#1 2018-03-10 13:07:44
miroR
"[quote] was opened within [s]" FluxBB bug?
Pls. have a look at
Safe GnuPG setup (with offlined master secret key)
https://dev1galaxy.org/viewtopic.php?id=1929
and go straight to the bottom, to the note [4]. I explained it there.
And I can try and make a quick (little time available) testcase here. In the next post.
Devs/testers/users of FOSS, what might be ahead for GNU/Linux after we lost PaX Team and spender? spender wrote:
https://forums.grsecurity.net/viewtopic … 699#p17127
Google made the choice to engage in underhanded competition against us with our own code...
grsecurity ripoff by Google, w/ Linus approval https://lists.dyne.org/lurker/message/2 … 4b.en.html
#2 2018-03-10 13:10:25
miroR
Re: "[quote] was opened within [s]" FluxBB bug?
Making a code paste:
some thing [S]
Opening a quote:
somebody said that...
Nope. This works! Why similar stuff wouldn't work in my topic (linked in previous post here)?
#3 2018-03-10 13:15:04
miroR
Here, this is the GnuPG setup which you can be reasonably sure is safe to use.
sub   rsa3072 2018-03-08 [S]
--list-secret-keys
And this is from my topic linked. But I removed the text, left just the tags... Works again... But I asure you I had to insert spaces around the  'S' of  [ S ] in the code, else it kept complaining... (this [ S ] needs spaces because there is no closing tag for it).
Regards!
P.S. Just tried to add "?" to the topic title. Can't do it...
EDIT: was editing non-first post of mine. Sorted.
#4 2018-03-10 18:14:18
miroR
I got it again!
And this time it's similar:
The following errors need to be corrected before the message can be posted:
    [ s ] was opened within itself, this is not allowed
And the text that I was trying  to past is exactly what I did eventually past (of course, the url tags will be added independent of my will), with the sole difference that I will, just right now, in the immediate next paste it with the spaces for the [ s ] added (s capatal or lowercase, that doesn't matter, I don't think).
The text at this time, with that error by FluxBB corresponds to this hash:
mr@gdOv:~$ sha256sum /Cmn/mr/Dev1_180310_GnuPG_safe_2.txt
d31a5f9a403c4103a17e2e313133f0bc0130d7507930b6a267dc47a3cb0f4004  /Cmn/mr/Dev1_180310_GnuPG_safe_2.txt
mr@gdOv:~$
I don't have my next post's exact link, but it's in that same new today's topic of mine.
Ah, while posting this, I got:
[ s ] was found without a matching [ /s ]
(without spaces, of course).
And now:
    [ /s ] was found without a matching [ s ]
#5 2018-03-12 05:34:50
The "s" bbcode makes a strike-through
See https://dev1galaxy.org/help.php#bbcode
#6 2018-03-12 08:44:57
miroR
Right, insufficient user understanding.
It is allowed in the
...[S]...
, as:
https://dev1galaxy.org/viewtopic.php?id=1929#p7925
does have a lot of those. I isn't allow where it would only have the meaning of starting a strike-through...
Took me a while to understand...
Thanks. Regards!
