxsession lxsession-logout openbox-lxde-session slim
I have declined this kind offer and have not yet had a chance to work out why it wants to remove LXDE.
Geoff
#2 2018-04-18 19:41:23
Geoff 42
Re: [Solved?] Upgrade to remove LXDE
My laptop has a different history but is currently also on Ascii with LXDE. On this machine dist-upgrade produces :-
# apt-get dist-upgrade
Building dependency tree
Calculating upgrade... Done
  docbook-xml docbook-xsl libept1.5.0 librarian0 libunique-1.0-0 libxml2-utils linux-image-4.9.0-3-amd64 linux-image-4.9.0-4-amd64 linux-image-4.9.0-5-amd64 rarian-compat sgml-data
Use 'apt autoremove' to remove them.
  libpolkit-backend-1-0-elogind lxde lxde-core lxsession lxsession-logout openbox-lxde-session policykit-1 synaptic
  libpolkit-gobject-1-0 libpolkit-gobject-elogind-1-0
  devuan-baseconf elogind eudev libelogind0 libeudev1 libpam-elogind libperl5.24 libpolkit-agent-1-0 libpolkit-gobject-1-0-elogind libudev1 perl perl-base perl-modules-5.24 python-wicd sysv-rc task-british-desktop task-english tasksel tasksel-data udev wicd
  wicd-daemon wicd-gtk
23 upgraded, 2 newly installed, 8 to remove and 0 not upgraded.
Need to get 10.4 MB of archives.
After this operation, 8,881 kB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
These packages are a bit different from my desktop machine, but it still wants to rmove LXDE.
Geoff
#3 2018-04-18 19:50:10
Geoff 42
I have just spotted Golinux' link to
https://dev1galaxy.org/viewtopic.php?pid=8217#p8217
I thought that I had the elogin stuff sorted, but will have to check again.
Geoff
#4 2018-04-18 19:52:33
I'd try aptitude why lxde and the same with the other packages that it wants to remove. Find out what brought them in. It's probably being replaced. And it's probably related to the new versions of elogind and/or policykit-1 that were put in ascii earlier today.
You're the second one today with something like this. (Looks like a metapackage issue.)
#5 2018-04-19 08:24:17
Geoff 42
I did try aptitude, but the info was not obviously helpful :-
# aptitude why lxde
i   lxde-core Suggests lxde
# aptitude why lxde-core
i   lxde Depends lxde-core
# aptitude why-not lxde
Manually installed, current version 9, priority optional
No dependencies require to remove lxde
# aptitude why-not lxde-core
No dependencies require to remove lxde-core
I'm now going to work through your post from Irrwahn, which Golinux linked to.
Geoff
#6 2018-04-19 08:47:35
Geoff 42
I think that everything appears to be correct, the following are installed :-
policykit-1              0.105-18+devuan2.4
libpolkit-agent-1-0      0.105-18+devuan2.4
libpolkit-backend-1-0-elogind      0.105-18+devuan2.4
libpolkit-gobject-1-0-elogind      0.105-18+devuan2.4
These all want to go from v2.4 to 2.9
On my desktop consolekit is installed.
pam-auth-update offers
Pluggable Authentication Modules (PAM) determine how authentication, authorization,
and password changing are handled on the system, as well as allowing configuration
of additional actions to take when starting user sessions.
Some PAM module packages provide profiles that can be used to automatically adjust
he behavior of all PAM-using applications on the system.  Please indicate which of
hese behaviors you wish to enable.
PAM profiles to enable:
[*] Unix authentication
[*] GNOME Keyring Daemon - Login keyring management
[*] elogind Session Management
[*] Inheritable Capabilities Management
I left these all selected and tabbed to <OK> and hit <return>.
apt-get still wants to remove LXDE.
Geoff
#7 2018-04-19 09:08:08
Geoff 42
Investigating with Synaptic, and trying marking for upgrade, suggests that
upgrading policykit-1 wants to remove
and install
libpolkit-backend-consolekit-1-0
libpolkit-gobject-consolekit-1-0
Marking consolekit for removal would remove
I haven't worked out yet why it wants to remove consolekit, but that would remove LXDE.
Geoff
#8 2018-04-19 09:20:11
Geoff 42
Looking at my posting from my laptop, I see that it wanted to remove policykit-1, so a quick check in Synaptic shows that removing policykit-1 would also remove LXDE.
Geoff
#9 2018-04-19 09:42:38
Geoff 42
# apt-cache depends consolekit
  Depends: libpolkit-gobject-1-0
    libpolkit-gobject-1-0-systemd
Neither of those is installed.
If I ask it to install libpolkit-gobject-1-0
then it will remove :-
policykit-1-gnome
and install
lxpolkit
and upgrade
libpolkit-agent-1-0
then it will also remove
cups-pk-helper
upower
xfce4-power-manager
and also install
I think that I will try and install libpolkit-gobject-1-0, but I will post this while my machine is still working!
Geoff
No, it won't do it, "Fix broken packages first".
#10 2018-04-19 11:34:26
You should be able to have both elogind and consolekit installed. Which one is used is determined by which backend is installed. What happens (after fixing broken) if you try to install
I think those will satisfy the deps so it won't ask for libpolkit-gobject-1-0-systemd
I can try this today. (Install lxde and then upgrade)
#11 2018-04-19 13:13:19
Well, I tried it, and I didn't run into any problems.
What I did:
installed to real hard drive with desktop-live-lxde iso I made a couple months ago. (task-lxde-desktop was installed)
apt-get update
apt-get upgrade
apt-get dist-upgade
I automatically got the two new libpolkit packages for consolekit (-backend and -gobject)
I'm using slim here. Did you change your display manager?
#12 2018-04-19 13:26:53
Geoff 42
# apt-get install libpolkit-backend-consolekit-1-0 libpolkit-gobject-consolekit-1-0
  chromium-inspector libavcodec56 libavresample2 libopenjpeg5 libschroedinger-1.0-0 libvpx1 libwebp5 libwebpdemux1 libx264-142
  libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 policykit-1
  libpolkit-backend-1-0-elogind libpolkit-gobject-1-0-elogind
  libpolkit-backend-1-0 libpolkit-backend-consolekit-1-0 libpolkit-gobject-1-0 libpolkit-gobject-consolekit-1-0
  libpolkit-agent-1-0 policykit-1
2 upgraded, 4 newly installed, 2 to remove and 25 not upgraded.
Need to get 186 kB of archives.
After this operation, 43.0 kB of additional disk space will be used.
Abort.
That looks as though it shouldn't break too much. Is it ok that it would remove libpolkit-backend-1-0-elogind and libpolkit-gobject-1-0-elogind?
I had used slim earlier, but had switched to lxdm after upgrading to Ascii.
Geoff
#13 2018-04-19 13:39:36
Geoff 42
I see that Penguinwrangler has hit the same sort of problem with KDE
https://dev1galaxy.org/viewtopic.php?id=2007
and has managed to work round it by installing libpolkit-backend-elogind-1-0. I had a look at that and it wanted to remove LXDE.
Geoff
#14 2018-04-19 13:57:15
Geoff 42
I saw the thread on DNG https://lists.dyne.org/lurker/message/2 … 53.en.html and have decided to go for it!
This runs without errors and now I can run
# apt-get update
And this runs without error. I now need to see if I can do things like shutdown.
Geoff
#15 2018-04-19 14:02:14
Geoff 42
Yes, I can select "reboot" from the exit menu and it still works, although it does still produce the GDBus error message which I reported elsewhere.
https://dev1galaxy.org/viewtopic.php?pid=8185#p8185
The early signs are that this works ok, with the suggestion that maybe elogind doesn't work with LXDE.
Geoff
#16 2018-04-19 15:36:46
Geoff 42
I have performed the same commands on my LXDE laptop and that also still works nicely and can also reboot from the exit menu.
Geoff
#17 2018-04-19 16:42:53
When I tested two months ago, I was able to use elogind with lxde. I would try that now, except that I already wiped that lxde install. All those *kit packages just went through a lot of changes, so it might be different now.
Anyway, it sound like you fixed it. If you use consolekit or elogind, you must have the corresponding libpolkit packages with it. Those are what determines which one gets used.
This problem might now be fixed for upgrades from jessie and new installs of ascii. For upgrades from ascii to ascii, the suggested fix seems to be working.
#18 2018-04-19 18:04:03
Geoff 42
If I mark libpolkit-{backend|gobject}-elogind-1-0 for installation, then it wants to remove lxde. This is the case whether the 1-0 is at the end or in the middle.
I do have elogind, libelogind0 and libpam-elogind installed and elogind is running as is the console-kit-daemon.
Geoff
#19 2018-04-20 13:28:03
Geoff 42
I have had a quick look at libpolkit-{backend|gobject}-elogind-1-0 to see if there is a problem.
$ aptitude why-not libpolkit-backend-elogind-1-0
i   libpolkit-backend-consolekit-1-0 Conflicts libpolkit-backend-elogind-1-0
$ aptitude why-not libpolkit-gobject-elogind-1-0
i   libpolkit-gobject-consolekit-1-0 Conflicts libpolkit-gobject-elogind-1-0
It appears that the libpolkits need either consolekit or elogind, but not both  and LXDE only works with the consolekit versions.
Geoff
#20 2018-04-20 22:37:14
Devs have been looking at this today, and the consensus is that lxde is an abomination. If you have it working, that's good. Don't look at the ugly combination of packages. Meanwhile, I'm getting ready to purge all desktop environments from all of my computers.
#21 2018-04-21 05:55:42
Geoff 42
I did initially have a look at LXQT :-
https://dev1galaxy.org/viewtopic.php?id=94
but I reverted to LXDE as lxqt-panel pulled in libpulse0 and libsystemd0.
Geoff
#22 2018-04-21 09:47:18
How are you running X without libsystemd0???
#23 2018-04-21 10:27:04
Geoff 42
Yes, X does pull in libsystemd0, so maybe I shouldn't be too worried, but I thought that the fewer packages that pull in libsystemd0, the better.
As I check up, I see that I also have libpulse0 installed. If I were to remove that, then that would take out, inter alia :-
chromium, ffmpeg, flightgear, gimp, kodi, qemu, vlc, wireshark
I do not have pulseaudio installed but I do have apulse.
Is it easy to convey the abominability (?) that the devs felt about LXDE.
Geoff
#24 2018-04-21 12:17:25
lxde pulls in an odd combination of packages for both consolekit and elogind. All the other desktops are fine with one of those. (kde and lxqt use elogind, the others work with just consolekit.)
#25 2018-04-23 09:14:24
Geoff 42
I have now re-installed LXQT alongside LXDE. I did this by installing lxde. If I were to install task-lxqt-desktop, it would remove lxde and consolekit and install the elogind stuff.
I can select either lxde or lxqt from the lxdm login screen and they both work. lxde is fine, but with lxqt it does want me to enter the root password as the first thing. I have not yet worked out why it is doing this, but I guess that this is a problem with not having all the elogind stuff installed. Generally lxqt does seem to work reasonably well although I have not had a chance to polish it to my liking yet.
Is lxqt the way forwards? Should we be moving away from lxde?
Geoff
