#1 2018-04-03 02:49:58
GNUser
trying to understand basics of SysVinit scripts [SOLVED]
This is a super basic exercise that has me stumped. Please help and pardon my ignorance.
1. I created /etc/init.d/test with this in it:
touch /home/bruno/Desktop/hello
Then I made the script executable.
2. I ran this command: sudo ln -s /etc/init.d/test /etc/rc2.d/S09test
3. I reboot the system.
The script does not appear to run (i.e., a file named "hello" does not show up on my desktop). What am I missing?
P.S. I do not want to use LSB headers or the update-rc.d command. I can get things to work that way, but for this exercise I want to do things manually and as simply as possible so that I can understand the absolute bare essentials.
#2 2018-04-03 04:07:24
Re: trying to understand basics of SysVinit scripts [SOLVED]
You'll probably do need to understand insserv, which is the one using the LSB headers, and manipulating the files /etc/init.d/.depend.{boot,start,stop}, which are the "make files" for the init process. I'm not totally sure where/when/how init uses those files, but as I remember it, those files tell which scripts to run when. The insserv man page points at startpar as the actual driver process, so I guess, all together it's init, insserv and startpar to peruse.
#3 2018-04-03 12:46:24
GNUser
Thank you, ralph.ronnquist. I guess nothing is ever as simple as it seems.
I will learn about insserv and friends, and will experiment with the hidden files. I have a full partition backup, so I can tinker with abandon.
I'll update the thread if there is a simple solution to my little exercise. If it's too complicated, it kind of defeats the purpose.
#4 2018-04-03 13:00:05
GNUser
The missing step was to add test to the end of the TARGETS list at the top of /etc/init.d/.depend.start
At this point I don't understand why it worked, but am happy to be one step closer to understanding.
Thanks again!
